POV-Ray : Newsgroups : povray.newusers : distorting superellipsoid Server Time
3 May 2026 17:18:19 EDT (-0400)
  distorting superellipsoid (Message 1 to 4 of 4)
Subject: distorting superellipsoid
Date: 31 Mar 2004 14:45:56
Message: <Xns94BDDD67DA42EehmdjiiNOSPAMgmxnet@203.29.75.35>
hello,
i want to make a prism like shape, but with rounded edges.
so i thought i could make a superellipsoid and distort it with matrix<...>.
it should look like the tip of an arrow, only with rounded edges.
thanks if anyone can help me out with some code, cause i cant do matrix
<...> at all.
Subject: Re: distorting superellipsoid
Date: 1 Apr 2004 07:02:28
Message: <406c04d4@news.povray.org>
  You can only apply linear transformations to an object.
  A linear transformation is a quite limited set of all possible
transformations. In short, when you apply a linear transformation to
an object, all lines in the object which were parallel before the
transformation will be parallel after the transformation. Only these
type of transformations are possible.
  This is not an artificial nor arbitrary limitation. There are
unsurmountable technical reasons why only these transformations are
possible.
  So what you are trying to do is not possible with matrix nor any other
transformation. You'll have to do it by other means (either by modelling
the shape you want explicitly, eg. with a mesh or other similar primitives,
or making an isosurface shaped like you want, which requires a bit of math).
Date: 1 Apr 2004 11:17:00
Message: <Xns94BEB9FB77E01ehmdjiiNOSPAMgmxnet@203.29.75.35>
Warp <war### [at] tagpovrayorg> wrote in news:406c04d4@news.povray.org:
>   other
> modelling the shape you want explicitly, eg. with a mesh or other
> similar primitives, or making an isosurface shaped like you want,
thank you!
i tried modeling it in Wings3D.
but im not sure how to make rounded edges besides beveling.
also, some things look poor when i render it in pov. polygons have
artifacts because the normals at the edges have other angles.
Date: 1 Apr 2004 11:40:01
Message: <406c45e1@news.povray.org>
  Try reading this:
http://tag.povray.org/povQandT/SmoothTriangleArtifact/
