"SecondCup" <nomail@nomail> wrote:
> Can anyone point me to a good link to help me out? Or is there a sure-fire way
> to connect the two camera shots?
Some of Chris Colefax's POV-Ray Include Files (archived GeoCities pages are
here: http://www.oocities.org/ccolefax/) may be of use and / or save your brain
melting as he's done a lot of the hard work on this kind of stuff already.
The Spline Macro File (archived at
http://www.oocities.org/ccolefax/spline/index.html, with a tutorial) lets you
generate and preview splines and also, most useful to you I think, sample
positions along a spline based on a clock value. So, if the POV-Ray animation
clock is 0.5 you can find out the position of a point half way along the spline.
Combine that with the Automatic Clock Modifier Macro, which is part of the Clock
Modifier Include File (archived at
http://www.oocities.org/ccolefax/clockmod.html - the downloadable zip file
contains very good documentation on both) and you can have more control, e.g.
sample the point along the spline based on a manipulated clock value.
Mr Colefax's code is over a decade old, but still works a treat. I've done this
kind of stuff with it in the past:
http://news.povray.org/povray.binaries.animations/thread/%3C3a6f29ef%40news.povray.org%3E/
Am 10.04.2016 um 15:28 schrieb Bald Eagle:
> Plucker looks like something clipka might be well familiar with. I have a
> feeling he's got a way better handle on all of that affine geometric stuff than
> I've got.
Uh... actually, no. Besides the fact that the proper ASCII rendition
would be "Pluecker", I think the only thing I truly know about that
coordinate system is that I have not the faintest idea what it even does :)
(Well, from the Wikipedia page I do grasp that it uses /some/ set of six
values to identify straight lines, rather than using a set of three
values to identify points. But that's about as far as I get without
having to cool my brain with liquid nitrogen.)
Am 10.04.2016 um 16:37 schrieb clipka:
> So accomodating only for the handedness and a choice of whether Y or Z
> is up doesn't quite cut it.
Uh... never mind this portion of my post. Somehow my brain was still
tuned to a different topic.
I really should try that liquid nitrogen.
> > Nice! The lower image looks good until my code wants it to rotate around the
> > center 360 degrees.
> "Until the code I wrote that I think will rotate it around..."
> Don't anthropomorphize POV-Ray, SDL, or your computer.
> Only YOU _want_ something to happen. Then you follow the rules of the puzzle to
> get the OS to run POV-Ray which interprets the SDL and then makes a Cartesian
> grid of colored pixels.
> > Because I tell the code to 'look_at <the center>', the coordinate system isn't
> > doing what I want.
> The coordinate system is a static "thing" It doesn't "do" anything.
> Look_at just determines what direction the camera is pointing when it's at a
> given location ("vector").
> > Without being locked to viewing the center, the coordinates would be:
> > 6oclock location <0,-15,-65>
> > 3oclock location <65,-15,0>
> > 12oclock location <0,-15,+65>
> > 9oclock location <-65,-15,0>
> > This would create the points on a spleen to rotate around the centre, but my
> > camera wouldnt be focused on the center. The look_at command causes the z-value
> > to act like a zoom-in/out tool.
> Those would be the coordinates regardless of where the camera is looking, or if
> there is even a camera at all. The clock still exists even if a blind man or
> no one at all is looking at it. (Let's not get into quantum delayed-choice
> gedanken experiments....)
> If those are your cardinal points on the clock, go back, draw it out on a piece
> of paper (or preferably on a unit-circle diagram) and then double-check any
> intermediate points you have in your spline.
> An easy way to do this without paper or a spreadsheet or trig, is to just do
> what I just did with the camera path(s) and place some yellow spheres at the
> points where you want the camera to pass through, and see if it lines up with
> where your spline gets interpolated to be.
> I would start out with something VERY simple, like your top-down view of a
> clock, with the first 4 points, and then start progressively adding points -
> then you can see where things start to go wrong.
> I'm on the road all day today - I'll look at this again some time after I get
> back in, sleep, go to work, get back, etc. ;)
> Good luck :)
That worked! I quickly tried my coordinates there and it worked. Thanks mate. I
have some stuff to do today myself but once I get my code fully functioning ill
post it here.
Thank you for the advice. It's much appreciated!
Thanks to everyone for the advice and suggestions. I got it to do exactly what I
wanted. Happy days. Here's my code...note that I drop the camera vertically,
then transition into a smooth arc to rotate 360 degrees around my center point
followed lastly by a smooth arc into a zoom. All while focused just below the
center.
Once you get the hang of the coordinate system, building a spline is the way to
go for smooth animations.
#declare CameraSpline =
spline {
natural_spline
0.0, <0,10,-65>
0.1, <0,0,-65>
0.2, <10, -10, -65>
0.3, <65, -15, 0>
0.4, <0, -15, +65>
0.5, <-65, -15, 0>
0.7, <-10, -15, -65>
0.8, <0, -15, -45>
1.0, <0, -5, -25>
camera{
location < CameraSpline(clock).x, CameraSpline(clock).y,
CameraSpline(clock).z >
rotate < 0, 0, 0>
look_at < 0 , -10 , 0>
> wanted. Happy days.
Congrats! :) I'm happy it's all working out for you.
Sometimes you just need enough of a nudge over some "threshhold", and then it
all clicks into place after that.
There are indeed many uses for splines, and there are all sorts of neat little
tricks and things that people have come up with. Heck, there's SO much stuff
in just the documentation that most of the time it's hard to even know what to
do with it all!
Be sure to check out http://www.f-lohmueller.de/ as well. He's put a LOT of
work into posting very useful working code and tutorials.
On 4/10/2016 3:37 PM, clipka wrote:
> Am 10.04.2016 um 15:00 schrieb Stephen:
>>> it's at a
>> Just one thing to mention. There are two coordinate systems*, Y up and Z
>> up. Depends if you are a mathematician or an engineer. Moray used Z up.
>> There is also left hand and right hand versions too.
>> One of the reasons I use a modeller I cannot visualise scenes well
>> enough to be a true Pover.
>> * Not counting all the fancy ones like Polar, Plücker, cylindrical etc.
> In other words, you refer to cartesian coordinates only.
> Well, actually there are only _two_ fundamentally different
> 3-dimensional cartesian coordinate systems: A right-handed one and a
> left-handed, and _infinitely_ many different orientations of those two
> coordinate systems, each of which are equally valid from a mathematical
> point of view.
Well it confused me going from Moray's Y up to PovRay's Z up coordinate
system. It is easy to make a mistake. It was also the source of many a
flame war, years ago.
A 2D X-Y plane is looked down on like a piece of paper by mathematicians
and Z is up/height. Whilst Engineers looked into an oscilloscope and Z
is depth. Or the other way around. Lutz of Moray fame wouldn't hear talk
about it.
It is a simple transformation to convert and I know for a fact Thomas
has memorised it.
So what doesn't cut what?
I don't understand.
Regards
Too late, too late. Was the reply. :)
And you are extracting what, using liquid nitrogen?
Regards
>> up.
> Right. I've use right-handed, z-up, and it did, for whatever strange human
> reason, take a bit of getting used to when I started using POV's left-handed
> y-up system.
When I used to work for a living. I've used both for different parts of
the job and polar coords as well. People just assume that everyone uses
the one they're using.
Using Moray (Z-up) as a modeller then modifying the code in PovRay
showed me a number of ways how to mess up.
> But some days (nights) _nothing_ makes sense, and that's why drawing things out,
> and checking both the math and _the assumptions_ you are progressing from, are
> always a good idea.
> I use lots of paper, Excel spreadsheets, unit circle diagrams, 3D space models
> or diagrams, test renders, etc.
I thought a "corner of a cardboard box" was a good idea. And a pencil
and rubber comes in handy too.
I think Excel spreadsheets are the best thing since sliced bread. I
start a new one for each project.
> I wouldn't really call polar "fancy" - especially since I often find it easier
> on the brain to "be lazy" and do the ole' define an object at the origin,
> translate, then rotate. Saves doing a lot of trig to get the coordinates,
> especially if I'm not just rotating in one plane, but then tilting up into "3D".
> Cylindrical is just polar with an "altitude" (z) thrown in.
Sorry, I was being flippant. Don't take everything I say seriously.
Polar is very useful and you need to be able to switch between them when
it is easier.
And that is not laziness it is common sense. I create things in unions
at the origin. As I don't have direct access to the code until its
exported. Having an extra union gives me a local set of axles.
> I've got.
> But yes, SecondCup - you should take Mr. McAvoy's
No need to be so formal. :-)
>advice and make sure that your
> assumptions about your axes are correct. That has caused me, and many other
> POV-ers way too many unnecessary headaches. I've even done it when I KNEW I
> wanted to be avoiding it. So write it down, calculate it, and graph it out.
> Don't just let your code fly into uncharted territory - nail down your FACTS,
> and double and triple check what you're doing until you get it to work out
> correctly. Then - just for fun, and as a test of how robust your code is,
> change some things around a bit. Add in things like negative values, zero,
> very large values, etc. to see how robust your system is, and to make sure that
> you're not just in some little coincidental mathematical bubble.
Oo! I don't know. I would say that once you get it working. Leave it
alone. If it breaks next year, fix it then. :-)
I am only joking, I think. But then I can't code so maybe I'm not. :-)
> “What are the facts? Again and again and again – what are the facts? Shun
> wishful thinking, ignore divine revelation, forget what “the stars foretell,”
> avoid opinion, care not what the neighbors think, never mind the unguessable
> “verdict of history” – what are the facts, and to how many decimal places? You
> pilot always into an unknown future; facts are your single clue. Get the facts!”
> ― Robert A. Heinlein
TO WOUND THE AUTUMNAL city.
So howled out for the world to give him a name.
The in-dark answered with wind.
All you know I know: careening astronauts and bank clerks glancing at
the clock before lunch; actresses cowling at light-ringed mirrors and
freight elevator operators grinding a thumbful of grease on a steel
handle; student riots; know that dark women in bodegas shook their heads
last week because in six months prices have risen outlandishly; how
coffee tastes after you’ve held it in your mouth, cold, a whole minute.
Dhalgren
Samuel Delany
Regards
> > wanted. Happy days.
> do with it all!
I've got http://www.f-lohmueller.de/ to thank for getting me to where I am in
less than a month!
