POV-Ray : Newsgroups : povray.off-topic : Old fart? Server Time
4 Jul 2026 14:23:55 EDT (-0400)
  Old fart? (Message 111 to 117 of 117)
Subject: Re: Old fart?
Date: 22 Apr 2011 11:52:58
Message: <4db1a45a@news.povray.org>
On 4/22/2011 2:28, andrel wrote:
> On 21-4-2011 4:31, Darren New wrote:
>> On 4/20/2011 15:07, andrel wrote:
>>> Suspiciously absent from the blurb is 'how to prevent them'.
>> Actually, the beginning of the book basically says "there's lots of
>> books about preventing bugs. This is a book about fixing them once they
>> happen." He's very clear about that.
> I don't own the book. I only saw the page you linked to.
That's why I'm telling you. :-)
   "Coding without comments is like
    driving without turn signals."
Date: 22 Apr 2011 11:57:19
Message: <4db1a55f$1@news.povray.org>
On 4/22/2011 3:09, andrel wrote:
> *) Some changes might trigger a tool to create a tool to be rebuild.
Just so you know, this isn't difficult in Windows. Heck, I don't even have
to write the makefiles myself - the IDE does it. I have lots of data formats
that I wrote my own compiler for that automatically gets compiled before the
data that depends on them gets compiled.  Stuff like taking a bunch of
frames for an image, automatically laying them out on a bigger sheet and
storing the boundary information separately with an annotation that the
boundary information depends on the constructed sheet and the constructed
sheet depends on the individual frames and the program depends on the parser
for the boundary information and the individual boundary information files
and etc etc etc. It's not any harder (if not easier) to set up in Windows
than Linux.
Date: 22 Apr 2011 13:15:05
Message: <4db1b799$1@news.povray.org>
On 4/13/2011 10:30 PM, Darren New wrote:
> Am I old, or is it really unprofessional to publish an API and have the
> official documentation for the function call be "go read this guy's blog
> from last June to see an example of how to use this API"? Even if the
> guy is the one that implemented it?
In the military in the 2000-01 timeframe they release the Job
Qualification Standard for my specialty (small computers maintenance),
and many of the training references were to websites.  Many of the web
sites did not belong to the military, and some of them were no longer
on-line when I went to read them.
Nice idea, until you try it.
John
Date: 23 Apr 2011 05:51:29
Message: <4DB2A122.6060105@gmail.com>
> have to write the makefiles myself - the IDE does it.
The IDE's that I (superficially) tried when it was relevant (5-10 years
ago) seemed not able to call ctangle before calling the c-compiler (it
simply assumed you were writing C source directly). Let alone call
cweave or mweave (our matlab frontend) to create the docs or mtangle and
leave the results alone. I think some even created a makefile from
scratch everytime, in order to make it impossible to tweak it yourself.
  Unfortunately also in that period I simply had no time for a full
investigation, people had problems recording and analysing their data.
And I could modify the matlab sources directly. Always planning to
backport in the WEB files of course...
> I have lots of
> data formats that I wrote my own compiler for that automatically gets
> compiled before the data that depends on them gets compiled. Stuff like
> taking a bunch of frames for an image, automatically laying them out on
> a bigger sheet and storing the boundary information separately with an
> annotation that the boundary information depends on the constructed
> sheet and the constructed sheet depends on the individual frames and the
> program depends on the parser for the boundary information and the
> individual boundary information files and etc etc etc. It's not any
> harder (if not easier) to set up in Windows than Linux.
That might be. In Un*x it is simple a set of scripts and makefiles.
Something I understand. IME in windows it was often hard or impossible
to parse such script files. For some reason I quite often end up wanting
to automatically change them, but that may just be me.
Things might have changed a lot since then. What IDE are you using?
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Date: 23 Apr 2011 12:42:11
Message: <4db30163$1@news.povray.org>
Visual Studio 2010 at the moment. It's all XML files.
Indeed, I have a data processor that you can say "this file compiles with
the manifest processor", and each time you run the compile, the manifest
processor parses the makefile to figure out what files go into the final
build and sticks their names into a text file which it adds to the final
build. The sort of thing you'd normally use directory enumeration at runtime
to fetch, if you weren't sandboxed out of the directory access
functionality.  So I stick in a file with the name "manifest", say "compile
this with the manifest processor". The manifest processor gets compiled,
then runs and looks at the makefile, pulls out the list of dependencies
marked as "to be copied to the final distribution directory", and stores
that into the manifest file, which then gets copied into the destination
directory also (while leaving the manifest processor behind, mind).
The makefiles are all XML of dependencies and what commands to run, but
there are few if any dependencies in the makefile on actual files per se.
For each directory, there's a list of "these files should be compiled with
those compilers" and a list of "this entire project depends on that antire
project." It's mildly funky because before you can (conveniently) say
"compile manifest.txt with the manifest processor" you must have already
compiled the manifest processor once. Obviously that's an IDE limitation and
not a makefile limitation, tho, since you can delete all the results and
still do the recompile.
But most of the dependency analysis is done by the actual compiler as it
compiles. For example, if you say "I want a house model, and it depends on
the bricks texture and the wood texture", you don't put that information in
the makefile. You put that information in the house model. When the
processor processes the house model, it tells the build system that the
house model depends on the textures, so if you change a texture after you've
built the house, it rebuilds the house too. But you don't do that stuff
manually - that's just silly.
Date: 23 Apr 2011 13:59:16
Message: <4db31374$1@news.povray.org>
Oh, and if there's parameters specific to that compile (like, whether to
compress images or something), they're represented as properties with an
attribute set (basically, in the "javabean" kind of sense), and the build
system looks at the executable after it's built in order to give the GUI a
mechanism to prompt for which parameters need to be changed. It then records
those parameters into the build file again in XML, and passes them to the
processor when it recompiles anything in that dependency chain.
Overall, a very cool system. It just takes a bit of cooperation from the
compiler to make it all work seamlessly.
Date: 21 Jun 2011 06:40:56
Message: <4e007538$1@news.povray.org>
On 19/04/2011 10:31 AM, Invisible wrote:
> http://questionablecontent.net/view.php?comic=1144
Angus?
The Angus she eventually ended up hooking up with?
Oh, sorry - you guys don't care about that. I forget sometimes...
