POV-Ray : Newsgroups : povray.off-topic : Very interesting color resolution examples Server Time
21 Jun 2026 16:08:24 EDT (-0400)
  Very interesting color resolution examples (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Very interesting color resolution examples
Date: 26 Apr 2009 18:20:23
Message: <49f4de27@news.povray.org>
"nemesis" <nam### [at] nospam-gmailcom> wrote in message
news:49f4d70d@news.povray.org...
> >> Would that still hold true in a blue-shaded scene? :P
> > http://nfggames.com/games/ntsc/traci_blue3.png
> Funny, but you know that's just a component.
It may be a component, but it also is an _image_ with only blues...
Date: 27 Apr 2009 02:37:54
Message: <49f552c2@news.povray.org>
> http://nfggames.com/games/ntsc/visual.shtm
> Summary: You really don't see blue very well.
I wonder if it is more that you don't see *colour* very well compared to
brightness, not blue compared to green?  It just so happens that the green
channel carries almost all of the brightness information compared to blue.
To test this out you could split into Yuv colour space (or similar) and
reduce the resolution of the u and v channels, I suspect then you could get
away with compressing green colours just as much as blue ones, so long as
the Y (brightness) channel remained at the original quality.
Date: 27 Apr 2009 07:20:00
Message: <web.49f594358b0909c76dd25f0b0@news.povray.org>
I remember once seeing the sun's power spectrum compared to the eye's response
spectrum, possibly at uni. The eye's spectrum follows the sun's very closely -
not suprising considering we evolved under its glare. This of course means that
we are far more sensitive to green light than red or blue, which are at the far
extremes of the visible range. I can't seem to find any refs for this
comparison, but there is a phototopic luminosity function on w'pedia:
http://en.wikipedia.org/wiki/Luminosity_function
....so this probably isn't cutting-edge news... still interesting to see it
demonstrated this way though.
Date: 27 Apr 2009 08:32:11
Message: <49f5a5cb$1@news.povray.org>
And hence is much much darker than an image with only greens.
Try adjusting the brightness of the green one to match the blue (I found
multiplying by 0.3 did it here), then compare side-by-side, now there's not
so much visible difference...
Date: 27 Apr 2009 16:48:25
Message: <49f61a19@news.povray.org>
Gee, do you think this could be somehow related to the fact that only 7%
of the light receptors in your eye are tuned to blue?
Actually, you know what? Screw that... Where can I find this "Traci"??
http://blog.orphi.me.uk/
Date: 28 Apr 2009 00:20:01
Message: <web.49f683368b0909c7f50167bc0@news.povray.org>
Just pondering that evolutionary adaptation is fascinating. I wonder if it came
about from the fact that we descended from tree-or-forest-dwelling animals,
where the predominant color was green? Not that the *entire* earth was
forested, but a good portion of it.  Does it also mean that we humans can now
see subtle gradations of green better than subtle gradations of red or blue?
KW
Date: 28 Apr 2009 04:37:18
Message: <49f6c03e$1@news.povray.org>
The question is... why are leaves green in the first place? Wouldn't
they work so much better if they were black??
Date: 28 Apr 2009 04:57:08
Message: <49f6c4e4$1@news.povray.org>
http://www.sciam.com/article.cfm?id=evolution-of-primate-color-vision
Might be of interest...
Date: 28 Apr 2009 07:31:26
Message: <49f6e90e$1@news.povray.org>
I think it's a given that if the list of links at the bottom had one to
more pix of Traci, that link would get the lion's share of the hits.
John
Date: 28 Apr 2009 10:35:53
Message: <49f71448@news.povray.org>
Kenneth <kdw### [at] earthlinknet> wrote:
> [-- text/plain, encoding 8bit, charset: iso-8859-1, 17 lines --]
  No, it's because of the surface temperature of the Sun. Both leaves and
best vision is at the green amplitude for a common reason.
