POV-Ray : Newsgroups : povray.object-collection : Polyhedra library Server Time
15 Sep 2025 08:06:11 EDT (-0400)
  Polyhedra library (Message 1 to 10 of 20)
Subject: Polyhedra library
Date: 21 Jul 2009 17:40:00
Message: <web.4a66345af9355cc2d5649c20@news.povray.org>
I have a question concerning the polyhedra objects I have recently been
amassing. Silly me, I haven't been creating the include files with the object
collection in mind, and there are A LOT of include files.
I have organised the polyhedra into groups (Platonic, Archimedean etc). Each
group has a main include file, which has a list of everything defined in that
group and another set of includes. Each polyhedron then has its own separate
include file, which defines three macros and a global vertex array. In this
way, one can include individual shapes without having to include the whole lot,
or a whole group without having to manually list the whole lot. I've been
putting the groups into separate directories for convenience, although this
needn't be compulsory. The macros and arrays are all prefixed by the shape name
and an underscore (e.g., tetrahedron_faces(), tetrahedron_edges() etc), and each
include file is named for this prefix.
My question is, therefore (and eventually!), is this layout sufficient for
inclusion in the object library? It feels sensible to submit each group as a
separate item, but the prefixes are per shape-include, not per group. Also, as
there are so many files per group (92 shapes for the Johnson solids, for
example) it might be better to submit a .zip file - is this supported by the
submission system?
Any advice..? :-)
Bill
(I'm also happy to host them on my own site, but this of course defeats the
purpose of the object collection...)
Subject: Re: Polyhedra library
Date: 21 Jul 2009 17:47:56
Message: <4a66378c@news.povray.org>
IMO you should group the objects into a smaller amount of include files
rather than having every single one in its own file (unless the files are
very large, which I think is not the case with such simple objects). While
parsing an include file with dozens of objects might take slightly longer,
it's not that bad (as long as you don't go overboard). Just group all the
polyhedra into logical categories, and create one include file for each
such category. Then maybe an include file which just includes all those
separate include files.
  Also, if you haven't done so, I think all the polyhedra should be scaled
to fit the same space, for consistency. For example, they could be scaled
so that they all fit perfectly inside a box from <-1, -1, -1> to <1, 1, 1>.
This way it's easy for the user to scale any polyhedron to the size he needs.
  Also, I don't know how you have thought about defining the objects, but
you could do two things:
  1) #define each polyhedron as its own identifier, named logically and
consistently.
  2) For each category, create an array with all the polyhedra of that
category, ordered in some logical way.
  This way the user can use either the name of the polyhedron directly,
or index that array, as needed.
Date: 21 Jul 2009 18:05:00
Message: <web.4a663b7acda2f1c2537313280@news.povray.org>
.... or not. There's also reason to scale them so all edges are 1 unit in length
(which however gives rise to the question whether they should be seated on the
y=0 plane, or centered around <0,0,0>), or - in case of regular polyhedra - so
that all vertices are at 1 unit distance from the center.
Interesting question, btw: Is there a way to access the individual vertex
coordinates?
Date: 21 Jul 2009 18:35:00
Message: <web.4a66411dcda2f1c22d5649c20@news.povray.org>
Many of them are very simple, but the larger ones can be quite complex. Each
include file contains the vertices in a global array (for the advanced user)
and three macros for instantiating the shape; most of the stellar icosahedra
includes are 1200+ lines.
> Just group all the
That'll probably work. There are some logical sub-groups in the Johnsons, but
the stellar icosahedra don't really have any sub-groups. If I put them all
together it could be several MB for the include... not too bad compared to a
big converted mesh2 I suppose.
I can add this with no problems, I think. Most of them are already approximately
scaled like this anyway.
> consistently.
I have three macros per shape. Faces (taking texture identifiers for polygon
types by number of sides), faces (no textures) and edges (textures and radii
for the edge cylinders and vertex spheres). Each macro also takes a yes/no for
sitting the shape on the x-z plane (it is centred on the origin otherwise). I
thought I could leave it to the user to combine faces and edges for themselves.
This is something I already thought of - invaluable for rendering them in
groups, as I have been doing.
What about the prefixes though? Even if I put them together in one file, there's
a lot of renaming to do for perfect library standards compliance...!
Date: 21 Jul 2009 18:36:47
Message: <4a6642ff@news.povray.org>
Firstly: thank you for your efforts and generosity in sharing the files!
Why don't you just post what you have got so far somewhere - whereever -
just not yet in the object collection. Maybe on rapidshare, if you fear for
the traffic it might generate.You might drop a link here.
Then we all could have a closer look at the sources, since I do not have the
faintest idea how large or small, how complex or how trivial (in case of a
tetraeder, cube etc. ;-) the files and data may be. So everybody interested
in the discussion could have a look and make some comments based on facts
instead of guesswork how the actual files do look.
Then you could consider all the arguments and decide what to do.
Date: 21 Jul 2009 18:40:01
Message: <web.4a66430fcda2f1c22d5649c20@news.povray.org>
> length
I thought about it, but it seemed overkill. Also, this wouldn't apply to the
stellar forms, since many of them are composed of highly irregular polygons.
Taken care of - see my reply to Warp.
I could be wrong, but I think that only applies to the Platonics.
> coordinates?
Yes - see my reply to Warp.
Many of your suggestions become possible by having access to the vertices, of
course!
Date: 22 Jul 2009 04:57:27
Message: <4a66d477@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote in message
news:web.4a66345af9355cc2d5649c20@news.povray.org...
> object
> Each
> that
> separate
> this
> lot,
> this
> name
> and each
> a
> Also, as
> the
> submission system?
These objects would be a great addition to the collection.
To answer your technical questions about the site:
File Names:
The upload scripts check that all files start with either the name of the
submission (e.g. "Polyhedra"), or a prefix that you can define (e.g. 'P').
This would mean that a file called 'tetrahedron.inc' would need to be
renamed 'p_tetrahedron.inc' or 'polyhedra_tetrahedron.inc', otherwise the
upload screen will raise an error.
SubDirectories:
Web browsers don't allow you to select a folder in the file upload screen
associated with a file field on a web page (or at least none of the web
browsers I've ever come across). The submission screen doesn't currently
provide any functionality to create subfolders within a single entry. OTOH,
if memory serves me correctly, I coded the server-side code to support
sub-directories. So if it makes most sense to organize them that way, I can
probably upload the directory structure for you (I'd need to do some testing
first to verify that this works ok).
ZIP Files:
The upload scripts don't accept 'zip' files, only files with extensions
'BMP, CSS, CSV, GIF, HTM, HTML, INC, INI, JPEG, JPG, JS, MAC, MCR, MDL, PGM,
PNG, POV, PPM, TGA, TIF, TIFF, TXT'. This is intended to reduce the risk of
harmful content being uploaded.
Identifier Names:
Variable and Macro names are less critical. The scripts do allow you to
upload files containing non-standard identifiers. The aim of the standards
is to avoid naming collisions for people using the files. It would therefore
be preferable to rename them, for example 'P_tetrahedron_faces()'. In any
case it is a POV-Ray convention to start identifier names with an uppercase
letter as I believe that names starting with lowercase letters are all
reserved for future versions of POV-Ray.
If you'd like help renaming files and variables for this impressive
collection of shapes, then I'd like to offer you my assistance. I'm quite
adept with editors and editor/OS scripts, so it's likely that I could do
that quite quickly. Also, if there is a large number of files it can get a
bit tedious selecting them one by one on the submission screen. I've done
this with about 30 files in one go and I would say that this is probably
about the practical limit. I do have access to the file system though, so if
you need a large number of files uploading for a single entry, I can easily
do the bulk of that for you.
Best Regards,
Chris B.
Date: 22 Jul 2009 05:35:00
Message: <web.4a66dbd5cda2f1c26dd25f0b0@news.povray.org>
Okay, so regarding filenames and directories, this may not be such an issue if I
follow Warp's advice and combine the separate files into a single include per
group.
> ZIP Files:
Of course. If I end up with many files, I'll let you know and put a temporary
..zip on my site that you can upload for me.
> Identifier Names:
By the sounds of it, this won't be too much of a problem either. The Johnson
solids and stellar icosahedra are all prefixed by J23, S48 and so on because of
their unwieldy nomenclature. The others are not sufficiently numerous to stop me
renaming them manually.
If I hit any serious bottlenecks I'll let you know - thanks for the offer!
Bill
Date: 10 Aug 2009 16:30:45
Message: <4a808375$1@news.povray.org>
Why are you storing the individual vertices instead of generating them
using an equation?
-Mike
Date: 12 Aug 2009 05:05:01
Message: <web.4a828594cda2f1c26dd25f0b0@news.povray.org>
> using an equation?
Quite simply, because I don't know how! (Well, except the simpler cases like the
platonic/archimedean solids).
I am converting the polyhedra from a library of meshes - someone has already
done the necessary calculations to generate them; I simply want to play with
the shapes and make them available to other users. The meshes are not big, so
there's no advantage to a native SDL polyhedron generator beyond elegance and
the joy of the challenge.
I've been distracted from this by RL recently, but they will make it to the
object library sometime soon, promise!
Bill
