POV-Ray : Newsgroups : povray.newusers : Blobs and loops Server Time
6 May 2026 18:54:11 EDT (-0400)
  Blobs and loops (Message 1 to 7 of 7)
Subject: Blobs and loops
Date: 1 Jan 2001 07:22:22
Message: <3a50767e@news.povray.org>
Take the following fragment of code
$ XPos = 0;
$ ZPos =0;
#while(ZPos<100)
     #while(XPos<100)
            blob {
                     threshold .65
                            sphere{<XPos,0,ZPos>, 1, 1
pigment{rgb<.25,1,.25>}
                                        translate vturbulence (1.5, 3,
3,<XPos,0,ZPos>/33)
                                        translate x*-50
            #declare XPos = XPos + 1;
  #declare XPos = 0;
  #declare ZPos = ZPos+1;
How can I get all the blobs to bond together? I've tried putting the loop in
the blob statement but it seems to make no difference. I'm stumped, please
help
Mick
Subject: Re: Blobs and loops
Date: 1 Jan 2001 08:23:27
Message: <chrishuff-AA9834.08245301012001@news.povray.org>
In article <3a50767e@news.povray.org>, "Mick Hazelgrove"
Your loops are making many separate 1-component blobs. You need to put
the entire looping structure that generates the components inside the
blob{} block.
> I've tried putting the loop in the blob statement but it seems to
> make no difference. I'm stumped, please help
Hmm...maybe your threshold and components are making it look like they
aren't blobbing together...do you get a bunch of intersecting spheres,
or are they completely disconnected?
Christopher James Huff
Date: 1 Jan 2001 08:51:14
Message: <slrn9512ov.d1m.steve@zero-pps.localdomain>
>help
Here's the code for a blob that has a while loop in it.
I hope it makes some sence to you and explains what you
need to know to solve your problem.
 #local DogEar =
                 blob{
                      #local EarRot =0;
                      threshold 0.1
                        #while(EarRot <46)
                          sphere{<0,0.,0>, 0.125, 0.5  translate y*0.75 rotate
z*-EarRot}
                          #local EarRot = EarRot+2;
                      sphere{<0,0.,0>, 0.15, 0.75  translate y*0.75}
                      texture{finish{ToyFinish}
                              pigment{TreeTrunckColour}
                      scale <1,1,0.45>
                      rotate z*-110
                      scale <2.5,2.5,2.75>
  1:43pm  up 14 days,  1:04,  3 users,  load average: 1.19, 1.05, 1.01
Date: 1 Jan 2001 09:12:46
Message: <be215t8tkrf8h4jfoto944ii0ge8pjtjaa@4ax.com>
On Mon, 1 Jan 2001 12:28:47 -0000, "Mick Hazelgrove"
>help
Hi Mick,
Happy New year!
As Chris says, you are creating a lot of seperate blobs.  What you have to do is
have a single blob and have the loop within the blob.  I did this when I was
trying to create smoke for one of my locos.
This seems to work OK;
$ XPos = 0;
$ ZPos =0;
blob {
            threshold .65
              #while(ZPos<100)
              #while(XPos<100)
                sphere{ <XPos,0,ZPos>, 1, 1
                        translate vturbulence (1.5, 3,3,<XPos,0,ZPos>/33)
                        translate x*-50
                 #declare XPos = 0;
David
dav### [at] hamiltonitecom
http://hamiltonite.com/
Date: 1 Jan 2001 10:22:19
Message: <3a50a0ab@news.povray.org>
Thanks All
Mick
Date: 1 Jan 2001 10:24:45
Message: <3a50a13d@news.povray.org>
That's it
The threshold statement needed to be outside the while loop!
Thanks again
Mick
Date: 1 Jan 2001 10:39:51
Message: <3a50a4c7@news.povray.org>
You are creating 10000 blobs with one component each instead of one
blob with 10000 components. The difference is quite clear.
  See http://iki.fi/warp/PovVFAQ/whileloops.html for more details.
