POV-Ray : Newsgroups : povray.off-topic : I found this interesting Server Time
27 Jun 2026 23:47:45 EDT (-0400)
  I found this interesting (Message 35 to 44 of 154)
Subject: Re: I found this interesting
Date: 6 Apr 2008 16:25:18
Message: <47f931ae$1@news.povray.org>
Warp wrote:
>   I believe that the most usual reason for the negative attitude is
> that the "noobs" are getting the job "done" faster, but at the cost
> of software quality. The software made by a newbie usually lacks
> robustness and efficiency. However, because bosses usually cannot
> see past the GUI, they are fooled into thinking that the newbie is
> actually a better programmer than the experienced one because he got
> something visible done faster. Then they hire the newbie and kick out
> the experienced programmer.
This reminds me of a problem that I saw working in the math study center
at my local college.
We were explicitly told not to help the Business Math students with
their homework, because the requirements of what they wanted were so
different from what students in the regular math courses needed.
Specifically, they didn't need to know "how it worked", just "how to
press buttons on a calculator to get the correct result".  As a result,
it was felt that our teaching them correct mathematical principles would
be a waste of time, both theirs and ours.
This drove me nuts.  In fact, on several occasions (when there weren't
other students needing help), I explicitly ignored the instructions and
helped the business math students.  But I wouldn't do it the way their
instructors wanted (press this button, get this result).  Instead, I
would teach them the theory behind what they were doing, to the point
that if they forgot the correct button press, they could still work out
the answer (or at least, figure out what buttons to press on their own).
  Usually, they expressed gratitude for my helping them to finally
understand what they were doing.
I think software is the same way.  While I never coded with 1s and 0s,
relatively soon after learning BASIC I learned x86 assembly, in real
(not protected) mode.  Things like pointers aren't a problem to me,
because they're an inherent part of computer architecture (virtually
everything uses pointers), and I understand the underlying architecture
fairly well.  I'm not against using VB, C# or LISP, per se.  But I *do*
think that my understanding of the underlying architecture is important
even in those languages.
The disdain that "real" programmers feel for newbies who crank out quick
code using "toy" languages is, I think, more akin to the disdain "real"
mathematicians feel towards business math majors.  Sure, they can "press
the buttons", but they don't really know what they're doing.  It's not
about jealousy - after all, many programmers who started out writing
assembly code are now using higher level languages and cranking out code
just as quickly.  It's about perceived understanding of what your code
actually does.
Personally, I think this understanding is so important that I would say
*all* programmers should, at one point or another, learn to write
complete programs in assembly language, by hand.  Not that they should
use machine language for their jobs, but because knowing how computers
*really* work will help them write better programs in the long run.
...Ben Chambers
www.pacificwebguy.com
Date: 6 Apr 2008 16:28:23
Message: <47f93267$1@news.povray.org>
I never went lower level than C. (well, I have looked at the
assembly-like code for LEGO RCX, but I doubt that counts; there aren't
even pointers there) I think some day I should learn asm...
Date: 6 Apr 2008 16:33:43
Message: <47f933a7@news.povray.org>
This, presumably, is why my course included a module on microprocessors,
machine code, binary representation, etc. It probably didn't help in the
slightest that this module was taught by Mr Apothetic. Seriously, I have
*no idea* WTF this guy's problem was, but damn...!
"Well this stuff is in the exam so I *suppose* I'd better teach it to
you. But it's pointless really. You'll never actually *need* to know
this stuff." Way to motivate your students, man! [Yes, these are the
actual words he used. His emphasis.]
But then, his views on BP were quite similar. "Oh yes, I understand
they're trying to 'rebuild Colossus'. Pointless really. The actual
machine was destroyed, so it'll never really be exactly like the
original. And what will they *do* with it anyway?" Jesus, dude, take a
pill or something!!
It really made me sad. This _would_ have been one of the most
interesting parts of the course... much more fun than learning Java or
how to balance accounts...
Date: 6 Apr 2008 16:35:37
Message: <47f93419$1@news.povray.org>
The concept of assembly without pointers bemuses me.
I don't "get" what's so hard about pointers. All data is stored in the
computer's memory. The memory is a vast grid of numbered cells. Each
cell's number is called an "address". A "pointer" is simply something
that holds the address of something else - it "points to" something. The
End.
Now, pointers and typecasting... scary stuff!
Date: 6 Apr 2008 16:37:30
Message: <47f9348a$1@news.povray.org>
Darren New wrote:
> The part others seem to think you lack is the knowledge of how to
> structure a document that's bigger.  You need to be able to say (a) why
> would the reader want to read this document, and (b) present it in an
> order and form that makes it easiest to understand.
The following structure from public speaking applies to pretty much any
technical document or report, as well.
a) Tell the audience what you're going to say.
b) Say it.
c) Tell them what you said
...Ben Chambers
Date: 6 Apr 2008 16:40:43
Message: <47f9354b$1@news.povray.org>
Orchid XP v8 wrote:
> Heh. I've still failed to convert even one single person to Haskell yet.
Consider that I'd never even *heard* of Haskell before I read your posts
here.  In fact, I *still* haven't gotten around to learning LISP, Ruby,
Perl, Python, Smalltalk, Lua, or any of a number of languages, although
I *have* looked at them and considered learning them.
In fact, C# is the first time in about 10 years now that I'm learning a
*new* language, and its only a derivative of the ones I already know.
Getting people to invest time into something like learning a new
language is difficult, at least, and close to impossible, in many
situations.  Just keep plugging, and don't lose hope :)
...Ben Chambers
Date: 6 Apr 2008 16:41:10
Message: <47f93566@news.povray.org>
> b) Say it.
Ah yes, the "tell them thrice" structure.
I pretty much suck at that. It's true... :-{
Date: 6 Apr 2008 16:42:18
Message: <47f935aa@news.povray.org>
The RCX has numbered variables (16-bit signed integers). There is no
real access to "memory". Although the 2.0 firmware supports indirect
access (indirect(3) reads get_variable(get_variable(3)) ) so things like
indexing an "array" in a loop is possible.
Date: 6 Apr 2008 16:43:57
Message: <47f9360d$1@news.povray.org>
I looked at Clean. It isn't.
I also looked at F#. And didn't like it much. Ditto for Erlang. And
Lisp. And Prolog. (But that was a very long time ago...)
You're talking to somebody who learned PostScript in their lunch break
one day. Just for the fun of it. BECAUSE I WAS BORED!!
Holy crap, I need a different job! o_O
Woah... and here I am trying to get people to learn something that's so
fundamentally weird it freaks Pixar employees out... o_O
Date: 6 Apr 2008 16:45:44
Message: <47f93678$1@news.povray.org>
andrel a écrit :
> Orchid XP v8 wrote:
>>>> I'm pretty sure that Andy is perfectly able to write a decent report.
>>> He said he isn't. So who am I going to believe.
>> I'm good at writing short, unstructured things. When trying to explain
>> big concepts, I have trouble figuring out where to start and what
>> order to say things in.
> My way of looking at a text or presentation: Look at it as if it is a
> program. The conclusions are the main routine. The lines in the
> conclusions call various subroutines (aka the previous sections and
> slides) that can in turn call other subroutines (paragraphs). You should
> therefore be able to draw a flowchart of the concepts in your text. A
> text is good if 1) no external subroutines are called (i.e. everything
> is defined within the text or common knowledge to the audience) 2) there
> are no dead branches. 3) all subroutines are define before use or
> explicitly declared as something to fill in later.
> When I said that a programmer should be able to write a decent report
> (or give a good presentation for that matter) because the skills
> required are the same, the above is what I meant.
I wonder how the (very good, by the way) analogy applies to the
functional programing so dear to Andrew :-)
If he starts writing reports that resemble Haskell programs, there will
be recursive sections all over the place :-D
Vincent
