POV-Ray : Newsgroups : povray.off-topic : OpenCL Server Time
20 Mar 2026 01:42:36 EDT (-0400)
  OpenCL (Message 1 to 10 of 40)
Subject: OpenCL
Date: 16 Aug 2011 07:58:59
Message: <4e4a5b83$1@news.povray.org>
about the FAQ "POV-Ray/raytracing on GPU" I am actually quite curious
how many systems would actually support double precession floating point
types (as needed by POV-Ray) and how *fast* they are.
If you are not using Windows(tm) there is no need to read on because
Apple's OpenCL implementation does currently not support 64bit floats
anyway and the same is AFAIK true for any Linux system. This might and
should change in the future but this is the current situation.
I've written a simple Windows program (a kind of "realtime" Mandelbrot
explorer) that is meant to check the capabilities of your system.
You can download it here (please check the included readme.txt)
http://www.lilysoft.org/Download/YAMF/yamf.zip
and send an email to me (ive[at]lilysoft[dot]org) or maybe simply reply
to this post. My guess is that both the availability and performance
gain will be quite disappointing.
thanks a lot
-Ive
Subject: Re: OpenCL
Date: 18 Aug 2011 05:54:06
Message: <4e4ce13e$1@news.povray.org>
Am 16.08.2011 13:58, schrieb Ive:
Benchmark result:
Window size 540 x 540 pixel
Maximal 1024 iterations
CPU with 8 threads
fps 6.82527
OpenCL GPU with 30 worker units
GeForce GTX 285
fps 26.41509
(CPU is an Intel i7 QuadCore)
OpenCL information:
Platform 0
   OpenCL 1.0 CUDA 4.0.1
   NVIDIA CUDA
   NVIDIA Corporation
   Device 0 - GPU  30 computing units active
     JIT compiler installed
     Data types with preferred and native vector width
       8bit integer: 1, 0
     16bit integer: 1, 0
     32bit integer: 1, 0
     64bit integer: 1, 0
     16bit float: not supported
     32bit float: 1, 0
     64bit float: 1, 0
Subject: Re: OpenCL
Date: 22 Aug 2011 03:12:31
Message: <4e52015f@news.povray.org>
Am 18.08.2011 11:53, schrieb clipka:
> CPU with 8 threads
> fps 6.82527
> GeForce GTX 285
> fps 26.41509
Thats what I'd have guessed and for anything with more *logic* involved
there is less speedup to be expected.
You can also install the Intel OpenCL driver from
http://software.intel.com/en-us/articles/download-intel-opencl-sdk
only the runtime at the bottom is needed. Intel's JIT compiler does a
pretty good job in optimizing. It uses SSE4 instructions when available
and is good for a speedup of about 15% compared to 'native' CPU threads.
And people with an AMD CPU but with a NVidea graphics card can download
and install the AMD Stream-SDK to add OpenCL support for the CPU.
Currently without support for double precession floats but this is
announced to change with the next release. No need to do this when also
a AMD graphics card is used as OpenCL is part of the Catalyst driver.
> OpenCL information:
> Platform 0
> NVIDIA CUDA
> NVIDIA Corporation
> 8bit integer: 1, 0
> 16bit integer: 1, 0
> 32bit integer: 1, 0
> 64bit integer: 1, 0
> 32bit float: 1, 0
> 64bit float: 1, 0
This isn't the latest NVidea driver or is it?
Anyway related to POV-Ray: OpenCL for 3.7 does IMHO not make any sense
as it would require major changes within the multi-threading framework.
On the other hand it looks quite straightforward to implement for MCPov
and as MCPov is currently just single-threaded a 10x speedup when
running on the GPU seems realistic. Well, most likely I do not see some
pitfalls there but as time permits I will give it a try.
-Ive
Subject: Re: OpenCL
Date: 22 Aug 2011 08:25:16
Message: <4e524aac@news.povray.org>
Am 22.08.2011 09:11, schrieb Ive:
>> OpenCL information:
>> Platform 0
>> NVIDIA CUDA
>> NVIDIA Corporation
>> 8bit integer: 1, 0
>> 16bit integer: 1, 0
>> 32bit integer: 1, 0
>> 64bit integer: 1, 0
>> 32bit float: 1, 0
>> 64bit float: 1, 0
It's 6.14.12.7533, to which I upgraded in June this year. Don't know if
there's anything newer by now.
Mind the recursion.
Subject: Re: OpenCL
Date: 22 Aug 2011 13:20:49
Message: <4e528ff1$1@news.povray.org>
Am 22.08.2011 14:25, schrieb clipka:
Strange. I was wondering about OpenCL version 1.0 and also about the
missing support for 'half' floats as they are NVideas 'own' invention.
> Mind the recursion.
Sure, but every recursion can also be expressed as an iteration ;)
-Ive
Subject: Re: OpenCL
Date: 22 Aug 2011 13:57:07
Message: <4e529873$1@news.povray.org>
>> Mind the recursion.
I'm fairly sure that's incorrect, but I can't find a reference...
http://blog.orphi.me.uk/
Subject: Re: OpenCL
Date: 22 Aug 2011 15:00:37
Message: <4e52a755$1@news.povray.org>
Am 22.08.2011 19:56, schrieb Orchid XP v8:
>>> Mind the recursion.
...and I'm fairly sure it is true as long there is proof that the
iterative calculus is Turing-complete as all Turing-complete calculi are
idempotent.
But I'm much more interested in the practical aspect and expressing
recursive raytracing with iterations is trivial in this case as the
OpenCL kernel-language is close to C99 (just without recursion).
-Ive
Subject: Re: OpenCL
Date: 14 Oct 2011 00:06:33
Message: <4e97b549$1@news.povray.org>
CPU with 4 threads
fps 70.70707
I don't know why I don't get OpenCL options enabled , I have 11.8
Catalyst and a a couple ATI RADEON 4670 in CrossFire with a AMD Phenom
II X4 3.4Ghz. ANy clues?
Subject: Re: OpenCL
Date: 14 Oct 2011 10:50:04
Message: <4e984c1c$1@news.povray.org>
Am 14.10.2011 06:06, schrieb Saul Luizaga:
> CPU with 4 threads
> fps 70.70707
AFAIK only ATI FirePro and Radeon 5xxx/6xxx graphics cards do support
OpenCL. The Radeon 4xxxx series does definitely not support it. Sorry.
-Ive
Subject: Re: OpenCL
Date: 14 Oct 2011 18:31:25
Message: <4e98b83d$1@news.povray.org>
Actually they do but only partially, yes the 5000 series and above are
fully compliant, too bad my 4670s are double precision only, they don't
handle single precision floats and have some power to offer & guess I
got screwed over by AMD, oh well.
