POV-Ray : Newsgroups : povray.newusers : Stains Server Time
6 May 2026 07:41:31 EDT (-0400)
  Stains (Message 1 to 4 of 4)
Subject: Stains
Date: 30 Sep 2002 12:15:08
Message: <web.3d9877d4c1649b9311db98c50@news.povray.org>
What would be the best way to create water stains on a surface? I haven't
been able to find any way to locate them in a specific location; it seems
to me that the best way will be an image maps, but I'd rather generate
them, since I want it to be different stains down a tunnel - many blocks,
many stains, which will be tiresome to create as an image map.
Thanks!
Jkior
Subject: Re: Stains
Date: 30 Sep 2002 12:25:03
Message: <chrishuff-ABC9AC.12222130092002@netplex.aussie.org>
In article <web.3d9877d4c1649b9311db98c50@news.povray.org>,
It depends what exactly you want...just a mark from the water level
being higher in the past than it is now? Use a gradient pattern with
some turbulence. Marks from water dripping and running down a wall? A
bit more difficult, an image map would give the most control, but you
could do it with a function pattern or even an object pattern with a bit
of turbulence. The object pattern will always give a sharp edge though,
with no soft edges or differences in color from distance to the stain
edge.
http://tag.povray.org/
Subject: Re: Stains
Date: 6 Oct 2002 22:30:06
Message: <web.3da0f0e5e389b6f1ebbd77600@news.povray.org>
>edge.
>Christopher James Huff <cja### [at] earthlinknet>
>http://home.earthlink.net/~cjameshuff/
>POV-Ray TAG: chr### [at] tagpovrayorg
I'd like water stains leaking around concrete blocks - so sharp edges won't
be a problem. However, I can't seem to be able to find anything in the
documentation explaining object patterns - "object" and "patterns" are the
ultimate in non-specific search terms in the pov docs. If object patterns
won't work, however, how will it be possible to wrap an image map around
the inside of a toroid (CSG) - a curving tunnel, circular in cross section?
Thanks!
Jkior
Subject: Re: Stains
Date: 6 Oct 2002 23:29:19
Message: <chrishuff-63FD86.23260006102002@netplex.aussie.org>
In article <web.3da0f0e5e389b6f1ebbd77600@news.povray.org>,
The object pattern uses one color/pigment/texture for any points inside
the object, and another for anything outside. Just look in the patterns
section of the reference. You could make a union of a lot of objects
representing all the stained areas, this would be simple but it could be
slow with a lot of objects. (insideness checking, which is what the
object pattern uses, is usually very fast, but it could pile up with
lots of objects)
Another possibility would be to use only the stain objects that affect a
specific block in the texture, so POV doesn't have to do the insideness
tests for the stains on the other side of the tunnel. This would use
more memory and would be a lot more complex, but would be faster.
> If object patterns won't work, however, how will it be possible to
> wrap an image map around the inside of a toroid (CSG) - a curving
I believe this is possible, there is a toroidal mapping available.
