POV-Ray : Newsgroups : povray.off-topic : Wikipath Server Time
21 Jul 2026 19:30:32 EDT (-0400)
  Wikipath (Message 28 to 37 of 47)
Subject: Re: Wikipath
Date: 15 Aug 2008 11:48:53
Message: <48a5a565$1@news.povray.org>
Invisible wrote:
> (I've never tried this extensively, but I would suggest that it probably
> requires a little forethought before you start the calculation...)
Not too much. If you have the equation written down, the rule is that
you type in the numbers in the order they appear, and you type in the
operators as soon as you've gotten all the arguments for that operator.
Now, if it's not written down, it can take some head-twisting, but IME
not any more than using infix. Certainly easier than using infix without
parentheses built into the calcualtor.
Date: 15 Aug 2008 13:42:55
Message: <48a5c01f$1@news.povray.org>
>> probably requires a little forethought before you start the
>> calculation...)
> Not too much. If you have the equation written down...
I was thinking more if you're just casually throwing numbers around, and
you suddenly realise that you'd like to use the number on the top of the
stack as the *denominator*, not the numerator, or something like that.
If you know before hand exactly what computation you want to perform
then yes it's quite easy.
http://blog.orphi.me.uk/
Date: 15 Aug 2008 13:49:03
Message: <48a5c18f$1@news.povray.org>
I think there's a button for *that* case, actually.
Date: 15 Aug 2008 14:58:25
Message: <48a5d1d1$1@news.povray.org>
>> the stack as the *denominator*, not the numerator, or something like
>> that.
Division and subtraction are the obvious ones. (Oh, and exponent if
there's a button for that.)
Thinking about it, a button to swap the top two operands ought to fix
most problems you might have.
I also anticipate that being able to somehow "inspect" the stack might
come in handy if you can't remember what you put on there already...
Date: 15 Aug 2008 15:11:18
Message: <48a5d4d6$1@news.povray.org>
That's kind of what I was referring to, yes.
Yes. I expect such a thing might have been around on some of the
calculators I remember seeing.
Date: 1 Sep 2008 07:12:05
Message: <48bbce05$1@news.povray.org>
On Fri, 15 Aug 2008 08:58:35 +0100, Invisible wrote:
> Nicolas Alvarez wrote:
>> JavaScript functions don't need names.
>> var value = (function (x) {
>>     return 3*x + 5;
>> })(42);
>> That actually works.
> Ooo... that's interesting.
Python:
  value = (lambda(x): 3*x+5)(42)
Lua:
  value = (function(x) return 3*x+5 end)(42)
Ruby (1):
  def test
    yield 42
  end
  value = test { |x| 3*x+5 }
Ruby (2):
  value = lambda { |x| 3*x+5 } .call(42)
C++0x:
  int main()
    int value = <>(int x) (3*x+5) (42);
  (I would have tested this, but the build instructions
   at http://parasol.tamu.edu/groups/pttlgroup/lambda/
   don't work for me, tried to computers...)
i386 assembly (ok, this is cheating):
  mov eax, 42
  call over
  lea eax, [eax*2+eax+5]
  ret
over:
  pop eax
  call eax
  mov [value], eax
Joel Yliluoma - http://iki.fi/bisqwit/
Date: 1 Sep 2008 07:32:22
Message: <48bbd2c6$1@news.povray.org>
Joel Yliluoma wrote:
> Python:
> Lua:
> Ruby (1):
>   def test
>     yield 42
>   end
> Ruby (2):
> C++0x:
>   int main()
>   mov eax, 42
>   call over
>   ret
> over:
>   pop eax
>   call eax
>   mov [value], eax
Haskell [is that cheating??]
   value = (\x -> 3*x + 5) 42
Lambda calculus:
   \i ->
   (\n -> \m -> \f -> \x -> n f (m f x))
     (\n -> \m -> \f -> \x -> n (m f) x)
     (\f -> \x -> f (f (f x)))
     i
   (\f -> \x -> f (f (f (f (f x)))))
[I can't be bothered to write "42" in the lambda calculus. Suffice it to
say it contains 42 copies of the letter "f".]
Date: 1 Sep 2008 16:27:10
Message: <48bc501e@news.povray.org>
> C++0x:
>   int main()
I thought it was [], not <>.
But I don't have any C++0x compiler...
Date: 1 Sep 2008 17:38:38
Message: <48bc60de@news.povray.org>
> > C++0x:
> >   int main()
  I suppose the exact syntax has still not been written to stone. The
current wikipedia article on the subject uses your syntax:
http://en.wikipedia.org/wiki/C%2B%2B0x#Lambda_functions_and_expressions
Date: 1 Sep 2008 17:41:52
Message: <48bc619f@news.povray.org>
It's not a feature I'm likely to use much, anyway. I'm more interested in
the range-based for loop (yes, I know it's pure syntax sugar), and template
concepts.
Currently:
for (std::vector<int>::iterator i = myList.begin(); i != myList.end(); ++i)
With the new type determination feature:
for (auto i = myList.begin(); i != myList.end(); ++i)
With the range-based for loop:
for (int &x : myList)
<3
