POV-Ray : Newsgroups : povray.off-topic : Compiling stuff Server Time
3 Jul 2026 06:48:36 EDT (-0400)
  Compiling stuff (Message 91 to 100 of 283)
Subject: Re: Compiling stuff
Date: 11 Dec 2008 16:46:02
Message: <49418a1a$1@news.povray.org>
On Thu, 11 Dec 2008 18:12:32 +0000, Orchid XP v8 wrote:
>>> I meant there are no Linux drivers for high-end hardware like
>>> expensive graphics cards. Clearly there *are* Linux drivers for lots
>>> of other things.
>> No Linux drivers for what high-end expensive graphics cards, exactly?
> I didn't say "no", I said "few". And I was making a generalisation.
And a generalization that at least in the X world is not accurate.  Just
because it's a generalization doesn't mean it's correct.
>> Most of those are now Nvidia or ATI IIRC, and there are Linux drivers
>> that support the majority of those cards, even with 3D (though you
>> often have to go to a proprietary kernel module for it).  I use both
>> the ATI and Nvidia drivers, so it's not exactly accurate to say that
>> those cards don't work well with Linux.
> Things have improved since 2006 then. ;-) I wasted a whole day trying to
> get the nVidia drivers to work...
2006 is about 4 generations ago for openSUSE.  Yeah, things have changed
since then.  The ATI drivers used to be a royal pain the ass to install
and configure.  Not anymore.
> (Of course, a few months later I upgraded my graphics card, making my
> Linux partition non-bootable. That was roughly when I decided to just
> not bother fixing it.)
Probably rebuilding the kernel?  Otherwise, I can't see how a graphics
card change would affect the hard drive at all.
>>> And by "a few" I meant more games and applications rather than
>>> drivers.
>> There's quite a large selection of software.  It may not be WoW, but
>> it's out there.
> Sure. And it'll probably continue to get larger over time. But right
> now, it's still fairly modest by comparison.
You must be looking at different places than I.  Go have a look at
sourceforge.net, freshmeat.net, and at the repository list for openSUSE
at the number of packages available.  There's TONS of software for Linux.
Then add to that Windows apps that work with WINE (and that is growing
significantly every month).  Now go find a Linux binary application that
runs on Windows without something like Cygwin.
Now tell me again that you have more choice on Windows than on Linux.
Jim
Date: 11 Dec 2008 17:09:18
Message: <49418f8e@news.povray.org>
>> No accelerated Linux drivers for almost any graphics card.
>> ...I mean for DirectFB, not X :D
> I don't know that that's a true statement, but I don't use DirectFB on my
> systems. :-)
In practice, I think DirectFB it's only used by embedded developers, and by
the people working on DirectFB itself :)
Date: 11 Dec 2008 17:35:15
Message: <494195a3$1@news.povray.org>
Actually is was (IIRC) Debian at the time, but whatever. ;-)
All I remember is that even after endless fiddling, I couldn't get 3D
acceleration to work. (Actually producing a picture didn't require any
special attention at all.)
OK, to be completely clear: It booted, but X wouldn't run.
Most of which is only marginally functional.
Don't get me wrong, there *is* some seriously quality software out
there. But there's also a lot of stuff that doesn't work very well.
(E.g., klogic. It does almost exactly what I want. But it doesn't *work*
properly. It randomly segfaults, and sometimes it GIVES YOU THE WRONG
ANSWER. It's also fiddly to use for no good reason.)
Anyway, how much *commercial* software (such as big-budget games) are
there for Linux?
It's news to me that *anything* works under WINE yet. (But then,
admittedly it's not something I follow closely. If I want to run Windows
software, I just run Windows...)
Most of the software *I* want runs only under Windows. Not all of it
(there are some notable exceptions), but most of it.
Of course, it depends what you're trying to do with your PC...
http://blog.orphi.me.uk/
Date: 11 Dec 2008 18:00:06
Message: <49419b76$1@news.povray.org>
Most of the utilities are ported to native Windows. The appropriate google
term is to tack "win32" onto whatever you're searching for:
gunzip win32
diff win32
... and so on.
Just in case you ever go looking.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Date: 12 Dec 2008 04:00:49
Message: <49422841$1@news.povray.org>
>> I saw an interesting project where people were figuring out what steps
>> you could cut out of a Linux boot for known hardware (like a laptop) to
>> get it to boot all the way to logged in under X in less than five
>> seconds. They apparently got it working, too.
> And why shouldn't it boot in 5 seconds flat? Damnit! >_<
I always put my XP laptop to sleep rather than turning it off, from hitting
the power button to windows unlock prompt is always under 5 seconds - it
would drive me mad if I had to shut it down and boot it up from cold each
time I used it.
Date: 12 Dec 2008 04:19:03
Message: <49422c87$1@news.povray.org>
> hitting the power button to windows unlock prompt is always under 5
> seconds - it would drive me mad if I had to shut it down and boot it up
> from cold each time I used it.
Doesn't that mean that after X hours the battery runs flat and you need
to cold boot it anyway?
(I guess it depends on exactly which "sleep mode" you mean...)
Date: 12 Dec 2008 04:38:23
Message: <4942310f$1@news.povray.org>
scott wrote:
> ...it would drive me mad if I had to shut it down and boot it up
No it wouldn't if it took only less than 5 seconds. And with SSD and
proper kernel config and INIT config it is very possible.
Date: 12 Dec 2008 04:44:37
Message: <49423285$1@news.povray.org>
>> Now go find a Linux binary application that runs on Windows without
> google term is to tack "win32" onto whatever you're searching for:
> gunzip win32
> diff win32
> ... and so on.
The fun thing is, usually there are several versions to choose from.
Some of them require a Cygwin DLL, some of them don't. Some of them
understand Windows pathnames. Some of them don't. Some have been simply
recompiled, some have been extensively modified. And so on.
Date: 12 Dec 2008 04:50:22
Message: <494233de$1@news.povray.org>
> Doesn't that mean that after X hours the battery runs flat and you need to
X is a very large number though, even after a weekend in standby the battery
is still at 90-something %.
Start -> Shutdown -> Standby
AIUI it just supplies enough power to the RAM to keep its contents
refreshed, everything else is turned off.
Date: 12 Dec 2008 04:51:19
Message: <49423417$1@news.povray.org>
Man, it takes longer than that to just get through the BIOS before it gets
anywhere near an OS!
