POV-Ray : Newsgroups : povray.newusers : Calling pre-defined textures with a concat generated string. Server Time
7 May 2026 02:57:59 EDT (-0400)
  Calling pre-defined textures with a concat generated string. (Message 1 to 6 of 6)
Subject: Calling pre-defined textures with a concat generated string.
Date: 16 Jul 1999 16:11:43
Message: <378f91ff@news.povray.org>
Hello.
Is it possible to use a concat generated string to call a pre-defined
texture?
In other words, why doesn't this code ...
// counter is a declared float in a loop with current value of 1
#declare vasetex = concat ( "T_Gold_", str(counter,1,0), "A")
texture { vasetex }
...let me call the texture T_Gold_1A, which is a pre-defined texture in the
file "golds.inc"?
I've trawled through the Help file but can't find any clarification.
Apologies if the answer is staring me in the face.
Thanks,
Alan.
Subject: Re: Calling pre-defined textures with a concat generated string.
Date: 16 Jul 1999 16:28:06
Message: <378F96F4.9827A22@compuserve.com>
The problem is that vasetex is a string variable, not a directive. One
way to work around this is to make an array of the textures instead.
Another way would be to use the file directives to write the texture
string to a file, then include that file in the proper place.
Date: 16 Jul 1999 16:35:24
Message: <378f95e1.7233577@204.213.191.228>
On Fri, 16 Jul 1999 21:10:16 +0100, "Alan Holding" <spe### [at] hotbotcom>
wrote:
Hi Alan.
What you're trying to do is use a string constant where a texture
identifier should be used. This doesn't work. Recently I asked a
similar question and the general opinion was that it could be achieved
by adequate use of file input/output. Try this:
#fopen F "tempfile.tmp" write
  #write (F, vasetex)
#fclose F
object { Vase texture { include "tempfile.tmp" } }
POV is currently heavily rendering so I haven't tried this, but I'm
pretty certain it should work.
Peter Popov
ICQ: 15002700
Date: 16 Jul 1999 18:21:38
Message: <378fb072@news.povray.org>
Hello, Peter.
Thanks to you and Chris Huff everything is working fine now!  (Just had to
change the 'include' to '#include' in the code you supplied.)
I've now got five lovely shiny golden vases.  And the potential to do all
kinds of crazy string manglin' madness!
Thanks again,
Alan.
http://www.specto.ukf.net/
Another pointless website.
Date: 16 Jul 1999 22:44:42
Message: <378fecbc.1472982@204.213.191.228>
On Fri, 16 Jul 1999 23:21:28 +0100, "Alan Holding" <spe### [at] hotbotcom>
wrote:
>Hello, Peter.
<hides in a corner>
Puhleeease forgive my poor soul
<pulls out a pocket knife and commits sepuko>
Seriously, sorry about that. I either have to have more coffee when I
post or put a reminder somewhere that there's always the F7 key. Too
bad it does not help for POV code :(
When are we going to see them?
>Thanks again,
>Alan.
Anytime.
<runs spell checker before hitting 'send'>
<it coughs on 'sepuko' :)>
Peter Popov
ICQ: 15002700
Date: 17 Jul 1999 05:59:38
Message: <3790540a@news.povray.org>
Peter Popov wrote in message
I've posted it to povray.binaries.images, though it's not that brilliant.
I'm still very new to POV-Ray and it's taking me a while to get my brain
round all the maths.  ;->
The post in p.b.i. is called 5 Gold Vases - 1st image.
Thanks,
Alan.
