POV-Ray : Newsgroups : povray.off-topic : Woo, GPU! Server Time
22 Jun 2026 00:47:26 EDT (-0400)
  Woo, GPU! (Message 52 to 61 of 71)
Subject: Re: Woo, mass breakage
Date: 30 Jan 2009 06:16:17
Message: <4982e181$1@news.povray.org>
scott wrote:
>>> Now *all* I have to do is figure out how to put NTLDR and friends
>>> back onto the drive using the recovery console and my PC will be
>>> usable again... o_O
> How did you manage to mess that up by simply replacing a graphics card?!?!
Read again, carefully: I haven't even changed the graphics card yet. All
I've actually done is move some hardware around so that there's a big
enough space to insert the card.
The reason Windoze is upset is because I removed HD 0. (For reasons
beyond my comprehension, M$ insists that the boot files must always be
on HD 0, even if the OS itself isn't.) So I need to put the boot files
onto the drive that has now become HD 0. Unfortunately the documentation
for this isn't that easy to find, but I believe I know how to fix this now.
Subject: Re: Woo, GPU!
Date: 30 Jan 2009 06:17:39
Message: <4982e1d3$1@news.povray.org>
Orchid XP v8 wrote:
> "Powering your XFX graphics card"
> "XFX does not support the use of two 4-pin to one 6-pin power cable
> converter for these graphics cards."
> So, uh, why did you supply just such a converter IN THE BOX WITH THE
> CARD???
> Is it just me?! o_O
Seriously - I'm still bemused by this one... :-?
Date: 30 Jan 2009 06:31:29
Message: <4982e511$1@news.povray.org>
>> Luckily those are not very expensive.
> Well, that's the main thing, yes. ;-)
> (Otherwise, right now you'd see my sitting in the corner crying.)
...or rather, "300W PSUs are not very expensive". Typically you can buy
Unfortunately, I need a minimum of 500W (and the "recommended" is 630W,
and if you ever go to SLI that becomes 680W). PSUs in that sort of range
plugs or something daft.)
I'm thinking... if I'm going to actually spend real money on getting a
bigger PSU, I might as well spent a little bit more on one that can do
the job *properly*. (I.e., one with enough connectors, and a decent
Wattage.)
Date: 30 Jan 2009 06:58:13
Message: <4982eb55$1@news.povray.org>
I'm thinking just buy 2x 300W ones for 12 pounds :-)
Date: 30 Jan 2009 07:02:24
Message: <4982ec50$1@news.povray.org>
>> 630W, and if you ever go to SLI that becomes 680W). PSUs in that sort
Mmm, yes... One PSU to power my PC, and the second one to power my GPU!! :-D
I'm not really sure how the case arrangements for that work out though.
(Notice that the recommended power is 630W, so 2x300W would still be
insufficient. However, I think my current PSU might be 400W, so...)
Anyway, it seems that if you want 700W *and* two 6-pin PCIe connectors,
you're talking about quite a lot of money. But if you settle for 650W,
you can find it quite a bit cheaper. I'm thinking I might go for this:
http://www.ebuyer.com/product/151295
It exceeds the recommended Wattage, it has two seperate PCIe connectors,
and it has enough other connectors to run the rest of my stuff. (It's
Date: 30 Jan 2009 13:03:39
Message: <498340fb$1@news.povray.org>
> one of those for about £6, or anything upwards.
Like everything, the exceptionally cheap ones are crap and will die, ofte
n
taking out other parts, in a year or so. Spend the extra and get the good
 one.
> (Occasionally you will see *one* model at £20 or so,
And it'll either be a piece of crap or specialized for a particular produ
ct
line.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 30 Jan 2009 13:08:48
Message: <49834230$1@news.povray.org>
Invisible wrote:
> Hopefully at this point the system should become bootable again.
You might need to use mbrfix (or is it fixmbr?)
Or use diskpart to make the partition active, I think. It's been a while
since I tried to fix an XP partition.
   "Ouch ouch ouch!"
Date: 30 Jan 2009 14:09:07
Message: <49835053$1@news.povray.org>
>> buy one of those for about £6, or anything upwards.
> often taking out other parts, in a year or so. Spend the extra and get
> the good one.
Yeah, if I buy I PSU, I tend to not buy *the* cheapest one. I like to
buy one that's a little more. Not too much, but just so that it's not
the £6 model. Maybe £15 or something?
I'm like that with a lot of things though. I tend to avoid *the*
cheapest one, and go for one a few notches higher up.
OTOH, when looking at something like CPUs, I tend to not go for *the*
most powerful one, because typically it's 8x the price for 8% more
performance. ;-)
http://blog.orphi.me.uk/
Date: 30 Jan 2009 14:10:22
Message: <4983509e@news.povray.org>
Yes. Actually I already did this from KNOPPIX. Just marking the
partition as "bootable" seemed to be enough to get me to the "CAN'T FIND
NTLDR" message. But I found the corresponding commands (it *is* fixmbr
and fixboot BTW) in the Recovery Console also.
Subject: Re: Woo, normality!
Date: 30 Jan 2009 14:13:37
Message: <49835161$1@news.povray.org>
Invisible wrote:
> - Build a new BOOT.INI file: bootcfg /all
> - This last command spends a few hours scanning all your HDs looking for
> anything that looks like a Windows installation. It then gives you an
> interactive prompt asking which ones to add to the boot menu.
Actually, that's "bootcfg /add" or /rebuild.
And, for whatever reason, it doesn't work. After a while it crashes out
with an error message about an unreadable filesystem or something.
Interestingly, it seems that placing NTLDR and NTDETECT.COM onto the
drive is sufficient to make it boot. When you boot the system, it says
"INVALID BOOT.INI; BOOTING FROM C:\WINDOWS". I'm guessing this only
works for certain cases. Since by Windows installation is your standard
"the OS is in the standard place on the first HD", it Just Works(tm).
Weirdly, once Windows has loaded there is apparently no way to recreate
a correct BOOT.INI file. However, cut-and-pasting the example one from
M$'s website seems to have fixed things nicely.
Wee, my PC works again! :-D
