POV-Ray : Newsgroups : povray.newusers : Cube in different colors ? Server Time
6 May 2026 07:41:03 EDT (-0400)
  Cube in different colors ? (Message 1 to 10 of 13)
Subject: Cube in different colors ?
Date: 10 Sep 2002 12:30:06
Message: <web.3d7e1dbe52cba467df9f5c610@news.povray.org>
Hi! I am new with povray and wanted to render a box where the 6 sides are in
different colors. Is there a way to manipulate the box object, or do i have
to draw the 6 sides as 6 single boxes (CSG). Maybe UVmapping ?
I think this is not a very difficult question. PLEASE HELP.
Subject: Re: Cube in different colors ?
Date: 10 Sep 2002 12:44:36
Message: <3d7e2173@news.povray.org>
  UV-mapping could be a way to do it if you can come up with a pattern
of the form described in chapter 6.7.7.1. I can't think of an easy way
of doing this right now...
  You could do it with six boxes, but that's not the only option.
  Using the intersection of six planes gives you a true box (which is
also usable in CSG) but can be a bit slower. You should definitely
remember to bound this "box" with a true box of the same size
(see bounded_by docs).
  You can also use the polygon or triangle primitives (the latter could
be inside a mesh, taking a bit less memory, I think), and it would be
faster to render but not usable in CSG (even though with a mesh you
can use inside_vector).
Date: 10 Sep 2002 17:26:44
Message: <chrishuff-5A612C.17251710092002@netplex.aussie.org>
In article <3d7e2173@news.povray.org>, Warp <war### [at] tagpovrayorg>
My feeling is that this would be the fastest way. You may have to tell
POV not to ignore your bounding, though.
I don't know if you meant this, but that last paragraph implies that a
mesh box would be unuseable in CSG. If he uses inside_vector, it will be
useable for CSG operations.
http://tag.povray.org/
Date: 10 Sep 2002 21:43:06
Message: <3D7EA09E.DEC45C3E@pacbell.net>
Works quite well actually :)
// Macro for creating a basic box object using triangles
#macro Box_Mesh(Vec1,Vec2)
#if (Vec1.x=Vec2.x | Vec1.y=Vec2.y | Vec1.z=Vec2.z)
#debug "\n  MeshBox detected identical vector values.\n" #end
#local P1=<Vec1.x, Vec1.y, Vec1.z>;
#local P2=<Vec2.x, Vec1.y, Vec1.z>;
#local P3=<Vec2.x, Vec1.y, Vec2.z>;
#local P4=<Vec1.x, Vec1.y, Vec2.z>;
#local P5=<Vec1.x, Vec2.y, Vec1.z>;
#local P6=<Vec2.x, Vec2.y, Vec1.z>;
#local P7=<Vec2.x, Vec2.y, Vec2.z>;
#local P8=<Vec1.x, Vec2.y, Vec2.z>;
mesh {
       triangle { P5, P1, P2 texture {T1} }
       triangle { P5, P6, P2 texture {T1} }
       triangle { P6, P2, P3 texture {T2} }
       triangle { P6, P7, P3 texture {T2} }
       triangle { P7, P3, P4 texture {T3} }
       triangle { P7, P8, P4 texture {T3} }
       triangle { P8, P4, P1 texture {T4} }
       triangle { P8, P5, P1 texture {T4} }
       triangle { P8, P5, P6 texture {T5} }
       triangle { P8, P7, P6 texture {T5} }
       triangle { P4, P1, P2 texture {T6} }
       triangle { P4, P3, P2 texture {T6} }
       inside_vector <0, 0, 1>
default { finish { ambient .4 diffuse .6 } }
#declare T1 = texture { pigment { rgb<1,0,0> }}
#declare T2 = texture { pigment { rgb<0,1,0> }}
#declare T3 = texture { pigment { rgb<0,0,1> }}
#declare T4 = texture { pigment { rgb<1,1,0> }}
#declare T5 = texture { pigment { rgb<1,0,1> }}
#declare T6 = texture { pigment { rgb<0,1,1> }}
// Usage
camera{location<-4,4,-4> look_at 0}
light_source{<-5,5,-5>rgb 1}
difference
  Box_Mesh ( <-1,-1,-1>, <1,1,1> )
  cylinder { z*-1.1, z*1.1, .75 pigment { rgb 1 }}
Ken Tyler
Date: 10 Sep 2002 23:37:37
Message: <3D7EBB75.342E8017@pacbell.net>
With limitations. From some tests I just ran it appears the mesh must be
the top level object in the csg operation. If used a secondary object
in a csg it does not work as expected. I wonder if an outside_vector
operator is needed to define the outside of a mesh object as opposed
to the inside?
Ken Tyler
Date: 11 Sep 2002 00:08:19
Message: <Xns92863DC0CA432raf256com@204.213.191.226>
"gam### [at] gmxnet" <gam### [at] gmxnet> wrote in
news:web.3d7e1dbe52cba467df9f5c610@news.povray.org
> are in different colors. Is there a way to manipulate the box object,
> or do i have to draw the 6 sides as 6 single boxes (CSG). Maybe
> UVmapping ?
hmm interesting, I was just about to send identical question here...
maybe telepatic ;) ?
so finaly - with method is the fastest ?
maybe some union/merge/intersection of planes ?
Date: 11 Sep 2002 05:42:41
Message: <3d7f1011@news.povray.org>
  I think that POV-Ray only removes user-defined bounding boxes when it
(thinks it) can make a better one itself. However, for planes it doesn't
create bounding boxes at all (because they are infinite) and thus should
not remove the user-defined one. I haven't tried it, though.
  Well, yes. That's what I meant (could have worded it better, though).
  A mesh by itself is not usable in CSG, but if you add inside_vector to
it, then it is.
Date: 11 Sep 2002 05:44:12
Message: <3d7f106b@news.povray.org>
  I remember that this bug was found months ago. I wonder if anyone made
a proper post at p.bug-reports... (if not, someone should).
Date: 11 Sep 2002 05:58:58
Message: <8k4unuk183qmnfaropqo2aql15vu989oai@4ax.com>
> to the inside?
I wonder if it could be becouse of feature described recently in some posts.
All_intersections method for meshes returns only first intersection. I don't
know how intersection test for csg is written but for sended ray mesh looks
like plane so it can behave strange in some cases.
ABX
Date: 11 Sep 2002 07:50:32
Message: <3d7f2e08@news.povray.org>
  I made a test with boxes made of planes, polygons and a mesh (with
differently colored sides) and compared their rendering speed
(-w800 -h600 +a0.1) by randomly placing 500 of them in the scene.
The render times were:
Planes:   75 s
Polygons: 80 s
Mesh:     63 s
  Seems like the mesh wins.
  This is the scene:
// 1: Planes
// 2: Polygons
// 3: Mesh
#declare BoxType = 1;
#declare Amount = 500;
#macro FixCorners(Corner1, Corner2)
  #local X1 = Corner1.x; #local X2 = Corner2.x;
  #local Y1 = Corner1.y; #local Y2 = Corner2.y;
  #local Z1 = Corner1.z; #local Z2 = Corner2.z;
  #if(X1 > X2) #local tmp = X1; #local X1 = X2; #local X2 = tmp; #end
  #if(Y1 > Y2) #local tmp = Y1; #local Y1 = Y2; #local Y2 = tmp; #end
  #if(Z1 > Z2) #local tmp = Z1; #local Z1 = Z2; #local Z2 = tmp; #end
  #local Corner1 = <X1, Y1, Z1>;
  #local Corner2 = <X2, Y2, Z2>;
#macro PlaneBox(Corner1, Corner2, T1, T2, T3, T4, T5, T6)
  #local C1 = Corner1+<0,0,0>;
  #local C2 = Corner2+<0,0,0>;
  FixCorners(C1, C2)
  intersection
    plane { -x, -C1.x texture { T1 } }
    plane {  x,  C2.x texture { T2 } }
    plane { -y, -C1.y texture { T3 } }
    plane {  y,  C2.y texture { T4 } }
    plane { -z, -C1.z texture { T5 } }
    plane {  z,  C2.z texture { T6 } }
    bounded_by { box { C1, C2 } }
#macro PolygonBox(Corner1, Corner2, T1, T2, T3, T4, T5, T6)
  FixCorners(C1, C2)
  union
    polygon
    { 5, C1, <C1.x, C1.y, C2.z>, <C1.x, C2.y, C2.z>, <C1.x, C2.y, C1.z>, C1
      texture { T1 }
    polygon
    { 5, C2, <C2.x, C2.y, C1.z>, <C2.x, C1.y, C1.z>, <C2.x, C1.y, C2.z>, C2
      texture { T2 }
    polygon
    { 5, C1, <C2.x, C1.y, C1.z>, <C2.x, C1.y, C2.z>, <C1.x, C1.y, C2.z>, C1
      texture { T3 }
    polygon
    { 5, C2, <C1.x, C2.y, C2.z>, <C1.x, C2.x, C1.z>, <C2.x, C2.y, C1.z>, C2
      texture { T4 }
    polygon
    { 5, C1, <C2.x, C1.y, C1.z>, <C2.x, C2.y, C1.z>, <C1.x, C2.y, C1.z>, C1
      texture { T5 }
    polygon
    { 5, C2, <C1.x, C2.y, C2.z>, <C1.x, C1.y, C2.z>, <C2.x, C1.y, C2.z>, C2
      texture { T6 }
#macro MeshBox(Corner1, Corner2, T1, T2, T3, T4, T5, T6)
  FixCorners(C1, C2)
  mesh2
    vertex_vectors
    { 8,
      <C1.x, C2.x, C1.z>, <C2.x, C2.y, C1.z>, C2, <C1.x, C2.y, C2.z>
    texture_list
    { 6,
      texture { T1 }, texture { T2 }, texture { T3 },
      texture { T4 }, texture { T5 }, texture { T6 }
    face_indices
    { 6*2,
      <0, 3, 7>, 0, <0, 7, 4>, 0,
      <1, 5, 6>, 1, <1, 6, 2>, 1,
      <0, 1, 2>, 2, <0, 2, 3>, 2,
      <4, 7, 6>, 3, <4, 6, 5>, 3,
      <0, 4, 5>, 4, <0, 5, 1>, 4,
      <3, 2, 6>, 5, <3, 6, 7>, 5
camera { location <4,10,-20>*2 look_at 0 angle 35 }
light_source { <100,200,-150>, 1 }
#declare T = array[6]
  pigment { rgb 1 },
  pigment { rgb x },
  pigment { rgb y },
  pigment { rgb z },
  pigment { rgb x+y },
  pigment { rgb y+z },
#declare Box =
  #switch(BoxType)
    #case(1)
      PlaneBox(-1, 1, T[0], T[1], T[2], T[3], T[4], T[5])
    #break
    #case(2)
      PolygonBox(-1, 1, T[0], T[1], T[2], T[3], T[4], T[5])
    #break
    #case(3)
      MeshBox(-1, 1, T[0], T[1], T[2], T[3], T[4], T[5])
    #break
#declare S = seed(1);
#declare Ind = 0;
#while(Ind < Amount)
  object
  { Box
    rotate <rand(S)*360, rand(S)*360, rand(S)*360>
    translate (<rand(S),.5,rand(S)>-.5)*50
  #declare Ind = Ind+1;
