POV-Ray : Newsgroups : povray.newusers : Animation Question Server Time
4 Jul 2026 20:31:32 EDT (-0400)
  Animation Question (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Animation Question
Date: 30 Jan 2002 17:14:46
Message: <3C588D22.60006@txcyber.com>
To John and TinCanMan,
Thanks for the help guys. Now I just have to work out the positions for
the different frames.
Les
Les Patterson wrote:
> When writing the .INI file for an animation, and you want to tell Pov to
> save each rendered image in the animation as a different file name, the
> tutorial in v3.5 is not very clear on how to do this.
>  Would the line read something like;
> Initial_Output_File_Name = "Frame1.pov"
> Final_Output_File_Name = "Frame50.pov"
> and does this tell pov to save all the files in between in numerical order?
> Also is the line for the output path something like this;
> Output_File_Path = C:\My Documents\Animations?
> Any help is appreciated,
> Les
Date: 30 Jan 2002 17:50:22
Message: <3c5878ae@news.povray.org>
"Les Patterson" <les### [at] txcybercom> wrote in message
news:3C5### [at] txcybercom...
Hopefully you're not making it out to be more difficult than it really is,
or barring that not thinking more can be done from the INI file than can
actually be.
The most basic way of animating in POV-Ray is fairly straightforward once
you have a INI with the keywords for Final_Clock=Number and
Final_Frame=Number (frames are integer) in the file (or +kfNumber and
+kffNumber on command line).  And of course a few other options possible
too.
The rest is all about using the 'clock' keyword in your scene file as a
variable which is based on the number of frames (and Intitial_Clock,
Final_Clock values if different from defaults of 0 to 1).  That way all you
do is imagine it is a changing number going from start to finish that you
can apply to other things within the scene.  You won't get differing prefix
names, only a frame count.  The prefix defaults to the scene file being
rendered, if you only specify a path otherwise it will take the filename you
give as Output_File_Name=.  Like I am trying to clarify here, you cannot
change that during animation unless you change the INI file prior to each
successive render.
Maybe I'm oversimplifying and going off the track of your question, just
wanted to be sure.
bob h
Date: 30 Jan 2002 18:59:16
Message: <3C58A59F.3090608@txcyber.com>
Bob,
  This is the file I plan to use;
Antialias=Off
Antialias_Threshold=0.1
Antialias_Depth=2
Input_File_Name=Fly.pov
Output_File_Path=C:\My Documents\PovAnimation
Initial_Frame=1
Final_Frame=50
Initial_Clock=0
Final_Clock=1
Cyclic_Animation=on
Pause_when_Done=off
Will this work?
Les
This animation will be an aircraft flying around in the scene, but so
far I haven't been able to get the object rotation values to work right.
> actually be.
> too.
> successive render.
> wanted to be sure.
> bob h
Date: 31 Jan 2002 02:14:49
Message: <3C58EE8D.9070906@tiac.net>
That should work. Sometimes I'll set up the clock
and frames so that it's easier to figure out.
I might do something like this:
Initial_Frame=0
Final_Frame=49
Initial_Clock=0
Final_Clock=0.49
This way there's still 50 frames and the clock is
set equal(well, sort of)to each frame.
Are you using Chris Colefax's "Clock Modifier"? It
really makes animating easier IMHO.
http://www.geocities.com/SiliconValley/Lakes/1434/clockmod.html
Phil
Behold, for I am the keeper of the sacred coffee brewing method.
Date: 31 Jan 2002 10:09:32
Message: <3C597AF8.1040501@txcyber.com>
Phil,
  Thanks for the info and the code. I have read a little about Chris
Colefax's "Clock Modifier" a short time ago, but haven't tried it yet. I
will check it out today.
Thanks again,
Les
> Initial_Frame=0
> Final_Frame=49
> Initial_Clock=0
> Final_Clock=0.49
Date: 31 Jan 2002 11:11:16
Message: <3c596ca4@news.povray.org>
> Antialias=Off
> Antialias_Depth=2
> Initial_Frame=1
> Final_Frame=50
> Initial_Clock=0
> Final_Clock=1
> Cyclic_Animation=on
> Pause_when_Done=off
> Will this work?
> Les
A bit delayed response from me but there isn't a Output_File_Path= (unless
someone added it without me realizing it. No, I checked the v3.5 docs, there
isn't).  You use Output_File_Name= for the path and leave off the file name
if you just want the scene file name to prefix onto the frame files.  Or you
can use the full path plus name different from your scenes name too.
Output_File_Name=C:\My Documents\PovAnimation\
or
Output_File_Name=C:\My Documents\PovAnimation\fly.pov
is what you want to be using.
bob h
Date: 31 Jan 2002 11:26:44
Message: <3c597044@news.povray.org>
Most important thing to remember is that when the keyword clock is used as a
variable in your scene it is just the number incrementing as set in INI as
Intitial_Clock=0 to Final_Clock=1 (or by default 0 to 1 if not set).
Cyclic_Animation=On will truncate that so the start and end is not repeated
and is only one frame for both.
Your airplane, if going in a circle for example, might be like:
object
    Airplane
        // do any reorienting here first, scales, rotates, translates
        // then do the following things
        translate 10*x // offset from center
        rotate clock*360*y // 360 degrees
And of course you need the nose/tail pointing -/+ z to begin with for this
example to work right.
I might as well point out now rather than later that getting all the
orientations done ahead of the final motion is paramount to things going the
way you expect; otherwise, if you try reorienting the wing tilt after the
circle rotation move you'll end up with a airplane going up and/or down
instead of a level orbit with tilting wings.
As Phil suggested that Clock Modifier really helps with non-uniform motion
too, just got to get the animation basics figured right.
bob h
Date: 31 Jan 2002 17:39:34
Message: <3C59E472.8030508@txcyber.com>
Bob,
  Thanks for your help in both replies.
Here are the object and camera coordinates that I'm working with right now.
camera location <0, 15, -6>
        look_at < 0, 15, 0>
object position #1 <8, 12, -8>//starting position
        position #2 <-45, 12, 50>//crossing from right to left in front
of camera as it travels into the distance.
        position #3 < 0, 50, 60>
        position #4 <45, 12, 50>//pos#2, #3 & #4 should make an arch
going across from left to right.
        position #5 <-8, 12, -8>//ending the path just outside of camera
view on left.
I understand how to use (From, Using, & To) for the movements, but the
spline/path is giving me problems now. Also, if I can figure out the
spline coordinates, I might just close the end of the path closest to
camera and have a full figure8, keeping everything in front of the
camera. I can get straight lines and curved lines but now crisscrossing
lines or figure 8 yet.
Thanks again for the help,
Les
>> Antialias=Off
>> Antialias_Depth=2
>> Initial_Frame=1
>> Final_Frame=50
>> Initial_Clock=0
>> Final_Clock=1
>> Cyclic_Animation=on
>> Pause_when_Done=off
>> Will this work?
>> Les
> or
> bob h
Date: 1 Feb 2002 11:48:10
Message: <3c5ac6ca@news.povray.org>
> Bob,
Welcome to whatever I can manage to help with.
> camera. I can get straight lines and curved lines but no crisscrossing
That movement you have set up is probably uneven.  The spline path will yank
the airplane around through it as though on the end of a snapping whip, well
what I mean is that the interploation of points between won't be very
steady.  Of course you would like acceleration and deceleration I'm sure but
you must be careful how you set the points up.  The spacing between them
should relate to speed, i.e. shorter spacings are slower and longer spacings
are faster.  There's been a lot done in the way splines are calculated
within POV-Ray but Chris Colefax's generator macro is external and I can't
remember how it goes about it.  Would be obvious once you've rendered out
the animation and viewed it.
3D graphing paper (nonexistant I guess :-)) would be perfect for planning
such things out.  A figure-8 wouldn't be a problem anyway, it shouldn't
tangle up.  ;-)
bob h
Date: 1 Feb 2002 15:02:27
Message: <3C5B1122.7060406@txcyber.com>
Bob,
  I'm still pretty new at Pov and it takes time for some of these things
to set in to the old brain. Old age I guess. I'm going to play with the
spline points for a while till I get it all worked out.
  Thanks again for your help,
Les
>> Bob,
> tangle up.  ;-)
> bob h
