>> Actually, when I want to compile something, I usually just say "make
>> foo". Otherwise GCC insists on naming it "a.out", which is very irritating.
> If you don't specify an executable name, how can gcc guess what is it
> that you want? Note that you can write something like:
> g++ file1.cc file2.cc file3.cc
Now there's interesting. I didn't know you could actually compile
multiple source files together; I was under the impression that in that
case, you must manually invoke g++ several times, and then manually
invoke ld to produce the final binary. (Or, more likely, write a
makefile that does that.)
> C++ inherits many things from C, good and bad.
Apparently so. ;-)
[I'm currently compiling a list...]
>> So there *is* a way to automate dependency analysis?
> The -MM option of gcc (which I use in that generic makefile I attached)
> auto-generates makefile dependencies for all the specified source
> files. Makefiles themselves (at least with gnu make) are so versatile
> that this can be used to completely automatize dependency building.
Well, that's a step up from manually writing a makefile, writing it
wrong, and producing a binary that segfaults because it's built from
incompatible object files...
>> This whole concept of having to manually write makefiles and manually
>> write header files and so forth just seems tedious and error-prone.
> You don't need to manually write makefiles. Just use a generic one.
Has anybody come up with a tool for autogenerating header files yet?
(Presumably you'd need to edit such a file to remove references to
things that aren't meant to be public, but at least the function names
and signatures would match.)
http://blog.orphi.me.uk/
Orchid XP v8 <voi### [at] dev null> wrote:
> I really can't figure out what everybody finds so confusing about
> Haskell. Is it just that it uses different syntax to other "common"
> programming languages? (E.g., no curly braces, no function call
> brackets.) Or is it something deeper?
There are many things. For example, in what seems to be a common
Haskell style of brevity, the lack of clear delimiters is confusing.
Often everything you see in a line of haskell code looks like this:
a b c . d e f . g h
and there's no way of visually telling what they are. The role of each
element may be wildly different, and from a layman's point of view,
completely arbitrary. It's often even hard to see where a command or
definition or whatever *ends* and where a new one starts. The lack of
clear delimiters makes it very confusing.
If it had some clear delimiters, it *might* become a bit easier to grasp
what exactly is going on. For example something like this is much easier
to start thinking about:
a { b(c, d, e); f(g, h); }
Even without knowing what is a keyword and what is a type or function
name, it's already much easier to even try to understand how the code
is structured, and what might be being executed before what else.
For example let's take these lines:
"+" -> binary (+) stack
"-" -> binary (-) stack
There's no ending delimiter for those commands. The only way we could
deduce where the commands are supposed to end is by trying to deduce
from the lines being similar. If you had used whitespace completely
differently, it would become very confusing, for example:
"+" -> binary
(+) stack "-"
-> binary
(-) stack
I don't know if that's still valid, but I assume it is. Now it's very
hard for a layman to understand what is going on. And the only thing I did
was to add a few newlines and spaces, nothing more. It became an almost
incomprehensible blob of code, with no clear blocks, command ends or
overall structure.
Moreover, in Haskell, from a layman's point of view, you are not even
guaranteed that you can read from left-to-right and get a concept of how
the code is being executed. Sometimes code is executed left-to-right,
sometimes right-to-left, sometimes in a wilder order, and seemingly very
arbitrarily. It becomes very hard to follow what is going on there.
I suppose there are programs which can be used for that. However,
it's very difficult for the program to tell what is it that belongs
to the public interface of the module and what isn't.
You don't want to add *everything* to a header file. You only want
to add the *minimal* public interface which is necessary to use the
module, no more.
If you had to annotate in your source file what goes to the header and
what doesn't, you might as well just write the header file yourself with
the same effort.
Yes, it seems that such a file would need to be edited by hand afterwards...
If I'm understanding this right, C++ at least tells you if your
function's signature doesn't match what's declared in the header file.
OK, now I see where you're coming from.
In the case alternatives, the line end *is* the delimiter. So if you
were to "change only the spacing" then you could actually CHANGE THE
MEANING of the program! (In fact, likely, cause it to no longer
compile.) This is different from "curly bracket languages" where you use
"{", "}" to delimit blocks, and ";" as a seperator. In Haskell,
generally a newline is a seperator, and indentation delimits blocks.
So, this works:
case foo of
1 -> bar1
2 -> bar2
3 -> bar3
If the expressions are a bit bigger, you can say
case foo of
1 ->
very_long_thing_1
2 ->
very_long_thing_2
3 ->
very_long_thing_3
And if they're really long, you can say
case foo of
1 ->
multiline1
multiline2
multiline3
2 ->
another_block_1
another_block_2
3 ->
yet_another_block
or some such. The case expression itself ends when we get to something
less indented.
I presume it goes without saying that if you nest things too deeply,
they end up scrolling off the right edge of the screen and/or becoming
rather hard to visually untangle. Don't do that! But for the post part,
it's like a normal curly-bracket language, but without the actual
brackets. (It's normal practise to indent things anyway.)
Expression execution order is more complicated. First, you can say
fn3 (fn2 (fn1 x))
which does... what you'd think it does. It calls the function fn1, and
then passes its result to fn2, and finally passes that to fn3. You can
also write
fn3 $ fn2 $ fn1 $ x
which does exactly the same thing, but doesn't require you to match up
the right number of brackets at the other end. Subtley different, you can do
fn3 . fn2 . fn1
which yields a *function* that will do the same thing as the above,
*when* you actually give it an argument. (Notice there's no "x" here.
That's deliberate. This doesn't produce a result, it produces a
function.) So
(fn3 . fn2 . fn1) x
would be a needlessly wordy way to do the same thing as the previous two
examples.
(As an aside, it should now be clear why the functions are listed
"backwards". If you take a look at the very first expression, this is
almost valid C or C++.)
I guess uttering
mapM_ (\(n,v) -> putStrLn $ "[" ++ show n ++ "]: " ++ show v) (zip
[0..] stack)
*is* pretty crazy. (It doesn't even fit on one line, for example.) But
other than that, it should be *reasonably* clear that main_loop does...
whatever the hell that line does, then it does (putStr "Calc> "), then
it does (cmd <- getLine), and then it does that case expression.
If you've been paying attention, you may have spotted that the very last
line of the program *does* in fact have some delimiters:
_ -> do putStrLn "Stack underflow."; main_loop stack
Haskell does in fact permit you to use curly brackets and semicolons if
you want to. It's just that most programmers don't. (And, in an amusing
twist, curly brackets are also used for something completely unrelated
as well, so it's probably best to _only_ use them for that. Less
confusing that way...)
Warp wrote:
>> If you DO want to read a whole line, look up the getline function. That
>> will also take in an "empty" line.
> The problem with getline() is precisely that it reads an entire line.
> If there are several whitespace-separated things in that line, it will
> still read the entire line.
Which is not a problem if that's what you want to do.
I use getline to simulate a pause, where the user has to press Enter to
continue (there's another function for just reading a character - I
forget what it was).
Copywight 1991 Elmer Fudd. All wights wesewved
/ \/ \ u e e n / \/ a w a z
>>>>>>mue### [at] nawaz org<<<<<<
anl
> a b c . d e f . g h
Yeah. I find this is where I have big stumbling blocks reading both
Haskell and ML.
Of course, part of the reason for that is that there really isn't a
clear separation between functions and "values". You can't really say
something like Erlang says, where function names start with lower case
and variable start with upper case. Maybe if there was a heirarchy of
alphabets/fonts like in math, you could see that (for example) "binary"
needs to take an operator because it's in bold, or some such.
I think Haskell is line oriented. Commands end at the end of lines.
Since I use a lot (relatively speaking) of languages like this, that's
not what's confusing. (Python, Tcl, most macro languages, etc.)
Or even if it executes at all. :-)
Yet, oddly enough, the most naive complaint about LISP is all the parens
that completely disambiguate evaluation, and about APL that the
evaluation order is strictly right to left without parens. :-)
That's basically what happens internally. I don't think it's like Java,
where putting multiple sources on the same line does things that
compiling them separately can't. (For example, putting multiple sources
on the same line is the only way to get Java to compile circular
dependencies between classes, last I looked.)
Yes. About 20 years ago. :-) It was editor macros in Teco (aka PMate).
Darren New wrote:
>> a b c . d e f . g h
> Haskell and ML.
I have a similar issue with stuff like
while (*x++ = *y++) {}
Apparently that means "deference y, fetch the result, incriment y,
deference x, store the result there, incriment x". For no particular
reason other than the specific operator precidences of C.
Similarly, to parse a Haskell expression, note that brackets rule first,
then the (.) or ($) operator. (You'd have to be mad to mix the two
together without some brackets first.) No reason, that's just the
operator precidence rules.
Meaning you can write a function that takes a function and returns a
function which accepts another function which will return a function
that takes an integer and returns a Boolean. Or similar. Which, even
I'll admit, is pretty crazy.
Indeed. (Though strictly Haskell doesn't have "commands", it has
expressions.) More exactly, blocks of stuff indented by the same amount
parse as if they were enclosed in {} (which you can manually do, if it
makes you feel better). Otherwise, expressions end at the end of the line.
Well, notionally you can ignore lazy execution while figuring out the
meaning of the statement, and *then* consider how (if at all) laziness
affects it afterwards.
One of the most common things beginner Haskell programmers do is add
vast numbers of brackets. ;-) Trust me, beyong a certain point it
hinders rather than helps.
I think the fact that tuples use regular brackets is rather unhelpful
here. There's a very subtle visual difference between (sin(x) + sin(y))
and (sin(x), sin(y)), but their meanings are quite different. It might
have been better if we had <sin(x), sin(y)> or something, like POV-Ray
does...
When I looked, Sun's javac chokes on circular depends, but M$
VisualStudio J++ doesn't blink an eyelid. It just compiles.
This was a *long* time ago tho... Maybe Sun have fixed their compiler now?
(Before I get too smug, I gather GHC also doesn't like circular depends
either. But then, in Haskell, module bounderies are arbitrary and the
programmer can choose them. In Java, a class goes in a file, and you
can't just move stuff from class to class at will. Not if you want your
design to make sense anyway!)
What happens if the expression is very long? For example, a function
could take a large amount of parameters, all of which are long expressions
using long variable names.
I think I'm starting to understand *why* Haskell people prefer using
short and cryptic variable names rather than long and clear ones: If they
did the latter, they would run out of space in their limited lines... :P
Put each argument on a seperate line, indented further than the function
name.
foo
arg1
arg2
arg3
Heh. Haskell programs *do* tend to end up with pretty long lines, that's
for sure. ;-)
I don't know. In Tcl, you put a backslash at the end of the line. Just
like bash or anything else.
>> expressions
> name.
Or... make them local variables.
(That's more usually done if a certain subexpression is needed more than
once - since, obviously, putting it in a variable makes it only evaluate
once. But you can also use it to break things up - especially if what
you're doing is complicated.)
let
thing1 = ...
thing2 = ...
thing3 = ...
in foo thing1 thing2 thing3
Notice that, unlike in "normal" languages, let is an *expression*, but a
*statement*, so it is valid absolutely anywhere an expression is valid.
That includes absurd constructions like
(let x = 5 in x) + (let y = 2 in y)
which just means "5 + 2".
Nicolas Alvarez wrote:
> I understand the C++ one and the Haskell one looks like line noise.
OK, well how about this:
module Main where
import System.Random
main = do
target <- randomRIO (1, 100)
guess target
guess target = do
putStr "Guess: "
txt <- getLine
let number = read txt :: Int
case compare number target of
LT -> do putStrLn "Too low."; guess target
GT -> do putStrLn "Too high."; guess target
EQ -> do putStrLn "You win!"
Does that look like line noise to you? Or can you figure out what that does?
I think this line illustrates well what I wrote earlier. Just a list
of whitespace-sepaated words. No delimiters, no hints about what might be
a reserved keyword, what might be a variable, what might be a function.
I'm no at all sure how that should be parsed. Could it, perhaps, be
something like:
case(compare(number, target)) of
What would be wrong with a syntax like that?
All the functions in Haskell are curried. So it's really
case (compare(number)(target)) of ...
But yes, this is exactly the kind of thing I have trouble with too, in
these sorts of languages. Especially when it gets a little more complex
and you get stuff like
case bump . hither $ yo stuff of ...
or when people start writing binary functions that take values on both
the left and the right (in SML, not Haskell) and giving them names like
"o", with functions returning other functions composed by "o", which was
apparently not unlike the "." in Haskell.
this o that value
OK, so what's the precidence on that in ML? Yarg.
why would want you distinguish reserved words, variables and functions?
In C(++) they might be implemented quite differently, that does not mean
however that are fundamentally different on a conceptual level. Haskell
apparently does not make such arbitrary and implementation driven
distinctions. I think we can only applaud that.
Orchid XP v8 a écrit :
> putStr "Guess: "
> does?
Honestly just from the strings that are being printed one can guess what
this program is meant to be doing... Should be true of any language.
Well one where the strings do not have to be somehow encoded of course ;-)
Vincent
I'm pretty sure "reserved words" are conceptually quite different from
variables, yes. Unless you're talking about an extensible language like
LISP or FORTH or Tcl, the reserved words let you do things that you
can't do with functions and variables, and vice versa.
Knowing what's an argument and what's a function is also pretty
important for understanding how a given line of code works. If you can't
look at the code and figure out which function bodies get evaluated, it
makes it really rough to work out what's going on, even in a functional
language.
> module Main where
> main = do
> guess target
> guess target = do
> putStr "Guess: "
> txt <- getLine
Now you'll have to implement the same program in C++. ;)
>> What compiler are you using?
> GCC, on Linux, running under QEMU. (Because it's what I have to hand.)
Huh. Crazy that it wouldn't give at least a warning for that. Maybe there's
a switch to give more picky warnings?
- Slime
[ http://www.slimeland.com/ ]
FYI, I have an issue with stuff like that too. C and C++ do make it easy to
write bad code. This is the second time you've mentioned that example, so I
assume someone once showed it to you and thought they were being clever.
They weren't! Or maybe it's just a popular example, because I was just
reading a book about coding style last night that gave that as a bad
example.
That code tries to do too much at once and is difficult to understand. If
you made a small mistake while writing it, it wouldn't be immediately
obvious that there's a problem with the logic. It's bad code. Its only use
is to help you understand operator precedence and the behavior of the
different operators. It's very possible to write code that does the same
thing in a clearer way.
C and C++ just require responsibility. =)
- Slime
> To me, all that tricky slight of hand with "break" and "continue" seems
> far less clear then just directly saying exactly what you want to happen,
> as the Haskell version does.
You can eliminate the "continue" in your example if you write it like this:
if ( cmd == "^" )
break;
else if ( cmd == "+" )
Add(stack);
else if ( cmd == "-" )
Sub(stack);
else
stack.push_back(1);
As for the break, it could just as easily be a 'return' like in the haskell
code, if you didn't want to print "exit" or if you brought the loop into its
own function.
- Slime
>> mean however that are fundamentally different on a conceptual level.
> variables, yes.
Indeed, but only if you assume you have a language that makes that
distinction. It is not a concept that is inherently a part of any
language. Maths does not have 'reserved words'. I.e. for the casual
observer things like '=' and '+' looks as though they are universally
defined and understood the same way. In practice even these are
sometimes redefined to suit a specific field or application in a way
that may even go deeper than overloading. Many operators are also
'reserved words' in certain subfields and not existent in others. If you
want to model a language on the way mathematics is used, defining
'reserved words' is something you might want to leave out.
I think that FORTH introduced me to the idea that it makes sense to
introduce user level control flow mechanisms.
Again absolutely true, for a imperative language. In lambda calculus and
any functional language derived from that this distinction make no sense
at all.
> If you can't
> language.
I don't think so. If you have an entity called current_temperature it
should not matter if that is derived by looking at a specific memory
location (a variable), by looking at an index in a circular buffer
(array) or by doing something more complicated like calling a function
of generating an interrupt. OK, it does matter sometimes but only in an
implementation. It should not have any influence on understanding the
code conceptually.
I think you understood that my mean reason for my response was that Warp
is looking with imperative spectacles to lines of code in a functional
language and desperately trying to force it into his own mindframe. Then
again, he might just be pulling Andy's legs. I know he does that
sometimes and I have not followed the entire thread.
Yeah. -Wall. Apparently.
Yes. That'll be harder, of course - I don't know the standard library
for C++ inside-out yet. ;-)
I know you probably won't care, but take a look at this:
http://haskell.org/hoogle/
Now, suppose I want a function that takes a String and turns it into an
Integer. If you type in
String -> Integer
and hit the search button, the very first result is
Prelude.read :: (Read a) => String -> a
(base)
Which tells you that the "Prelude" module (implicitly imported by all
Haskell modules) contains a function named "read", which will transform
a String into any type "a" that is a memory of the "Read" class. (And it
turns out that *all* the basic types are members of this class.)
Similarly, suppose I want to, say, discover whether a given list
contains a specified element. Well, the function that does that is
obviously going to take two arguments - a list, and a thing to find.
Slightly less obviously, you can only do this for types that can be
compared. In Haskell, that means types that belong to the
cryptically-named "Eq" class. So we have
(Eq x) => [x] -> x -> Bool
A quick search, and we get
Prelude.elem :: (Eq a) => a -> [a] -> Bool
(base)
Notice how the arguments are actually the other way round, but the
search still found the function. (You can also search by name - useful
if you find yourself asking something like "dude, WTF is 'nub' supposed
to be?!")
You might not care about Haskell, but you gotta admit all of this is
pretty neat, eh?
Now, the question is... is there a similar resource for C++? Because for
starters, the first thing I'm gonna want to know is how to choose a
random number in C++. ;-) (Altough I dare say for *that*, a simple
Google search will probably answer...)
Fair point.
The following are reserved keywords in Haskell:
module, where, import, qualified, hiding, as, case, of, let, in,
data, type, newtype, class, instance, deriving, do
I'm pretty sure that's the complete list. I count 17 reserved words. (A
quick Google search indicates that C++ has roughly 90 of 'em.) If you
see any of these words, it's a keyword.
(It's actually kinda irritating that "in" and "as" are keywords; these
would make convinient variable names from time to time, e.g., handles
named "in" and "out". But, alas, no...)
> something like:
You can write
case (compare number target) of
if you prefer. This is completely valid syntax.
Now, if it was pretty-printed like THIS:
http://hpaste.org/10565
you wouldn't be as confused. (?) If you have some kind of text editor
with syntax-hilighting, this isn't an issue. (I don't know anything
about Emacs, but I imagine it can't be hard to program it so that just
the 17 words above print in a different colour...)
As for why functions aren't called like foo(x, y, z) like in C... that's
due to function currying. In Haskell, you say "foo x y z" because then
you can write "foo x y" to mean a function that just accepts "z". (Or
just "foo x" for one that accepts "y" and "z", or "foo" for the function
itself, or whatever.)
Note that you *can* write foo (x, y, z) in Haskell, because "(x, y, z)"
is what Haskell calls a "tuple". This has a different type though. (It's
like the difference between calling a C++ function with an array verses
a vector. Same concept, different implementation - and type.) This is a
so-called "uncurried function", and they aren't used much.
Well, you'd hope so, yes... ;-)
> module, where, import, qualified, hiding, as, case, of, let, in, data,
WRONG! It's actually 21. I forget if/then/else, and apparently "default"
is a keyword...? (Ah, yes. The Haskell '98 Language Report explains that
this very obscure keyword is for adjusting the type defaulting
mechanism. As if you'd want to...)
Apparently it's already been done. (SUPRISE!)
http://www.iro.umontreal.ca/~monnier/elisp/#haskell-mode
> Uh-huh, and let me guess: You already know how to read and write C++
> fluently, but you know nothing about Haskell yet? :-P
Correct.
> Seriously, I am constantly baffled by statements like this.
But you used to say the same in the opposite direction. "That C++ looks SO
unreadable, yet I fully understand this mess of a haskell program".
> So, this works:
> case foo of
> 1 -> bar1
> 2 -> bar2
> 3 -> bar3
> case foo of
> 1 ->
> very_long_thing_1
> 2 ->
> very_long_thing_2
> 3 ->
> very_long_thing_3
> case foo of
> 1 ->
> multiline1
> multiline2
> multiline3
> 2 ->
> another_block_1
> another_block_2
> 3 ->
> yet_another_block
> less indented.
Just like Python, then :)
> does?
Looks understandable, but what the hell does 'guess' do??
> Because for starters, the first thing I'm gonna want to know is how to
> choose a random number in C++. ;-)
C++ itself doesn't have a random number library (something which will
be fixed in the next C++ standard), but <cstdlib> does have a rand()
function. Rather unusually for a C function, the usage of rand() is
simple and safe: You simply call it, and it returns a random integer
value between 0 and RAND_MAX.
A simple way of getting a value so that 0 <= value < n, is:
int value = std::rand() % n;
Of course it will always return the same values every time you run the
program. If you want it to return different values, you'll have to seed
it with a clock value. Again, no time functions in C++, but the C versions
are also unusually easy and safe to use (at least in this case). Include
<ctime> and then you can seed the rng at the beginning of your program:
std::srand(std::time(0));
And by the way, no, this will probably not work correctly:
int value = std::rand() * n / RAND_MAX;
> distinction.
That's what I said.
Correct. Except that given the programming language, reserved words are
fundamentally different from functions or variables. That's why they're
reserved.
Kind of like parens in math - once you decide you have a grouping
operator that's written ( ), you really can't use it to define functions
called ( and ).
The confusion, I think, is that you think maths doesn't have reserved
words. It does. They're just outside of the maths.
For example, the "summation function" is kind of the same as the for
loop: start variable and value below the sigma, stop value above the
sigma, expression to evaluate to the right of the sigma. The reserved
words, in this case, is the English sentence I just wrote describing the
functionality.
Unfortunately, to communicate with the computer about how a compiler
works, we need to speak something other than English. That's where the
reserved words come in. They're a way for the compiler writer to let the
compiler user communicate with the compiler. They are part of the syntax
of a language that is implicit in the rules for evaluating the
functions, just like (A^A)->C you can do a production to find that A->C
because of the rules of pattern matching and substitution. It's
virtually impossible (or even utterly impossible) to formalize the
productions you use in your formalization.
Granted. But Haskell doesn't model a language on the way mathematics is
used. It models a language on one particular mathematics. The reserved
words are a syntactic shortcut for a much larger lambda expression, just
like "193" is a syntactic shortcut for a big long string of bits in a
turing machine.
> at all.
Except that Haskell is obviously beyond lambda calculus in its
implementation and meaning. See any of Andrew's postings about writing
"2+2" in lambda calculus.
>> If you can't look at the code and figure out which function bodies get
>> evaluated, it makes it really rough to work out what's going on, even
>> in a functional language.
> code conceptually.
Sure. And if you have an entity called "o" or "+" or "case" or "start"?
I wouldn't go that far, but yes. But if you have a language that defines
complex syntax (which Haskell does a little and C++ does a lot) and you
can't even parse the syntax tree because you can't distinguish reserved
words from variables or functions, then you must admit it's going to be
difficult to read the code. Indeed, if you can't even tell where one
expression ends and another starts, it can be very difficult to
understand the code.
> Orchid XP v8 wrote:
>> In Haskell,
Probably. ;-)
What, you can't guess?
*rimshot*
Sorry, couldn't resist that... ;-)
>> module Main where
>> main = do
>> guess target
>> guess target = do
>> putStr "Guess: "
>> txt <- getLine
This appears to work:
#include <iostream>
#include <sstream>
#include <cstdlib>
#include <ctime>
void guess(const int target)
while (true)
std::cout << "Guess: ";
std::string txt;
std::cin >> txt;
std::istringstream iss(txt);
int number;
iss >> number;
if (number < target) {std::cout << "Too low." << std::endl; continue;}
if (number > target) {std::cout << "Too high." << std::endl; continue;}
break;
std::cout << "You win!" << std::endl;
int main()
const int target = std::rand() % 99 + 1;
guess(target);
A few missing semicolons, a few missing std:: qualifiers, and then it
basically ran first time.
(It is unclear to me whether I could have thrown in a few more "const"
keywords, but for such a short example it probably doesn't matter.)
> example.
More like, "it's the only bit of C that I know". (I'd use an example of
printf() or something, but first I'd have to find an example that's
actually *correct*...)
Both C and C++ are positively *bursting* with features that are subtle,
counter-intuitive and cryptic. This isn't exactly news. C++ at least
appears to be something of an improvement in this regard...
Beauty is in the eye of the beholder?
> std::string txt;
> std::cin >> txt;
> int number;
> iss >> number;
I think you misunderstood the reason to use stringstreams. Recycling the
user input through the stringstream above is basically a no-op (except that
it's needlessly inefficient). You could have read the value directly from
std::cin:
int number
std::cin >> number;
Why I suggested using stringstreams in your original program was because
you wanted to read either a string or an integer. This can be done by
reading a string, and then trying to parse it as an integer with a
stringstream (which also allows you to check if the parsing succeeded).
However, here you are simply always reading an integer. There's no need
> break;
Wouldn't it be simpler to do it like:
if(number == target) break;
if(number < target) std::cout << "Too low.\n";
else std::cout << "Too high.\n";
>> std::string txt;
>> std::cin >> txt;
>> int number;
>> iss >> number;
Er, yeah, good point...
>> break;
Mmm, I guess that would also work...
How does Haskell distinguish where a nested (possibly curried) function
call ends, and the outer one continues? Assume that you would want to
write (here in C++ style) something like:
foo(a, bar(b, c), d, e)
If you wrote that as a Haskell-style no-delimiters function call,
I suppose it would look like:
foo a bar b c d e
Exactly how does Haskell decide how many parameters 'bar' takes there
(and consequently how many of the rest of the parameters are for 'foo')?
I can't even begin to imagine how you would write that using the
"point syntax", seen in many examples posted by Andrew. Perhaps you
use parentheses to enclose the 'bar' call?
(Btw, I think this demonstrates one problem with Haskell. I'm an
experienced programmer, and I do have a moderate understanding of the
functional paradigm, and I have been seeing quite many example programs
posted by Andrew during the last years. Yet I'm still completely unable
to figure out or deduce how you could write that in Haskell. It must be
simple, but I just don't know, even though I have seen many examples of
small Haskell programs.
There just is something about the Haskell paradigm and syntax that
makes it confusing and hard to assimilate.)
> foo a bar b c d e
You'd have to throw in some brackets to disambiguate.
If you change every "foo(x, y, z)" into "(foo x y z)", you'll get a
valid expression. In this case, we have
foo a (bar b c) d e
If you wrap the whole thing in brackets, then the following rule
applies: the first token after each "(" is the function being called;
everything else is arguments.
What may be a little confusing is that a function's arguments may be
functions themselves - even standard library functions. This is very
useful from a programming perspective (indeed, the whole paradigm is
based on it), but perhaps rather unhelpful for anybody trying to read
the thing.
Where this starts to go wrong is where you start using operators.
Obviously "2 + 7" means... well... two plus seven. It would be tedious
(though perhaps more consistent) to write this as "(+) 2 7".
To understand how to parse an expression involving operators, you must
know (or take a reasonable stab at) operator precidences. For arithmetic
operators, it's the usual stuff. Function application has a higher
precidence than anything else in the language - so "foo x + bar y"
parses as "(foo x) + (bar y)" and not "foo (x + bar) y".
And that leads us neatly on to...
You can't. Because the nested expression isn't the final argument in the
argument list. (Haskell programmers are very fussy about what order to
put function arguments in for just this reason.)
The following are all equivilent:
function1 (function2 (function3 (function4 (function5 x))))
function1 $ function2 $ function3 $ function4 $ function5 $ x
function1 $ function2 $ function3 $ function4 $ function5 x
(function1 . function2 . function3 . function4 . function5) x
The last one creates a function by chaining several functions together,
and then passes x as the argument to that function. Normally you
wouldn't do that; you'd only use (.) if you wanted to pass a function as
an argument or something:
map (reverse . toUpper)
(Takes a list of strings, converts each string to upper case, and then
reverses it.)
Where this starts to get crazy is if you have functions that take more
than one argument. Because functions are curried, you may write
function2args x $ function4args a b c $ function1arg j
or something.
So, between recognising language keywords, bracketed expressions, ($)
and (.), and infix operators, I guess there *is* quite a bit to be
getting on with.
It's interesting to me that most people seem confused not by curried
functions or monads or high-order functions, but by the basics of
parsing Haskell's syntax. I guess I'm so used to it be now that I take
it for granted - but obviously, if you can't read the language syntax,
you don't stand much chance of getting very far. I'll go have a think
about that...
Warp <war### [at] tag povray org> wrote:
> What you can do is this:
> std::string s;
> while(true)
> std::cin >> s;
> if(!std::cin.good()) break;
> int value;
> std::istringstream iss(s);
> iss >> value;
> if(!iss.fail())
> std::cout << "The input was an integer: " << value << "\n";
> else
> std::cout << "The input was something else: " << s << "\n";
Actually there is a way to achieve the same thing with std::cin
directly, without having to use stringstreams.
If an input stream fails to read data which fits the parameter type,
it will stop reading, so anything that was in the input (which was not
whitespace) will be left there. It's thus possible to check if reading
the integer filed, and if it did, read it as a string.
The only catch is that you have to clear the error flags of std::cin
before you can continue reading properly.
The above example code can thus be written as:
while(true)
int value;
std::cin >> value; // Try to read an integer
if(std::cin.fail()) // If there was no integer in the input
std::cin.clear(); // Clear the error flags
std::string s;
std::cin >> s; // Read a string
else
Thus removing the need for stringstreams.
Thanks for the tip.
By the way... what's the usual C++ idiom for handling failure?
In Haskell, if you have some function that could fail for some reason,
you have two options:
1. Throw an exception if there's a problem. (Only I/O code can catch and
handle exceptions.)
2. Use the "maybe" datatype, which contains either some data, or a
"there's nothing here" flag. (And because the type is different, the
caller *must* explicitly check which it is before using the result for
anything.)
Typically you throw an exception for something like "we ran out of
memory" or "you called with an invalid argument". But for something
like, say, looking up a key in a dictionary, it's a very predictable
thing that the key might not actually exist, so the "maybe" approach is
used there.
What is the "usual" C++ style for this kind of thing? (I'm asking a
question of style here; clearly there are several possible things you
*could* do in C++.)
> *could* do in C++.)
The standard data containers, as well as 'new', throw an exception by
default when they run out of memory. Also the at() member function of
some of the containers throws an exception if you try to index out of
boundaries.
If you don't want to throw exceptions in your own code, then it depends
on what is it that you want to do to signal a condition.
The usual way to catch programming errors at runtime is to use
assertions. For example:
void foo(int min, int max)
assert(min <= max);
// rest of the code here
If the assertion fails, a message will be printed and the program is
immediately terminated at that point. Obviously this should only be
used in situations which are a symptom of a programming error and which
must be fixed.
(The good thing about assert() is that you can freely use it as much
as you want. In fact, the more you use it, the better. You can compile
the program with a special precompiler parameter which will remove all
the asserts from the executable so that they will not add overhead to
a final version.)
> boundaries.
> assert(min <= max);
> must be fixed.
Right. So assert() is for stuff that should never happen if the
programmer is doing their job right. In other words, BUGS.
How about stuff that might ordinarily be expected to not work? E.g.,
parsing strings, looking up keys in dictionaries, etc.
It seems that streams at least signal errors by altering the stream
object and getting the programmer to call a member function to check
whether an error condition occurred. Is that a usual C++ idiom?
I'm not sure there *is* any "usual" C++ idiom for error handling
(other than throwing exceptions).
No, actually, C is really, really straightforward. Almost moreso than
assembler. It's not subtle and complex and cryptic. It's just difficult
and tedious.
I, personally, think C++ has many features that seem subtle and
counter-intuitive, as evidenced by the fact that it's really hard to
explain how some of the features work and when they come into play. Most
people seem to say "this is how you use them" without actually knowing
why using them that way actually works. (Granted, I don't have a whole
lot of experience with C++, so I probably sound way off base to those
who know C++ well.)
