POV-Ray : Newsgroups : povray.off-topic : Today's WTF moment Server Time
17 Jun 2026 01:04:54 EDT (-0400)
  Today's WTF moment (Message 35 to 44 of 64)
Subject: Re: Today's WTF moment
Date: 6 Sep 2011 04:05:11
Message: <4e65d437@news.povray.org>
On 06/09/2011 06:27 AM, Jim Henderson wrote:
> On Mon, 05 Sep 2011 19:32:49 +0100, Orchid XP v8 wrote:
>>>> Yes, but under /normal/ circumstances, it boils at 100°C, which is why
>>>> it's defined that way. :-P
>>> Not here at 4,000 feet - "normal" circumstances here have it boiling at
>>> a slightly lower temperature. :P
>> 96.2°C, a piffling 3.8° lower.
> Which is still not 100C no matter how you slice it.  The difference in
> humidity, altitude, and other things makes cooking things that require
> precise measurements (usually baked goods) slightly different than at
> other altitudes and in other conditions.
I would suggest that the wild variations in oven temperatures have a
vastly bigger impact than a 4% difference in the boiling point of water.
Date: 6 Sep 2011 05:33:52
Message: <4e65e900$1@news.povray.org>
On 9/5/2011 6:12 PM, Alain wrote:
> If you slowly heat very pure water, it can bet a good bit warmer that
> 100°C before it start to boil. There will be vapour escaping from the
> surface, but no ebulition, even in a open container. It's a dangerous
> situation, as any disturbance can cause explosive ebulition projecting
> scalding water everywhere.
Or, very fast, by heating it all more or less at the same time (i.e.,
with something like a microwave oven.
Date: 6 Sep 2011 05:36:31
Message: <4e65e99f$1@news.povray.org>
Legend has it that boiling water in a microwave oven has this effect. I
don't know of an authoritative source which can confirm or refute that...
Date: 6 Sep 2011 05:40:37
Message: <4e65ea95$1@news.povray.org>
On 9/6/2011 1:04 AM, Invisible wrote:
> On 06/09/2011 06:25 AM, Jim Henderson wrote:
>> On Mon, 05 Sep 2011 21:12:15 -0400, Alain wrote:
>>> You can have water that stay liquid down to -10°C and possibly even
>>> less. You need a container with very smooth surface and no particles in
>>> suspention. In this state, a vibration can be just enough to cause
>>> almost instant crystalisation.
>> Which is actually quite cool
> I see what you did there.
> I've got a box of hand warmers at home. They contain a super-saturated
> solution (of what I don't know). Once you provide a nucleation point,
> the whole lot crystallises within a few seconds. It also gets quite warm
> in the process. (This is what makes it good for warming your hands.)
Seen those. There is also some expensive shirt that was made for
joggers, which uses a similar principle, though, in that case, I get the
impression they formulated the material so it crystalized faster than
normal in cold temperatures, releasing heat, but softening faster than
normal too, absorbing it, thus keeping you cooler, or warmer, depending
on conditions.
Always wondered, in the case of the whole "heat pack" thing though if
you couldn't make one that did the reverse, and was "recoolable", or
whatever. The principle being, of course, than it is rechargable, so
long as the solution doesn't change (often the plastic is
semi-permiable, so loses moister over time, and stops working), so when
you let it cool slowly, it "holds" the excess energy. When you apply
kinetic energy to it, it instantly starts losing all of what it
retained, and crystallizes. You would basically need to do the reverse,
somehow, for a "cold pack", crystallizing it, so as to "lose" more heat
than it needs in a stable state, then.. there comes the rub. Other than
that it would liquify as it absorbed the heat, instead of crystallizing,
like the supersaturation, I am not clear how you would manage to make it
so it could recharge effectively.
Date: 6 Sep 2011 05:41:06
Message: <4e65eab2$1@news.povray.org>
Uh.. Mythbusters? They tried it, and it did. lol
Date: 6 Sep 2011 06:08:21
Message: <4e65f115@news.povray.org>
> whatever.
Hmm. Plausibly.
I would imagine, like with other refrigeration technologies, the key is
to find a material which has a phase change at the right temperature.
Normal hand warmers become super-saturated solutions at very high
temperatures. If you wanted to make something cold, you'd need something
that becomes super-saturated at a low temperature.
I'm also not completely sure of the kinetics: a hand warmer releases
heat quickly, and absorbs it slowly. That may or may not be useful for
cooling purposes.
Unrelated, but I note that dissolving ammonia in water is an endothermic
reaction. That, apparently, is how Victorian icecream was made. So I
guess the question is, WOULD YOU EAT IT? ;-)
Date: 6 Sep 2011 14:34:22
Message: <4e6667ae$1@news.povray.org>
>> that...
I've also had it happen to me.
Jim
Date: 6 Sep 2011 14:35:08
Message: <4e6667dc@news.povray.org>
>>>>> why it's defined that way. :-P
>>>> at a slightly lower temperature. :P
My point is that 4% is still 4%.
Jim
Date: 6 Sep 2011 14:35:45
Message: <4e666801@news.povray.org>
>>> in suspention. In this state, a vibration can be just enough to cause
Wow, *completely* unintentional, that one.  Honest. :)
Jim
Date: 6 Sep 2011 15:59:03
Message: <4e667b87@news.povray.org>
Me too.
   How come I never get only one kudo?
