Mike Horvath <mik### [at] gmail com> wrote:
> I kinda wish there were a POV-Ray object that would be guaranteed to
> always be 1 pixel big.
I snipped this out of something I wrote last April, and haven't tested it out
tonight in a scene all by itself, but it gives you the broad strokes.
Location is the camera location.
(So do
#declare Location = <0, 0, -10>;
camera { ... location Location ...}
Vector is the center of the object you want to be 1 pixel.
The macro returns the radius of a sphere/cylinder so it is a pixel wide.
you can work the rest out from there.
// Minimum radius for solid visibility is (Z/image_width)*Aspect
// Minimum radius for threshold visibility is (Z/image_width)
#macro MinRad (Vector)
#local Aspect = image_width/image_height;
#local Dist = vlength (Vector-Location);
#local M = (0.5*Aspect)/tan(radians(Angle/2));
#local ZA = Dist/M;
#local Rad = (ZA/image_width)*Aspect;
Rad
#end // end macro MinRad
> (So do
> #local ZA = Dist/M;
> Rad
Interesting. Would it work better with a cube oriented to face the
camera? I suppose the perspective distortion might make the cubes look
weird if they're toward the edges of the image. But spheres would end up
looking distorted too.
Mike
> Mike
E.g. a true "one-pixel" POV-Ray object would not be distorted by
perspective, which I think is realistic since stars are so distant and
tiny that visual perspective has no effect on their perceived
dimensions/brightness.
Mike
On 2018-02-09 10:28 PM (-4), Mike Horvath wrote:
> The fuzzy circles don't look so great. I don't know if anything can be
> done to improve them however. In video games, stars are often reduced to
> 1 pixel. But I don't think in POVray there's an easy way to make a star
> exactly 1 pixel big. Maybe with some trigonometry?
Yes, of course they can be improved! The purpose of the demo was merely
to demonstrate how to use the data. I consider attempting a realistic
sky beyond the scope of the demo.
This works if you are representing the stars as actual objects:
----------[BEGIN CODE]----------
#version 3.7;
#declare Cam_angle = 60;
#declare RSky = 10000; // arbitrary distance to the stars
#declare R = RSky * tan (radians (Cam_angle / 2)) / image_width;
camera
{ location 1.64 * y
look_at <0.5, 2.64, 2.5>
angle Cam_angle
plane { y, 0 pigment { checker } }
#include "brightstar5.inc"
#default { finish { ambient 0 diffuse 0 emission 1 } }
union
{ #for (I, 0, BSC5_N - 1)
#if (BSC5_Data [I] [BSC5_HD] != BSC5_NO_DATA)
sphere
{ RSky * y, R
pigment { rgb BSC5_fn_Brightness (BSC5_Data [I] [BSC5_MAG], 0) }
rotate
< 90 - BSC5_Data [I] [BSC5_DEC],
-15 * BSC5_Data [I] [BSC5_RA],
0
rotate <0, 120, 71.7>
-----------[END CODE]-----------
I disregarded image_height in the formula because the POV-Ray camera
considers only image_width for its field angle. Also note that if the
camera is significantly distant from the origin, you will need to make
appropriate adjustments.
Note that with a diameter of 1 pixel, an adaptive anti-aliasing trace
will miss quite a few stars. To avoid this, you'll need to either use
+A0.0 (slow), or use a diameter slightly larger than 1 pixel (times
sqrt(2) should do). As far as using boxes instead of spheres, I don't
think it would be worth the effort.
If Orion looks strangely oriented in the above code, it's because I'm
stargazing from the northeast Caribbean.
Yes, there is some distortion as you move away from the center of the
image, as explained in the knowledge base:
http://wiki.povray.org/content/Knowledgebase:Misconceptions#Topic_3
The orthographic camera will preserve the star shape, but the star
positions will still be distorted, for the reason you learned in 4th
grade geography. Also, the orthographic camera would be quite awkward
to use if you are rendering, say, a landscape.
A sky sphere would use a different formula, but the math would be similar.
Has anyone to date used the catalogue to generate a fairly realistic spherical
sky shell or a flat image useful for uv-mapping a sphere?
I'd like to be able to incorporate this into the solar system scene I've worked
on, if I get the time to focus on it, and I have another project where I'd like
to be able to look up from a given position on earth at a certain angle at a
given date and time and see a reasonably accurate view.
Does anyone here know [how to contact] this chap?
https://www.youtube.com/watch?v=bvpEWuxBBRw
Am 1/14/20 8:38 PM, also sprach Bald Eagle:
How many Geoff Dallimore(s) can there be? Google thinks you want the
UK patent attorney, who looks like the guy in the thumbnail on youtube.
If you comment on the video, I'm pretty sure he'll get an email. Or you
can try his contact form: http://xpatent.co.uk/contact/
dik
Rendered 49,882,521,600 of 49,882,521,600 pixels (100%)
> I have extracted some of the data fields from the Yale Bright Star
> Catalogue and converted ...
Hum when it comes time to generate a view if this library,
if your library is in 3D points, not ra dec, you'll save thousands of trig
functions, and the time.
seta(1,146180222.862047,-139516389.855953,-37392435.96208,5.1);
seta(2,65647206.128445,-80763375.119065,-16312013.815614,4.7);
seta(3,135031719.98319,-145513040.060053,-31389042.949954,5.3);
times 10,000,000 = miles, and there's your distance.
I already made a bright star catalog converted to pov, in 3D points, if anyone
is interested.
> is interested.
Yes, that would be a very useful thing, indeed.
Are there comments of any sort to assist in highlighting the various
constellations, or is it just bare-bones at the moment?
I still have to wrap my head around the ephemerides and the orbital elements to
be able to position everything where it needs to be at the proper times...
> > is interested.
Constellation boundaries points is another set of points.
Got it all in 3 languages.
POV
http://trueinnerbeing.x10host.com/charts/planetarium45.zip
JS
http://trueinnerbeing.x10host.com/charts/jtarium232full-opac.zip
http://trueinnerbeing.x10host.com/charts/jtarium.html
(ctrl-F8 titles are links to APOD)
OpenGL
http://trueinnerbeing.x10host.com/code/gamemode.zip
http://trueinnerbeing.x10host.com/code/code.html
all to grok really, is that camera matrix is "inverted"
and you just pipe everything thru the world matrix.
