POV-Ray : Newsgroups : povray.off-topic : A Word question : scale a text with different fonts and font sizes Server Time
17 Aug 2025 16:27:52 EDT (-0400)
  A Word question : scale a text with different fonts and font sizes (Message 1 to 5 of 5)
Subject: A Word question : scale a text with different fonts and font sizes
Date: 11 Apr 2008 11:03:50
Message: <47ff7dd6$1@news.povray.org>
A question for the Word experts...
I want to paste the text of a web page inside a Word document, and then
to scale the size of the whole text. The difficulty is that the text
contains different fonts, with different sizes (and I need to keep those
different fonts and size for readability). If I select the whole text, I
cannot change the size of the fonts (because it is a mix). Is there a
way to scale all the fonts size down (without selecting individually
each font, which would be tedious)?   It sounds easy, it is maybe
stupid, but I have not found a way so far.
Thanks for any help,
Thibaut
Subject: Re: A Word question : scale a text with different fonts and font sizes
Date: 11 Apr 2008 11:23:28
Message: <op.t9gc28hwc3xi7v@news.povray.org>
And lo on Fri, 11 Apr 2008 16:03:50 +0100, Thibaut Jonckheere
<tua### [at] MAPSONyahoofr> did spake, saying:
Select all the text you want to scale. Hold down the Ctrl+Shift keys and
use the < > to scale down or up respectively.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 11 Apr 2008 11:32:09
Message: <47ff8479$1@news.povray.org>
>> then to scale the size of the whole text. The difficulty is that the
>> text contains different fonts, with different sizes (and I need to
>> keep those different fonts and size for readability). If I select the
>> whole text, I cannot change the size of the fonts (because it is a
>> mix). Is there a way to scale all the fonts size down (without
>> selecting individually each font, which would be tedious)?   It sounds
>> easy, it is maybe stupid, but I have not found a way so far.
> --Phil Cook
	Thanks a lot !
For some reason I do not understand, it works only to scale down (and
not to scale up), but this is what I need now, so I am not going to
investigate too much :-) .
Thibaut
Subject: Re: A Word question : scale a text with different fonts and fontsizes
Date: 11 Apr 2008 11:42:54
Message: <47ff86fe@news.povray.org>
Well, I did investigate a little bit though. By looking at the list of
all keyboards commands, I can see that the 'scale down font' is defined
on my system (CTRL+SHIFT+<), but not the 'scale up'.
Thibaut
Date: 11 Apr 2008 11:43:31
Message: <op.t9gd0jd6c3xi7v@news.povray.org>
And lo on Fri, 11 Apr 2008 16:32:09 +0100, Thibaut Jonckheere
>> and use the < > to scale down or up respectively.
> 	Thanks a lot !
De nada if it's something you use a lot and can't recall the shortcut then
there are two commands you can add to the toolbar called Shrink Font and
Grow Font.
Odd, but at least it's scaling the right way for you :-)
Phil Cook
