POV-Ray : Newsgroups : povray.newusers : Searching for logical "not" Server Time
6 May 2026 20:19:37 EDT (-0400)
  Searching for logical "not" (Message 1 to 7 of 7)
Subject: Searching for logical "not"
Date: 7 Sep 2000 10:16:53
Message: <39b7a355$1@news.povray.org>
I want do difference two functions (to add a third one afterwards) and thing
it could be done by "& not". Alas, I can't find the logical "not" operator
in functions. Do I miss something? Does a simple "& -" the job or is there
no logical "not"?
I can't use "sign -1" because that would effect the hole function.
Thanks in advance,
Marc-Hendrik
Subject: Re: Searching for logical "not"
Date: 7 Sep 2000 19:01:15
Message: <slrn8rg7gd.kc9.steve@zero-pps.localdomain>
On Thu, 7 Sep 2000 16:17:02 +0200, Marc-Hendrik Bremer wrote:
>Hi,
>no logical "not"?
>Thanks in advance,
>Marc-Hendrik
#declare TheCount=2;
#if(TheCount !=1)
  pigment{Gold}
  #else
  pigment{Blue}
This works, I've just tested it, and I couldn't find it documented, I
just tried something I've seen in other languages.
 11:40pm  up 17 days,  3:53,  3 users,  load average: 1.53, 1.52, 1.25
Date: 7 Sep 2000 22:30:12
Message: <chrishuff-1357B6.21315707092000@news.povray.org>
In article <slr### [at] zero-ppslocaldomain>,
ste### [at] zeroppsuklinuxnet wrote:
> #if(TheCount !=1)
It *is* documented(section 4.1.3.3 "Float Operators", Relational
expressions), but I don't think this is what he is looking for. I think
Marc-Hendrik is looking for a not operator for isosurface functions.
Such an operator does not exist as far as I know, it might be a better
idea to just try CSG...though you could also do it by fiddling around
with the functions to get their "inside" on the other side of the
surface.
Christopher James Huff
Date: 8 Sep 2000 06:57:02
Message: <39b8c5fe@news.povray.org>
Marc-Hendrik Bremer <Mar### [at] t-onlinede> wrote:
: I want do difference two functions (to add a third one afterwards) and thing
: it could be done by "& not". Alas, I can't find the logical "not" operator
: in functions. Do I miss something? Does a simple "& -" the job or is there
: no logical "not"?
  Negating the function works if your threshold is 0.
Date: 8 Sep 2000 15:28:55
Message: <slrn8rhgau.m2f.steve@zero-pps.localdomain>
>> #if(TheCount !=1)
>surface.
But you could only find it because you did a search on "!", if you didn't
know that that is waht it is and that pov actually calles them float
operators rather that logical operators you'd be a bit stuck wouldn't you.
 11:21am  up 17 days, 15:34,  3 users,  load average: 1.19, 1.12, 1.04
Date: 9 Sep 2000 13:26:01
Message: <39ba72a9@news.povray.org>
Sorry Steve I was indeed not clear in my question. As Chris said, I was
looking for an isosurface-function-operator.
CSG does not work, because the cutout-surface would not be affected by the
third function (in this case a wood-pattern as function). In this special
case I have now, I avoided the difference by "rebuilding" the inverted shape
(a simple box) with two unioned boxes (the contained_by-object cared for the
rest). But that was only possible in this simple case.
Thanks for the help,
Marc-Hendrik
Steve schrieb in Nachricht ...
>>> #if(TheCount !=1)
>>surface.
>Cheers
>Steve              email mailto:ste### [at] zeroppsuklinuxnet
>%HAV-A-NICEDAY Error not enough coffee  0 pps.
>web http://www.zeropps.uklinux.net/
>or  http://start.at/zero-pps
Date: 9 Sep 2000 13:29:22
Message: <39ba7372$1@news.povray.org>
Thanks Warp!
I'll try that.
Marc-Hendrik
Warp schrieb in Nachricht <39b8c5fe@news.povray.org>...
