![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://www.eecs.harvard.edu/~cduan/technical/git/
Having spoken with half a dozen people who said "I hate git, it's so
confusing" and then after showing them this they go "wow, that's really
easy", I figured it might be worthwhile to show people this. :-)
"Coding without comments is like
driving without turn signals."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 19/04/2011 20:25, Darren New nous fit lire :
Let's start a holy troll war. best OS or browser is so 20th century.
I prefer mercurial. ;-)
Oh, there is a false assertion about rebasing being unique to git on the
last page.
And doing graph in ascii art... ouch on the web!
(really, graphviz is not that hard to learn)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I prefer Darcs. Then again, I haven't tried any other [distributed] VC
system, so...
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I honestly wasn't recommending git.
However, that said, and with the understanding that I haven't looked at the
other DVCSs, I think git has a very interesting layered approach to the problem.
First you have the virtual file system that is the repository.
Then on top you have actual commits and such, almost completely independent
of the file system model.
Then on top of that you have stuff like packs and transfer protocols and
such, again almost completely independent of the file system and commit model.
Kind of cool, in much the same way that Second Life has a kind of cool
business model regardless of how well they actually implemented the code.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the other DVCSs, I think git has a very interesting layered approach to
> the problem.
OK, I just sat down and read it.
Yeah, it's fairly straight-forward. But I can see how if you don't
understand the way it works, there's huge potential to *seriously*
confuse yourself!
I had assumed that all DVCSs were the same, but I now see that at least
Git and Darcs use fundamentally different models.
Fundamentally, any version control system tracks changes to files. What
Git appears to be doing is something similar to RCS or CVS, where each
file goes through a strictly sequential series of "versions", and one
version comes "before" or "after" another. It seems that each commit
stores the complete state of the entire repository. (Presumably as a
diff relative to the previous commit, but still logically it's a
snapshot of everything.) Git then uses "heads" to point to the most
recent commit in each branch, or to other interesting points in the history.
Darcs works completely differently. Darcs doesn't track sequential file
versions, it tracks change-sets. It defines a "change-set algebra" where
unrelated changes to the same file are independent, and can be applied
or reverted independently. Changes to the same part of a file are not
independent, and can only be applied in sequence. But unrelated changes
are... unrelated.
As an example, if I add some comments to file X and commit that, and
then I add a new function to file X and commit that too, I get two
change-sets. I can revert adding the comments but still keep the new
function, even though the latter change happened *before* the former.
As far as I can tell, Git would require me to create a branch where I
add the comments, and another branch where I add the new code, and then
merge them back into the main branch, hoping that I don't get any
conflicts. To me, this seems like a lot more work and a lot more
conceptual overhead.
It also seems that when you ask Git to perform a commit, you have to
tell it which files to record changes for. With Darcs, you tell it which
files to monitor, and when you ask to commit it detects what's changed
and interactively asks you which differences to include and which ones
not to include. E.g., I could add comments to file X, add a new
function, do a commit and interactively split the modifications into two
separate commits. (It doesn't /always/ work, of course, but mostly it does.)
I wonder how well the illusion of one single sequence of file versions
works when you have multiple people editing the file in parallel. I
would imagine the Darcs model works better, because it doesn't try to
pretend that file X looked like this, and then this, and then this. It
just records what edits happened, without recording their relative
ordering [except where they affect the same lines of code]. Git, on the
other hand, appears to be trying to track what every file in the entire
repository looked like in every individual commit object.
With Darcs, you make a branch by copying the repository. That's it.
(Although there is an option to build a bunch of symlinks for you
instead of just copying, to save a bit of disk space. Presumably only on
POSIX platforms...) You can email individual change-sets around, and
this works. Getting somebody else's changes just copies all change-sets
from their repository into yours. You can then resolve any conflicts.
Still, I've used Darcs quite a bit, and I've never once used Git, so I'm
not really qualified to say how well it works in practise.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> history.
> are... unrelated.
It appears Mercurial works the same was as Git:
http://mercurial.selenic.com/wiki/UnderstandingMercurial
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
One thing which apparently can't be done with Darcs, Git or Mercurial is
managing multiple repositories at once.
For example, consider Glasgow Haskell Compiler, which is written in
Haskell itself. The compiler, interpreter and run-time system are one
repo, and the various standard libraries it requires are independent
projects with their own repos, but GHC mirrors a copy of each, lagging
behind the upstream slightly. The main GHC repo contains a special Bash
script to do things like update all the sub-repos automatically. The
existence of this script tells you that there's functionality that Darcs
itself is failing to provide. (And Git and Mercurial, apparently.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
As an aside, I do envy you to some extent for actually knowing people
IRL who know how a computer works...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 4/20/2011 2:44, Invisible wrote:
> I had assumed that all DVCSs were the same, but I now see that at least Git
GIT stores files, and deduces change sets from those files.
Mercurial stores change sets, and deduces files from those changesets.
No, git actually tracks entire files. Every time you check something in, any
file you add to staging (i.e., any file with any change) is stored in its
entirety in the repository. And, technically, *every* file in the entire
repository is stored, but if you haven't changed it, it has the same sha-1
name, so it doesn't physically get copied.
Only later do you compress the repository into diffs. But a file can be
stored as a diff from a different file it was never related to, that was
created whole-hat *after* you checked in the file it's a diff from.
> What Git
> appears to be doing is something similar to RCS or CVS, where each file goes
> through a strictly sequential series of "versions", and one version comes
Nope. Not even close. git is storing the entire repository on every commit.
That's the completely boggling idea there.
> It seems that each commit stores the complete
Yes. So there's no "before" or "after" for files, technically. There's
before or after for repositories.
> (Presumably as a diff relative to the previous commit,
Nope. It stores the entire repository. Now, if you don't change a file, it
hashes to the same value, and hence doesn't need to get stored again. But
the entire file is put into the repository.
That's why git doesn't have a "rename" command. That would imply you're
storing something other than files in the repository. git looks at the same
contents disappearing from one part of the directory structure and showing
up in another and says "Gee, that must have been a rename." If there are
minor changes between what disappeared on this commit and what showed up
somewhere else on that commit, git says "there's a 97% probability this was
a renamed file."
When you do a "git gc" to collect garbage, it then looks for a good way to
generate diffs between files, and it looks through all the files (not just
ancestors) to find good versions to diff from, and it stores the diffs. But
that's just an storage optmization, just like the fact that it gzips the
files in the repository is a storage optimization.
If I checked in a configuration file with my name in it, and 2 days later
deleted it, and then you checked in a similar configuration file with your
name in it, and then we did a "git gc", it's entirely possible (likely,
even) that my file would be stored as a diff from your file.
In contrast, it seem Mercurial actually stores a tree of changes.
The only reason git uses a pointer to earlier commits is when you merge
things, you don't want to apply changes you already applied in an earlier
merge.
For example, when you merge branch A into branch B, git finds the common
ancestor (i.e., the point at which you separated B from A in the first
place), then *generates* the diff between what's now A and where they
branched, then *applies* that diff to B, and leaves it ready for a commit.
There's no diff stored before you type "git merge" or after it returns from
the command line.
Reverting a commit involves either just throwing away the new version, or
generating a reverse diff and applying it.
That's the thing that throws people about git, apparently. They're thinking
in terms of diffs, when it's easiest to understand if you just think about
it in terms of file contents.
> Git then uses "heads" to point to the most recent commit in each branch, or to
Right.
> unrelated changes to the same file are independent, and can be applied or
> are... unrelated.
Yeah, from the little I read about it, Darcs is another one of those
"interesting" ideas. An actual mathematical system for defining a
repository, like relational algebra did for databases.
> As an example, if I add some comments to file X and commit that, and then I
> add a new function to file X and commit that too, I get two change-sets. I
> can revert adding the comments but still keep the new function, even though
> As far as I can tell, Git would require me to create a branch where I add
> the comments, and another branch where I add the new code, and then merge
> them back into the main branch, hoping that I don't get any conflicts. To
> me, this seems like a lot more work and a lot more conceptual overhead.
Nah. That's only if you want to have both at once working in parallel. That
is, if you want one version with the comments but no function, and another
version with the function but no comments, that's trivial in git. If you
then want to combine them into a third version that has both comments and
function, then you merge, which is also trivial unless you changed the same
lines in both places. (I.e., it's as trivial as any other diff-patch based
merge.)
> It also seems that when you ask Git to perform a commit, you have to tell it
Sure. But you can say "add all changes" trivially. Or you can use
interactive tools to commit just bits and pieces of this and that.
Basically, there's a "staging" area where you build a new copy of the
repository by including files and directories that are different from what's
out there already. Then you add those new files and directories to the
repository and point a commit to the new top-level directory.
> With Darcs, you tell it which files to
> monitor, and when you ask to commit it detects what's changed and
> interactively asks you which differences to include and which ones not to
> include. E.g., I could add comments to file X, add a new function, do a
> commit and interactively split the modifications into two separate commits.
This is trivial with GIT. I do it all the time. I'll be adding a new
function, and while testing, realize there's a bug in some other function.
So when everything works again, I'll do two commits, staging just particular
hunks (in the diff sense of the word) and do two commits, one for the bugfix
and one for the new change.
> I wonder how well the illusion of one single sequence of file versions works
There's no single sequence of file versions. Every file is a new version.
Given that it's the repository format used by Linux developers, I think it's
safe to say it works adequately for multiple people editing the file in
parallel.
> I would imagine
> the Darcs model works better, because it doesn't try to pretend that file X
Neither does git.
> It just records what edits
> happened, without recording their relative ordering [except where they
> affect the same lines of code]. Git, on the other hand, appears to be trying
> to track what every file in the entire repository looked like in every
Yes, but since you have them all, you can recreate the diffs between any two
versions whenever you want.
In git you make a branch by saying "make a new branch." That's what boggled
me about mercurial. Really, I need multiple repositories to let me have a
stable version and a development version?
> (Although there is an option to build a bunch of symlinks for you instead of
> just copying, to save a bit of disk space. Presumably only on POSIX
> platforms...) You can email individual change-sets around, and this works.
> Getting somebody else's changes just copies all change-sets from their
git is exactly the same, except it copies files instead of changes. When you
say "pull from that repository", it finds each "head" (i.e., branch tip) and
then recurses through the data structures pulling anything reachable from
them. Since they're all named after the hashes, if you already have a file
of the same name, you don't need to copy it. Then it stores the heads for
the remote repository in a different place of the namespace tree than your
own heads.
But, really, the only things in the git repository are files (blobs),
directories (trees), commits (a log message pointing to a tree and maybe
other commits), and tags (a log message pointing to a commit, possibly
pgp-signed), and then a bunch of names for specific commits or tags or trees
(i.e., branch names). There are no diffs. There is no history. There are no
users.
If you want the log history, you follow pointers from one of the heads thru
the different commit objects. If you want to see what changed, you run diff
on the two files you want to know what changed between. If you want a new
branch, you just modify some files, store them, and point a different name
at the new commit.
If you want to merge someone's repository into yours, you simply copy from
them any files or names that they have that you don't, and you're done.
You're merged. Now if you want to incorporate their changes into your work,
you generate a diff between their latest version and some earlier version,
and apply that diff to your latest version, and you're merged.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
git can do this in a sorta half-assed way. Mercurial apparently can too.
> you that there's functionality that Darcs itself is failing to provide. (And
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
