POV-Ray : Newsgroups : povray.newusers : Animation Server Time
6 May 2026 16:02:10 EDT (-0400)
  Animation (Message 1 to 8 of 8)
Subject: Animation
Date: 4 Aug 2001 20:12:23
Message: <3b6c8f67@news.povray.org>
What is the simplest way to set POV-Ray to render the frames of the
animation and how to use the keyword clock?
I read the documentation but I just can't get right.
Subject: Re: Animation
Date: 4 Aug 2001 21:20:48
Message: <3b6c9f70@news.povray.org>
"Renato Oliveira" <war### [at] bolcombr> wrote in message
news:3b6c8f67@news.povray.org...
The very simplest form would go something like this (for Windows platform).
Your pov scene file contains the following, for example:
light_source {<10,10,-10>,1}
camera {location -5*z look_at 0}
box {-1,1 pigment {rgb 1} rotate clock*360}
That sort of tumbles the box primitive in all 3 axes, or you could choose
one as in clock*360*y.  The 360 is degrees and for a full rotation.  The
basic idea is clock will run from one number to the next interpolating
inbetween depending on what values you gave for them.   But wait!  To get it
going you still must do the next step.
Press the Ini button on the toolbar and type +ki0.0 +kf1.0 +kfi1 +kff10 into
the Command field then render.  Then press Render.  The animation frames (#1
thru #10) will output to your default folder (directory) having clock going
from 0 to 1.
Alternatively, and the best thing to do IMHO, use a ini file to set up the
whole thing with all the parameters you might need.  You can create one in
POV's editor and save as animate.ini into the \POV-Ray\renderer\ folder,
opening it for use with a scene file later via that Ini button.
The ini syntax is Initial_Clock=0.0 Final_Clock=1.0 Initial_Frame=1
Final_Frame=10 (each on their own line).  Once you learn more about it you
can add/change things, just read about it in the Output Options|Animation
section of the Scene help doc.
Bob H.
Date: 4 Aug 2001 22:01:26
Message: <3b6ca8f6@news.povray.org>
Bob H. <omn### [at] msncom>
I think I got now, but just one more question: the "Initial_frame" and
"Final_frame" that defines how long the animation will last?
Date: 4 Aug 2001 22:10:48
Message: <3B6CABCD.15905B0B@pp.htv.fi>
You will get Final_frame-Initial_frame+1 frames. If those are shown
at 30 fps the animation lasts frame_count/30 seconds.
_____________
Kari Kivisalo
Date: 5 Aug 2001 00:08:15
Message: <3b6cc6af@news.povray.org>
And if I want to make the cube starts rotating only in the frame 3, for
example what should I do?
Date: 5 Aug 2001 03:30:09
Message: <3b6cf601@news.povray.org>
news:3b6cc6af@news.povray.org...
choose
Definitely go get the Clock Modifier Macro (or the Include), it will allow
you to set up exactly such a thing by declaring a clock start and finish.
Not sure if there's a direct way to enter it by frame number using the macro
since I seldom use it but it's easy to do the math to get a clock value for
a frame, ie. Clock=FrameThree/TotalFrameCount
See  http://www.geocities.com/ccolefax/
Bob H.
Date: 5 Aug 2001 08:47:58
Message: <slrn9mqfs9.nt0.steve@zero-pps.localdomain>
>choose
Say I want something to start moving half way through the animation,
I tend to do something like:
object{
       Strobe
       #if(clock>0.5)
          rotate y*clock*135
          rotate x*clock*270
And here's how I animated the Strobe that's on my gallery page,
I havn't uploaded the animation as I havn't got round to converting it
to mpeg yet.
object{
       Strobe
       #if(clock<=0.333)
          rotate y*clock*135
          rotate x*clock*270
        #if(clock>0.333 & clock<=0.666)
           rotate y*clock*135
           rotate x*90
           rotate y*(clock-0.333)*270
        #if(clock>0.666)
           rotate y*clock*135
           rotate x*90
           rotate y*90
           rotate z*(clock-0.666)*270
        translate<0,5,10>
        photons{
                target 0.75
                refraction off
                reflection on
I wrote this a few years ago so the photon code is probably out of
date.  Hope some of that is useful.
  1:30pm  up 22 days, 15:33,  2 users,  load average: 1.03, 1.02, 1.00
Date: 5 Aug 2001 20:05:22
Message: <3b6ddf42@news.povray.org>
Steve <ste### [at] zeroppsuklinuxnet> wrote:
:        #if(clock>0.5)
:           rotate y*clock*135
:           rotate x*clock*270
:         #end
  Note that when you do this to "start something at a certain clock value",
you might want to use a "subclock" value which itself goes from 0 to 1
inside the subrange although the main clock value has other values.
  In this example the clock will "start" from 0.5 inside the block, which
is often not handy. You can do something like this:
  #if(clock>0.5)
    #local subclock = (clock-.5)*2;
  Of course using some of the clock macros out there would be easier. See
for example:
http://www.geocities.com/ccolefax/clockmod.html
