POV-Ray : Newsgroups : povray.newusers : placing objects at intersections? Server Time
6 May 2026 08:57:25 EDT (-0400)
  placing objects at intersections? (Message 1 to 10 of 10)
Subject: placing objects at intersections?
Date: 28 Jul 2002 19:45:38
Message: <3D44821F.4C35DD5C@earthlink.net>
Is there a way to say place object a at the intersection of objects b
and c?
If there isn't, can anyone suggest how I can find the right equation for
the shape of a sphere scaled to 1.35 times longer in the y direction
than in the x?  I tried a parabola, but it came out too flat.
Subject: Re: placing objects at intersections?
Date: 28 Jul 2002 21:21:29
Message: <3d449899@news.povray.org>
> and c?
  If there would be an easy way, that would be great news for collision
detection.
  Unfortunately, I don't think there is any easy solution for the general
case.
Date: 28 Jul 2002 23:15:10
Message: <3D44B338.9040006@mac.com>
> case.
Maybe someone can help me with my math, then.
I have a sphere scaled to <40, 54, 9.2>.  I wanted to place a row of
holes along a parabolic surface that would match the curve of the elipse
in the XY plane.
I came up with f(x) = 0.04909(27.5-x)^2+37.125, which produces a
parabola that matches the x and y intercepts, but the sides are too flat.
I think if I could find a point that wasn't an intercept, I could come
up with a better parabolic model, but I don't know how to do that, short
of (extensive) trail and error.
Suggestions?  Anyone?
Date: 29 Jul 2002 00:39:16
Message: <3d44c6f4$1@news.povray.org>
I suppose you're using POV-Ray 3.5, so if you'd just
go ahead and look at 6.1.4.6 in the documentation,
(Vector Expressions), you'll find a vector function called
"trace".
It returns the intersection of a ray that comes from
a User-Given position, along a User-Given direction.
The correct setup of starting positions and directions
for the rays would result in what you want.
Its early morning now, so I'm not up to the math-part
of your question yet, but if you give some more specific
details, I could look at them when I'm back from work...
Tim
Tim Nikias
Email: Tim### [at] gmxde
> and c?
Date: 29 Jul 2002 01:56:01
Message: <web.3d44d8741b88da9b88d4e3910@news.povray.org>
>> case.
>in the XY plane.
Dawn,
Where did you derive your f(x)  equation from?
Is the general equation for this sphere
1= (  (x-Xo)/40  )^2 + ( (y-Yo)/54  )^2  +( (z-Zo)/9.2 )^2   where
(Xo,Yo,Zo) is the center of the sphere?
I tested this equation against a scaled sphere you cited and it
seemed to work.
If so, and if the center of the sphere is (0,0,0) and your XY plane is at
z=0, then the equation might boil down to
y= f(x) = sqrt{ [1-(x/40)^2] / [54^2]  }
Hope this helps,
Sorry if I misinterpreted something
Tony
ton### [at] xenomechanicscom
Date: 29 Jul 2002 02:50:08
Message: <n1p9kuocnvaph0n0hl6018dm6eqpl2qlph@4ax.com>
On Sun, 28 Jul 2002 16:45:35 -0700, Dawn McKnight <gru### [at] earthlinknet>
> and c?
Not ideal but can work.
#include "rand.inc"
#local A=object{...};
#local B=object{...};
#local C=object{...};
#local Generator=seed(100);
#local Intersection=intersection{object{B}object{C}};
object{ A translate VRand_In_Obj(Intersection,Generator) }
ABX
Date: 29 Jul 2002 10:17:36
Message: <chrishuff-1A4205.09103229072002@netplex.aussie.org>
In article <3D44821F.4C35DD5C@earthlink.net>,
> and c?
There is no way to guarantee that they intersect at a single point, and
if they did there wouldn't be a way to find that point reliably. You
could just look for a random point inside the intersection though, as
someone else suggested.
Not a parabola, an ellipsoid. Just a scaled sphere. I'm not sure what
you are trying to do, if you just want points on the sphere, use a
scaled sphere with the trace() function. If you want an isosurface, just
inversely scale the inputs to the sphere function.
Date: 29 Jul 2002 21:19:57
Message: <3D45E9B9.2040200@mac.com>
Tony LaVigne wrote:
> Dawn,
Hey, Tony.
First of all, let me sy thanks for your assistance... I'm really a math
idiot trying to make it in a big world.
My function is derived from the standard parabolic form y = a(x-h)^2 +k,
where h, k are the x, y coordinates of the vertex.  Since I want a
parabolic section (or an elipsoidal section) that matches the shape of
the outer edge, without actually being at the outside edge (in this
case, I want the x intercepts at +/- 27.5, y at 37.125), I find that the
  coordinates of the vertex are (0, 37.125).  Plug and chug, and you get
the equation I provided.
Uh... I'm not sure.  Is that right?  You're setting it equal to one?
Why not zero?  I'm confused.
I looked at the equation for the superquadratic elipsoid, which is in
the docs, but it doesn't look like yours, and I'm not math-knowledgeable
enough to get from one form to the other.
That's a reasonable aproximation, yes.
When I plot that on my graphing calculator, I get an elipsoid shape that
has the right x intercepts... but the y intercept is off by a factor of
a thousand.
I'm not clever enough to figure out how to correct it....
Date: 31 Jul 2002 10:01:12
Message: <pan.2002.07.31.14.01.10.128557.17877@iastate.edu>
On Mon, 29 Jul 2002 20:19:53 -0500, Dawn McKnight wrote:
> Tony LaVigne wrote:
>> Is the general equation for this sphere 1= (  (x-Xo)/40  )^2 + (
>> (y-Yo)/54  )^2  +( (z-Zo)/9.2 )^2   where (Xo,Yo,Zo) is the center of
>> the sphere?
> Uh... I'm not sure.  Is that right?  You're setting it equal to one? Why
What Tony has done is put your values into the general equation of an
ellipsoid: ( (x-x0)/a )^2 + ( (y-y0)/b )^2 + ( (z-z0)/c )^2 = 1.
The point x0,y0,z0 is the center and a, b, and c are the semiaxes (or
"radii") in the x, y, and z directions respectively.  (This equation
isn't actually *totally* general; it doesn't take into account the
possibility of rotations.)  The fact that it's equal to one arises from
geometric considerations.
The superquadric ellipsoid is a different beast.  :)
>> at z=0, then the equation might boil down to
> a thousand.
This was probably a typo... I think it should be
y = f(x) = 54 * sqrt( 1 - (x^2)/(40^2) )
Good luck!
	-Ed
Date: 31 Jul 2002 21:32:02
Message: <web.3d488ef11b88da9b88d4e3910@news.povray.org>
>Tony LaVigne wrote:
>> Dawn,
>Hey, Tony.
>a thousand.
I just realized the above was posted with the news group, below if my reply
to Dawn that night.  The way I understand it, Dawn wanted the equation of
an elipsiod that contained the points (27.5,0,0) and  (0,37.125,0) with the
center  at (0,0,0).
Thanks to Ed for  pointing out the below equation also assumes the
ellipsiod has not been rotated on any axis.
.....  My Calculus book is
at work so this is all from memory years ago.
Actually my equation from last night
can be in the form of
1= (  (x-Xo) ^2)/a + ( (y-Yo)^2)/b  +( (z-Zo)^2)/c
assuming is symetric about the origin then Xo=0, Yo=0, Zo=0;
yeilds
1=(x^2)/a +(y^2)/b +(z^2)/c
if we are on the xy plane where z= 0 then if
1 = (x^2)/a +(y^2)/b      we call equation Alpha
with (x,y) = (27.5,0), (0,37.125)
yeilds
1= (27.5^2)/a + 0
1 =  0   +(37.125^2)/b
implies
a = 27.5^2
b = 37.125^2
 therefor
y = sqrt( )
equation alpha is rearranged into
y = sqrt(b- (x^2)*b/a)
y = f(x) = sqrt( 37.125^2(1-(x^2)/(27.5^2)    )
more accurately this is symetric about the x and y axis, so there is the
other sister equation that is negitive
y = f(x) = -sqrt( 37.125^2(1-(x^2)/(27.5^2)    )
so the generic equation is
y = f(x) = +/-sqrt( 37.125^2(1-(x^2)/(27.5^2)    )
I plotted this out and it does have the intercepts at the correct place, I
hope the curve is right for you though,
Let me know if this doesn't do it
Tony
