POV-Ray : Newsgroups : povray.newusers : Where did THAT come from...? Server Time
24 Jun 2026 21:59:49 EDT (-0400)
  Where did THAT come from...? (Message 11 to 13 of 13)
Subject: Re: Where did THAT come from...?
Date: 26 Mar 2014 13:14:39
Message: <53330aff$1@news.povray.org>
Thanks, Kenneth,
I didn't change the +q[n] setting.
I just added the default directive and then commented it back out.
maybe
#default {pigment {rgb <1,1,0>} finish {ambient 1} }
needs to be
#default {texture {pigment {rgb <1,1,0>} finish {ambient 1} } }
I don't have any orthographic cameras in my scene... yet.
I would however like to see if I could do a smooth transition from an
orthographic camera to a regular perspective camera, and the camera
definitions and behaviours are beyond my ken at this stage of the game.
Once I get the bulk of what I want defined in my scene, then I'll
probably start doing camera experiments and learning some nice animation
skills.
I'll see what I can do with the scene SDL - it's only about 2000 lines
so far, scene, subscene, and include file all together.
I have to rotate and translate my whole subscene to where I want it.
Do you have any clever suggestions for calculating where things should
actually be in my final scene if I copy and paste it all into the big
scene and then correct the coordinates?  I'm thinking spreadsheet...
Thanks for all your help,
Bill
Date: 26 Mar 2014 15:55:01
Message: <web.53332f7fba522c12c2d977c20@news.povray.org>
Bald Eagle <cre### [at] netscapenet> wrote:
> maybe
> needs to be
Nope, not really necessary. For example, you could, if you wanted to, simply
write...
#default{finish{ambient .5 diffuse .5}}
....which would attach only a *finish* to an object (one that doesn't already
have an explicitly-stated finish, that is.) The 'texture' wrapper isn't
mandatory in a #default statement. In fact, it's not mandatory in an OBJECT
either-- but it's  'good coding practice' to do so, in my opinion... especially
if you decide to add *multiple* overlaid textures to an object; otherwise,
you'll get error messages. To be honest, I rarely use #default{...} in my
scenes; just a personal preference. I like to add full textures to my objects as
I build them. But for quickly creating the basics of a scene-- without worrying
about textures just yet-- #default is certainly useful.
By the way: I hope I didn't confuse you further with my quick-and-dirty
example...
box{
texture{pigment{rgb <.5,.3,.1>}finish{ambient .3 diffuse .7}}
The box needs a size, of course-- like  box{<0,0,0>,<1,1,1>...
Without seeing your code, that would be difficult. My suggestion: Experiment!
It's the best way to find out how things work in POV-Ray; even making mistakes
is beneficial! As the saying goes, "Rome wasn't built in a day!" ;-)
Date: 27 Mar 2014 19:13:03
Message: <5334b07f@news.povray.org>
>>>> #default{pigment{rgb<1,1,0>}finish{ambient 1}}
>>>> If you now have a bright magenta box, you know that you have an object
>>>> that don't have any pigment.
>> That makes the box bright Yellow.
>> And jacks up the ambient value of everything in the scene. Whoa.
> If you're using 'quality 0' to test the scene, then all ambient values will
> indeed appear to be maxed out (regardless of using the #default stuff.) Maybe
> that's what's visually confusing. Quality 0 adds no color shading or lights-- or
> much of *anything* except the full rgb color of the objects.
> Also, the #default{pigment{rgb<1,1,0>}finish{ambient 1}} will *only* be imposed
> on objects that do not already have an explicitly-stated pigment and finish. In
> other words, it will not change anything in the following example:
> box{
> although it might change the FINISH in this example (I'm actually not sure,
> without trying it myself)...
> box{
> texture{pigment{rgb <.5,.3,.1>}} // no explicit finish here
For any texture that don't set a finish, or when you use only a pigment,
you get to use the default finish. Also, if your finish don't
explicitely set some finish parameter, the corresponding parameter from
the default will be used.
So, if you have #default{finish{ambient 1}}, any texture or plain
pigment will use ambient 1.
Another somwhat core complex example:
#defaut texture{pigment{rgb<1,0,1>}finish{ambient 0 emission 0.2 diffuse
albedo 0.7 brilliance 2 reflection{1 fresnel} specular albedo 0.7
roughness 0.1}}
This finish will be used UNLESS you explicitely set it to something
else, AND any finish parameter that is not explicitely set will use
those set in the #default directive.
