POV-Ray : Newsgroups : povray.off-topic : Plug & play Server Time
16 Jan 2026 05:28:12 EST (-0500)
  Plug & play (Message 1 to 10 of 53)
Subject: Plug & play
Date: 4 Apr 2011 05:34:44
Message: <4d9990b4@news.povray.org>
What the user manual says:
"To expend the available recording capacity, simply purchase an external
USB harddrive or flash drive and connect it to the USB socket at the
back of the device."
What you actually have to do:
1. Purchase a USB HD.
2. Connect it to a computer running Linux.
3. Create a partition.
4. Format it with ext3.
5. Create at least one empty folder.
6. Connect it to the device.
Note, in particular, that if you do not possess a computer, then you
*cannot* expend the recording capacity of your device. Just back up and
think about that for a moment. We're talking about a set-top box for a
TV. You plug it into a power source, a TV and an aerial, and it lets you
watch digital TV. It also lets you record and play back TV. Now why IN
THE NAME OF GOD should you need to possess a computer just to upgrade
the storage capacity?
Seriously. You should be able to just plug in a HD and the device itself
should format it. Why the hell do you need a computer to do that?
Another thing. Technically you don't need to use Linux. The device
supports FAT16 and FAT32 as well. But apparently none of those go up to
the size necessary to make expansion worth the effort. Only ext3 seems
to support really big filesystems.
(Notice that's ext3. The device does not support ext2 or ext4. Only
ext3. Please get it right when formatting!)
Also, even if you format the drive, the set-top box still acts as if
it's read-only until you create at least one empty folder. At that
point, suddenly it works just fine. WTF?
Don't even get me started on the infelicities of *using* the external
storage.
1. Copying a file to the external HD allows you to keep watching TV, but
disables all controls. (E.g., you cannot change channel.) Mercifully
there's a cancel button. But cancel is the only operation you can
perform while the copy is in progress.
2. When you copy a file, it gives you a progress bar. When you copy
multiple files, it gives you a progress bar FOR THE CURRENT FILE. It
provides no indication whatsoever of overall progress. And when a large
copy operation takes several hours, that's a problem.
3. You cannot copy folders, only files. To copy a folder, you must
manually create the destination folder, open the source folder and
destination folder, select-all and copy. If a folder contains folders,
you must select-all and manually unselect any folders.
Still, what do you expect for several hundred pounds worth of hardware?
Oh, wait...
Subject: Re: Plug & play
Date: 4 Apr 2011 07:10:06
Message: <4d99a70e$1@news.povray.org>
> Oh, wait...
Benefits for the shareholders, what else ?
Date: 4 Apr 2011 07:18:25
Message: <4d99a901@news.povray.org>
>> Oh, wait...
Well, yeah. On the other hand, there are laws and things that require
that if you pay money for something, it actually *works*. Unfortunately
these laws do /not/ require that it works *well*...
The market theory is that if a device doesn't work very well, everybody
will buy a competing product instead. Except that, as far as I can tell,
almost all of these devices tend to be equally inept.
Date: 4 Apr 2011 08:43:17
Message: <4d99bce5$1@news.povray.org>
Maybe it wasn't possible to make a better one for that price and still
make a profit?
Date: 4 Apr 2011 10:25:43
Message: <4d99d4e7$1@news.povray.org>
> make a profit?
How hard would it be to add 3 lines of code to display the number of
files still to be copied? I mean, maybe it would actually be difficult
to add a second progress bar, I don't know, but I can't imagine adding a
little bit of text could be that hard.
There's already an option to reformat the internal HD. So why isn't
there one to format an external one? The necessary code obviously exists
already, so...?
Alternatively, if you actually need a PC, why not document this fact
correctly? If the drive has to have at least one empty folder on it,
document that too! (Weirdly, you can create and delete folders from the
device. You just can't until at least one empty folder exists, WTF?)
We're talking about tiny little changes that would have made a big
difference to how easy to use the product would have been. OK, making it
so that you can still change channel while a file copy is in progress
*might* actually be difficult. Most of the other stuff would have been
trivial.
Date: 4 Apr 2011 12:06:10
Message: <4d99ec72$1@news.povray.org>
It's all about priorities and deadlines.
   "Coding without comments is like
    driving without turn signals."
Date: 4 Apr 2011 20:14:04
Message: <4d9a5ecc@news.povray.org>
Sounds like Yahoo Small Business' "file manager". Stupid thing lets you
move/copy files up/down a level in the tree, but not "across", to
entirely other locations. And, you can't do shit with folders.
I seriously wonder, at times, what people are thinking when they do
stupid shit like this, then claim it "helps" you do anything. Luckily,
in my case, I was able to activate FTP, then make changes on my own
system. Maybe, in your case, you just boot a completely different OS,
make the changes/copies, then... lol
Date: 5 Apr 2011 04:01:23
Message: <4d9acc53@news.povray.org>
Indeed. And as usual, customer satisfaction is not a priority.
Date: 5 Apr 2011 06:03:58
Message: <4d9ae90e@news.povray.org>
> already, so...?
> trivial.
You'll probably find a lot of the code is just copied from an earlier
generation product (where HDs were much smaller), and the external drive
thing was a last minute add-on.  To go through a thorough a test, code
and test cycle would probably end up way more expensive than any
additional profits they could make over just shipping it "as-is" with
minimum modifications ("how can we make huge external drives work as
quickly as possible").
Don't forget these type of products sell for 12 months or so until the
next better one comes along, in a lot of cases it's much more profitable
to sell your product NOW with a few bugs rather than wait some time to
iron them out.  And in the end a company that makes amazing products but
no profit will not last very long.
Date: 5 Apr 2011 06:14:39
Message: <4d9aeb8f$1@news.povray.org>
It still bemuses me that they could go to all the trouble of writing a
huge, complex USB driver, and yet not bother to add 3 lines of code to
display a file count.
As the manufacturer, this is probably true. As the consumer, we've
bought this thing and we're probably going to use it for at least 10
years, if not longer. So the minor glitches that the manufacturer didn't
bother to iron out in their rush to market are extremely annoying, and
they're going to annoy us for the next 10 years.
> iron them out.
Reminds me of my PC motherboard. Splashed across the [very shiny] box is
something about RAID support and dual-BIOS support. You know what? The
product in the box doesn't actually possess either of these features.
(!!) But about a year later, Gigabyte released a BIOS update that makes
these features work as advertised.
(I especially love that you have to bypass the dual-BIOS in order to
make the dual-BIOS work...)
I would pay serious money to obtain hardware and software which isn't
infuriatingly awkward to use. But unfortunately, that doesn't appear to
be an option. Nobody makes it.
What, fundamentally, can we do about this? How can we make it
unprofitable to produce poor quality products?
