POV-Ray : Newsgroups : povray.off-topic : Fibrous Server Time
16 Jun 2026 20:13:46 EDT (-0400)
  Fibrous (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Fibrous
Date: 20 Jul 2011 07:22:22
Message: <4e26ba6e@news.povray.org>
Jim Holsenback <nom### [at] nomailcom> wrote:
> On 07/20/2011 06:21 AM, Invisible wrote:
> > Given that it's impossible to draw fur in CGI, how come so many people
> > are drawing fur in CGI?
> must be then that your initial assumption is a bit off the mark ;-)
  Although, to be fair, most (if not all) the rendering software that are
capable of rendering realistic-looking fur are using tricks to make it
look realistic instead of simulating what happens in real life, which is
quite complicated and would require a humongous amount of time to calculate
properly, with all the microscopic semitransparent layers of organic
material scattering and diffusing the light from all possible directions,
and so on. (For example, I think there's a phenomenon that happens when
light passes between two objects which are very close to each other, so that
the objects affect the light even though it's not technically speaking
"touching" them, and has something to do with the amplitude of the light
wave or something. Simulating this accurately with thousands of indivisual
hairs would be prohitively heavy. This not to talk about the scattering
that happens when light goes through a semi-transparent hair.)
Date: 20 Jul 2011 08:33:04
Message: <4e26cb00@news.povray.org>
...which is kind of my point. You can't render and illuminate hundreds
of thousands of complex shapes "directly". It's impossible. (Or at
least, utterly infeasible.) The fact that so many people now do CGI hair
means that somebody somewhere has found a way to fake it. I'm wondering
if anybody knows what that is.
Date: 20 Jul 2011 11:47:45
Message: <4e26f8a1@news.povray.org>
> "touching" them,
It is called "diffraction".  More than you ever wanted to know at wikipedia.
Note that just rolling up your index finger and peeking thru the hole, or
putting two fingers next to each other and looking at the slit between your
fingers when your knuckles are touching, is small enough to give you visible
diffraction effects. Say, half a mm?
   "Coding without comments is like
    driving without turn signals."
Date: 20 Jul 2011 11:54:51
Message: <4e26fa4b@news.povray.org>
> is small enough to give you visible diffraction effects. Say, half a mm?
Oh. Is /that/ what that is? I thought my eyes were just defective...
Date: 20 Jul 2011 19:20:01
Message: <web.4e27621accd941e4273b877e0@news.povray.org>
They are probably faking as much as povray is in not directly rendering millions
of grains of sand and cement comprising those infinte planes...
Date: 21 Jul 2011 09:07:52
Message: <4e2824a8$1@news.povray.org>
> I'm wondering if anybody knows what that is.
This post is bordering on being on topic and should go in .advanced-users.
I seem to recall reading that in the Final Fantasy movie, they DID have
shots where each strand of hair was made up of  3 or 4 triangles, and
the model had 60,000 individual hairs, if I'm not mistaken.  Considering
that this movie was made over 10 years ago, one can safely assume that
rendering a similar shot today would be next to trivial.
I do know that Golumn's hairs were also individually modeled and
rendered, but he only had a handfull of them, so it's not quite the same
level of complexity.  ;)
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 21 Jul 2011 09:16:52
Message: <4e2826c4@news.povray.org>
  You forgot the first law of rendering: Computers get faster, rendering
times don't.
Date: 21 Jul 2011 13:47:10
Message: <4e28661e@news.povray.org>
> times don't.
And for anyone technologically naive that doesn't understand what that means
(i.e., nobody actually reading this message), simply point to the dog in the
first Toy Story and in the second Toy Story.
Date: 25 Jul 2011 04:36:39
Message: <4e2d2b17$1@news.povray.org>
> shots where each strand of hair was made up of 3 or 4 triangles, and the
> model had 60,000 individual hairs, if I'm not mistaken. Considering that
I had a brief look around the Internet, and failed to find any technical
data about the film. (Other than yes, it really was 10 years ago.
Apparently I am significantly older than I realised.)
I would have thought that 3 or 4 triangles would be nowhere near enough
to represent a shape as complex as a strand of hair. (Although I notice
that Aki is conspicuously straight-haired.) 60k strands of hair sounds
like a plausible amount for one head. That gives us well in excess of
100k triangles just for the hair; no wonder the typical render time is
90 minutes per frame. (I'm still surprised the finished film contains
less than 1M frames.)
Similarly, the sorts of figures I've seen vaguely suggested for the
total poly count of the characters seems way too low. (I can hardly
believe that in this day and age, flat polygons are still the most
advanced technology available for representing complex curved shapes...)
Date: 25 Jul 2011 06:49:01
Message: <4e2d4a1d@news.povray.org>
> times don't.
Corollary: You cannot afford a fast enough computer.
