POV-Ray : Newsgroups : povray.off-topic : Another stupid SQL query problem Server Time
17 Aug 2025 09:19:15 EDT (-0400)
  Another stupid SQL query problem (Message 1 to 10 of 12)
Subject: Another stupid SQL query problem
Date: 21 Apr 2008 16:38:53
Message: <480cfb5d$1@news.povray.org>
If we have any SQL gurus out there (not mentioning any names, Gail :-) I
have a simple problem I with undoubtedly a simple answer.
I have a log table:
Log_time | IP | Script_Name| Email | DK
I need to select based on the criteria Log_time between two dates, script
name =  '/EN/travelsync/content/getthere.asp', and DK = 'TEST'
So far we get:
SELECT Log_time, IP, Script_Name, Email, DK
FROM uselog
WHERE
Log_time >  '2008-01-31' and Log_time < '2008-03-01' and Script_Name =
'/EN/travelsync/content/getthere.asp' and DK = 'TEST'
I need to add a field indicating the number of times an email address occurs
and not return multiple records for the same email address.
That's hard to explain, but hopefully I managed to do it.
If anyone here knows what I must do please let me know. Thanks!
Subject: Re: Another stupid SQL query problem
Date: 21 Apr 2008 16:58:27
Message: <480cfff3@news.povray.org>
"Halbert" <hal### [at] gmailcom> wrote in message
news:480cfb5d$1@news.povray.org...
Hmmm, am I hearing things?
> I
> I have a log table:
Ok. Think I understand. It's a little complex, but not really difficult.
Do need some things clarifying.
Say you have 3 rows with the same Email, different IP, different Log time
and different script. (is that possible?)
What log time, IP, script do you want returning? The ones that match the
latest log-time? Oldest log time? Any one, doesn't matter?
Oh, what DB engine? Oracle, My SQL, SQL Server, other? What version?
If no one's helped by morning, I'll take a look, but it's 11pm here...
Date: 21 Apr 2008 17:04:05
Message: <480d0145$1@news.povray.org>
The script name will not be a variable. But the email could come from
different IPs at different times. They want to have counts for the number of
times individuals used the getthere.asp script.
We are using MS SQL Server (2000 in this case)
Thanks again.
s
"Gail Shaw" <initialsurname@sentech sa dot com> wrote in message
news:480cfff3@news.povray.org...
>> I
>> I have a log table:
Date: 21 Apr 2008 17:10:09
Message: <480d02b1@news.povray.org>
news:480d0145$1@news.povray.org...
of
> Thanks again.
Ok, so say this is the input (as a comma-seperated list). What do you want
as results?
Logtime, IP, Email
2008/01/01 10:15, 10.2.45.56, me@here
2008/01/01 10:25, 10.2.45.56, me@here
2008/01/01 16:15, 10.2.78.156, me@here
2008/01/02 12:15, 10.2.15.74, me@here
2008/01/02 12:17, 10.2.15.74, me@here
2008/01/02 12:19, 10.2.15.74, me@here
2008/01/01 12:15, 10.5.25.34, you@somewhere
2008/01/01 13:15, 10.5.25.34, you@somewhere
2008/01/01 14:15, 10.5.25.34, you@somewhere
2008/01/01 18:15, 10.5.25.38, you@somewhere
Date: 21 Apr 2008 17:18:35
Message: <480d04ab$1@news.povray.org>
> Logtime, IP, Email
me@here,7
you@somewhere,4
Date: 21 Apr 2008 17:30:19
Message: <480d076b$1@news.povray.org>
Halbert wrote:
>> Logtime, IP, Email
> me@here,7
> you@somewhere,4
That's easy, then.
select email, count(*) from logtable where '2008-...' < logtime and
logtime < '2008...' group by email
The "group by" (and possibly "with rollup" and "having" clauses) is what
you need to read up on.
If you need one of the IP addresses or other columns to come back, it's
harder.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 21 Apr 2008 17:34:51
Message: <480d087b$1@news.povray.org>
> That's easy, then.
> harder.
In reality, I need to select based on DK (a company identifier,)the script
name and the date range but I think that it would be sufficient to return
with only the email and the count.
Date: 21 Apr 2008 20:03:05
Message: <480d2b39$1@news.povray.org>
Halbert wrote:
>> That's easy, then.
>> harder.
The "group by" lets you select on anything. (I.e., the "where" clause
can refer to any column, including joins with other tables etc.)  But
everything you *return* has to either be mentioned in the "group by"
clause or has to be a summary function (like count(), sum(), avg(),
etc).  (I forget what those kinds of functions are called in SQL, but...)
Date: 22 Apr 2008 00:38:41
Message: <480d6bd1@news.povray.org>
news:480d087b$1@news.povray.org...
> > That's easy, then.
> > harder.
Still very simple.
SELECT Email, Count(*)
FROM uselog
WHERE
group by Email
Date: 22 Apr 2008 00:39:07
Message: <480d6beb@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:480d2b39$1@news.povray.org...
Aggregate.
