POV-Ray : Newsgroups : povray.newusers : a question about image map projection Server Time
3 May 2026 18:49:03 EDT (-0400)
  a question about image map projection (Message 1 to 2 of 2)
Subject: a question about image map projection
Date: 16 Jan 2004 09:10:03
Message: <web.4007f092e0e38790999617420@news.povray.org>
is there a way to prevent an image map from re-appearing mirrored on the
opposite side of an object? a work-around i used up to now is to create a
copy of the actual object, put the image map on it and position it at the
same coordinates with a slight offset. this seems to me a rather awkward
way, though, and often it doesn't work if the surface is complicated. so,
is there a better way to do this?
Subject: Re: a question about image map projection
Date: 16 Jan 2004 19:55:10
Message: <400886ef.18626532@localhost>
Define one pigment that is your image map.  Define a
second pigment to be the back side of your shape.
Now make a pigment that is a front-to-back gradient
with a pigment_map from your image pigment to your
second pigment.
Tha will work for simple objects (IE, the "front" is
flat).  UV-mapping will work for more complicated
(mesh, most likely) objects.
