POV-Ray : Newsgroups : povray.newusers : Prisms with conic sweeps and unpredictable results Server Time
4 May 2026 00:39:27 EDT (-0400)
  Prisms with conic sweeps and unpredictable results (Message 1 to 5 of 5)
Subject: Prisms with conic sweeps and unpredictable results
Date: 28 May 2003 11:35:02
Message: <web.3ed4d625db845e66738e706a0@news.povray.org>
I guess I'm just having difficulty understanding how to achieve predictable
results with a conically swept prism object in my scene.  I specifically
want the object to have the "ziggurat" type flattened top.  Given such a
prism declaration, (lifted almost wholecloth out of the docs)
  prism {
    conic_sweep
    linear_spline
    0.85, // height 1
    1, // height 2
    5, // the number of points making up the shape...
    <4,4>,<-4,4>,<-4,-4>,<4,-4>,<4,4>,
    rotate <180, 0, 0>  //(yes, I get this part)
    translate <0, X?, 0>
    scale <1, 4, 1>
    pigment { gradient y scale .2 }
How much should the object get translated downward for its base to be at
y=0? And would scaling the object along y affect where its base lay?
Subject: Re: Prisms with conic sweeps and unpredictable results
Date: 28 May 2003 14:06:52
Message: <XZ6Z4EABqP1+EwaS@econym.demon.co.uk>
>  prism {
>    conic_sweep
>    linear_spline
>    0.85, // height 1
>    1, // height 2
>    scale <1, 4, 1>
If you can't work it out, yo could try using trace() to find the
position of the base and then translating it by that amount in the
opposite direction.
#declare Thing =
  prism {
    conic_sweep
    linear_spline
    0.85, // height 1
    1, // height 2
    scale <1, 4, 1>
object {Thing translate -trace (Thing, <0,-100,0>, <0,1,0>)}
In this case, the distance to translate downwards is equal to the Y
coefficient of the scale. So for a scaling of <1,4,1> you translate by
<0,-4,0>.
Mike Williams
Gentleman of Leisure
Date: 28 May 2003 17:21:30
Message: <3ed5285a@news.povray.org>
"Mike Williams" <mik### [at] econymdemoncouk> wrote in message
news:XZ6Z4EABqP1+Ewa### [at] econymdemoncouk...
> If you can't work it out, you could try using trace()
Good idea. However, this is a problem about transformation order.
By putting translate before scale is making -0.85*y move by four times, so
what's needed is the common scale, rotate, translate ordering to keep that
from happening. Doing so makes it like this: "height 2" is at 1*y (the
ever-widening conic sweep shape's top, starting from a point at 0 regardless
of "height 1"), becoming 4*y next, then turned upside down to become -4*y,
and finally moved upward by 4*y.
  prism {
    conic_sweep
    linear_spline
    .85, // height 1
    1, // height 2 [is +y*1 here]
    scale <1, 4, 1> // will move height 2 by this multiple
    rotate <180, 0, 0> // upside-down
    translate <0, 4, 0> // final move to 0*y
    pigment { gradient y scale .201 }
Please notice that the pigment scaling here is to circumvent pattern/surface
alignments, since it would have created unwanted artifacts where the object
and pattern are equally positioned. Reason in this case: 4 times 0.15 equals
0.6, making exactly 3 repeats of the gradient.
Curious thing about this though is that I had thought all such patterns were
changed to shift them slightly to stop this from happening. I know the
'checker ' pattern was, anyway. Oh well, something to think about again.
Bob H.
Date: 29 May 2003 15:10:02
Message: <web.3ed65aae162ba84e738e706a0@news.povray.org>
Mike Williams wrote:
>If you can't work it out, yo could try using trace() ...
Sounds interesting;  when I tried to search the index of the Windows Help on
it, I found references to Max_Trace_Level, and general ray tracing stuff,
but not where this particular command/function/macro/whatever is documented
in more depth.  A pointer, please?  Thanks
Date: 29 May 2003 15:20:01
Message: <web.3ed65d3e162ba84e738e706a0@news.povray.org>
Never mind, found it! Thanks.
