POV-Ray : Newsgroups : povray.newusers : declaring a new texture with a macro Server Time
20 Apr 2026 19:48:06 EDT (-0400)
  declaring a new texture with a macro (Message 11 to 18 of 18)
Subject: Re: declaring a new texture with a macro
Date: 1 Dec 2015 04:05:00
Message: <web.565d623a4f56292ca73f5e290@news.povray.org>
I've modified my project files to keep the essential and it still doesn't work.
I've uploaded the files (pov, inc and png of heightfield) to a server in a zip
archive. The files are quite small.
Here is the path to download the zip file:
www.ant01.fr/fichiersAnt01/povray/pov_help_macro.zip
Date: 1 Dec 2015 04:44:16
Message: <565d6bf0@news.povray.org>
> (* Note that you're welcome to simplify your scene and trim it down to
> the portion that gives you problems; that, too, helps us help you.
Often just performing this task will identify the problem.
Date: 1 Dec 2015 04:47:39
Message: <565d6cbb@news.povray.org>
Seems to work here - I get a pink coloured background with a beige wave
going across this middle. Is this what you expected?
Date: 1 Dec 2015 10:40:00
Message: <web.565dbe1c4f56292ca73f5e290@news.povray.org>
I post the content of the files
File #1 : CouleursPersoAnt.inc
#declare C_marronA1=rgb<113/256, 65/256, 52/256>;
#declare C_marronA2=rgb<117/256, 69/256, 56/256>;
niveau 1 des sols marrons
#declare C_marronB1=rgb<138/256, 89/256, 73/256>;
#declare C_marronB2=rgb<130/256, 85/256, 69/256>;
#declare C_marronB3=rgb<125/256, 77/256, 65/256>;
#declare C_marronB4=C_marronA1;
#declare C_marronB5=C_marronA3;
#declare C_marronC1=C_marronB1*1.15;
#declare C_marronC2=C_marronB2*1.15;
#declare C_marronC3=C_marronB3*1.15;
#declare C_marronC4=C_marronB4*1.15;
#declare C_marronC5=C_marronB5*1.15;
//End of file
File #2 : textures_JeuM_v3.inc
//Nouveau fichier pour les textures
#include "CouleursPersoAnt.inc"
//Textures des differents sols pour Mercenaires
#macro
T_var_Wrinkles(multiplicateur,Cmarron1,Cmarron2,Cmarron3,Cmarron4,Cmarron5,ValAmbient,ValDiffuse)
    texture{pigment{wrinkles color_map{
                                       [0.0 Cmarron3*multiplicateur]
                                       [0.125 Cmarron2*multiplicateur]
                                       [0.25 Cmarron1*multiplicateur]
                                       [0.375 Cmarron2*multiplicateur]
                                       [0.5 Cmarron3*multiplicateur]
                                       [0.675 Cmarron4*multiplicateur]
                                       [0.75 Cmarron5*multiplicateur]
                                       [0.875 Cmarron4*multiplicateur]
                                       [1.0 Cmarron3*multiplicateur]
                    scale 0.005
            finish { ambient ValAmbient diffuse ValDiffuse}
//Definitions des sols marron avec les macros
#declare
T_marron_MacroNiv1=T_var_Wrinkles(<1,1,1>,C_marronA1,C_marronA2,C_marronA3,C_marronA4,C_marronA5,1,0)
#declare
T_marron_MacroNiv2=T_var_Wrinkles(<1.12,1.1,1.1>,C_marronA1,C_marronA2,C_marronA3,C_marronA4,C_marronA5,1,0)
#declare
T_marron_MacroNiv3=T_var_Wrinkles(<1.32,1.3,1.3>,C_marronA1,C_marronA2,C_marronA3,C_marronA4,C_marronA5,1,0)
#declare
T_marron_MacroNiv4=T_var_Wrinkles(<1.52,1.5,1.5>,C_marronA1,C_marronA2,C_marronA3,C_marronA4,C_marronA5,1,0)
//Texture de la roche des pentes avec sols marrons
#declare T_rocheGriseA=T_var_Wrinkles(<1.3, 1.15,
1>,Gray80,Gray70,Gray60,Gray50,Gray40, 1,0)
#declare T_rocheGriseA2=texture{T_rocheGriseA finish{specular 0.2 diffuse 0.4
ambient 0.24} normal{granite 0.6 scale 0.1}}
File #3 : pentes_v3_x128.pov
#version 3.7;
global_settings{assumed_gamma 1.0}
#declare Anim_Serie=true;
#declare xN=128;
#declare HeightField=true;
#declare Mesh=false;
#declare Photo=true;
#include "textures_JeuM_v3.inc"
#declare T_transition1_2 = texture{gradient y texture_map{[0.0
T_marron_MacroNiv1][0.1 T_rocheGriseA2][0.9 T_rocheGriseA2][1.0
T_marron_MacroNiv2]}};
#declare T_transition2_3 = texture{gradient y texture_map{[0.0
T_marron_MacroNiv2][0.1 T_rocheGriseA2][0.9 T_rocheGriseA2][1.0
T_marron_MacroNiv3]}};
#declare T_transition3_4 = texture{gradient y texture_map{[0.0
T_marron_MacroNiv3][0.1 T_rocheGriseA2][0.9 T_rocheGriseA2][1.0
T_marron_MacroNiv4]}};
#declare tps=clock;
#if (Photo =true)
camera{
       orthographic
       location <0.000001,20,0>
       look_at <0,0,0>
       direction -y
       sky z
  up 2*z
  right 2*x
#else
camera{location <2.5,4,2.5> look_at <0,1,0>}
light_source{<10,20,10>*100 color rgb 1}
height_field{jpg
             #if (Anim_Serie=true)
                     #if (tps>=0 & tps<4)
                        "HF_x128_lineaire1"
                     #if (tps>=4 & tps<8)
                        "HF_x128_lineaire2"
                     #if (tps>=8 & tps<12)
                        "HF_x128_coin1"//Orniere
                     #if (tps>=12 & tps<16)
             smooth
             translate <-0.5,0,-0.5>
             rotate 90*tps*y
             scale <2,1,2>
             texture{T_transition1_2}
             scale <1,4,1>
             no_shadow
And the ini file for an auto renderer
-w128
-h128
+a0.3
+KFI0
+KFF15
+KI0
+KF15
+Ipentes_v3_x128.pov
+Ooutput/rr12_x128_.png
+Q9
Date: 1 Dec 2015 12:00:01
Message: <web.565dd1914f56292ca73f5e290@news.povray.org>
I got what I expected in windows 10 with the files mentioned above and the
images you told about but once in Linux Ubuntu (with my laptop, with the desktop
pc I get the expected pictures )I get a pack of 16 totally black pictures.
Lately I tried to tweak the admin rights in folders, removing non ASCII
characters, but it still doesn't work.
I will copy the file of Ubuntu desktop to the Ubuntu laptop. But don't worry
about that , it works on my desktop computer, it's just that I' d like to solve
the problem :(.
Date: 1 Dec 2015 13:16:07
Message: <565de3e7$1@news.povray.org>
Am 01.12.2015 um 17:57 schrieb Warren:
> the problem :(.
It's quite apparent to me at this point that /something/ is fishy about
the POV-Ray binary you're using on your laptop.
This immediately raises the following questions:
- Do any of the sample scenes render properly on your laptop?
- What does "povray --version" output on the two Ubuntu computers?
- What versions of Ubuntu are you using on the two machines?
My current best bet is that you're using a different version of POV-Ray
on the laptop machine, and that there's some bug in that version. If
that is the case, I'd really like to get down to the bottom of it.
Date: 1 Dec 2015 14:05:01
Message: <web.565dee2e4f56292ca73f5e290@news.povray.org>
On the desktop PC in the terminal after a "povray --version" I get :
antoine@PCMapex:~$ povray --version
POV-Ray 3.7.0.unofficial
This is an unofficial version compiled by:
 Antoine FAURE (that's me :) )
 The POV-Ray Team is not responsible for supporting this version.
Copyright 1991-2013 Persistence of Vision Raytracer Pty. Ltd.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Built-in features:
  I/O restrictions:          enabled
  X Window display:          enabled (using SDL)
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff
  Unsupported image formats: openexr
Compilation settings:
  Build architecture:  x86_64-unknown-linux-gnu
  Built/Optimized for: x86_64-unknown-linux-gnu (using -march=native)
  Compiler vendor:     gnu
  Compiler version:    g++ 4.8
  Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread
whereas on the laptop it gives :
antoine@antoine-Presario-V6000:~$ povray --version
 Felix Geyer <deb### [at] ubuntucom> for Debian <www.debian.org>
Built-in features:
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff openexr
  Unsupported image formats: -
  Build architecture:  x86_64-pc-linux-gnu
  Built/Optimized for: x86_64-pc-linux-gnu
-fno-enforce-eh-specs -g -O2 -fstack-protector --param=ssp-buffer-size=4
-Wformat -Werror=format-security -O3 -pthread
And yes, on the laptop I installed povray via the depots "trusty backports"
whereas on the desktop PC I compiled the sources I download on www.povray.org.
Date: 2 Dec 2015 10:55:00
Message: <web.565f13ff4f56292ca73f5e290@news.povray.org>
Hi , everybody
I have good news. :)
I removed povray I get from the depots "trusty backports" and installed povray
with the source code from www.povray.org > github and the code I posted in the
post above works fine now. I tested the render example after compiling the new
povray and that was good too.
I want to thank all those who were willing to help me. :)
Antoine.
