POV-Ray : Newsgroups : povray.newusers : Newbie question about the light_source function. Server Time
30 Mar 2026 07:31:08 EDT (-0400)
  Newbie question about the light_source function. (Message 11 to 14 of 14)
Subject: Re: Newbie question about the light_source function.
Date: 9 Nov 2003 22:06:30
Message: <matt-pace-2FB775.19062909112003@netplex.aussie.org>
In article <cja### [at] netplexaussieorg>,
 Christopher James Huff <cja### [at] earthlinknet> wrote:
> You have a lot of lights, and they are all using full-brightness colors.
> Colors are composed of 3 float values, one for each of red, green, and
> blue. Although internally their range is practically unlimited, they are
> clipped to the range [0, 1] for output. A value of 1 is full brightness,
> and going higher will not have any effect. If you have 100 green lights
> and 2 red lights, it won't matter how much more brightly lit in green
> the surface is. A point lit with < 2, 100, 0> will appear to be < 1, 1,
> 0> yellow. Basically, you just need to drastically reduce the brightness
> of your lights, and probably should use distance fading as well. And you
> should seriously look at whether all those lights are necessary...it
> looks like you may be trying to make area lights.
I thought that I read somewhere that a light defined as color rgb 2
would be white, but twice as bright as normal.  Is this true?  Did
anyone else read this? Am I insane?  I didnt think this was possible, as
the light could only get so bright, but please put my doubts to rest.
Thanks
Date: 9 Nov 2003 22:59:29
Message: <cjameshuff-9A71BA.22580509112003@netplex.aussie.org>
In article <mat### [at] netplexaussieorg>,
Well, I pretty much just said so, though not using that specific
example. It is white and twice as bright as rgb < 1, 1, 1>. Your monitor
can only display colors with a limitedd range of brightness and most
file formats only store percentages of maximum brightness rather than
absolute brightness, so the colors are clipped at output. There is no
difference in the final output between a color that the camera saw as <
2, 7, 1> and one that was only < 1, 1, 1>.
http://tag.povray.org/
Date: 10 Nov 2003 03:34:02
Message: <3faf4d7a$1@news.povray.org>
de news: cja### [at] netplexaussieorg...
Your monitor
But pixels colors are computed from light color>fade due to distance>object
pigment/diffuse properties... so not inevitably clipped.
If you want maximum dynamic range in your image (i.e white highlights and
black most dark shadows) you can multiply your light color.
Marc
Date: 10 Nov 2003 08:47:07
Message: <cjameshuff-48A936.08454510112003@netplex.aussie.org>
In article <3faf4d7a$1@news.povray.org>,
 "Marc Jacquier" <jac### [at] wanadoofr> wrote:
> Your monitor
Distance fading is off by default and scenes usually have at least some
pigment/diffuse properties that come close to white.
By what?
Yes, you can pack more information into the output image by making sure
the lighting is dark enough that clipping is minimized, and then
post-processing the scene to get the normally lit portions (which are
now very dark because of the light scaling) to show up right. However,
this has bad precision effects...a 24-bit image has 8 bits per color
component. That's 256 levels from black to 100% intensity. If you use
100% to mean 2x max viewable intensity, you've just limited the normal
[0, 1] range of lighting to 128 levels of intensity. If 100% means 10x
max viewable intensity, you limit it to 25 levels.
You could render multiple images at different color scales and combine
their data, but your best bet is to just use a patch that adds a high
dynamic range output format.
