POV-Ray : Newsgroups : povray.general : A little help about old vers. Server Time
29 Apr 2025 17:21:05 EDT (-0400)
  A little help about old vers. (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: A little help about old vers.
Date: 26 Apr 2025 08:20:00
Message: <web.680ccdc7ce24a8bb7e2ea33059126100@news.povray.org>
Alain Martel <kua### [at] videotronca> wrote:
> > Hi all,
> > I am sorry.
> > I don't understand the complex explanation of some changes made after version
> > 2.x, but I'm "reverting" some of my files.
> > I would appreciate if someone could translate these instructions because my old
> > compiler got from the CAD layer name and wrote something like this, which is now
> > not valid.
> My take.
> > DEF GOLDDARK Material {diffuseColor 0.81 0.71 0.23 ambientIntensity 0.5
> > specularColor 1 1 1 shininess 1}
> #declare GOLDDARK = material{
>  pigment{rgb<0.81, 0.71, 0.23>}
>  finish{diffuse 0.5 ambient 0 specular 1 metallic roughness 0.01
>   reflection{0.6 metallic}
>  }// This is a metal.
> The metallic key word cause the highlight and reflection to take the
> colour of the surface.
> Need an environment to show in the reflection.
> > DEF POLIBLUE Material {emissiveColor 0 0 0 diffuseColor 0.05 0 0.50
> > ambientIntensity 0.4 specularColor 0.8 0.8 0.8 shininess 0.625}
> #declare POLIBLUE = material{
>  pigment{rgb<0.05, 0, 0.5>}
>  finish{diffuse 0.7 ambient 0.1  specular 0.8 roughness 0.375}
>  // That's a rather dull surface.
> Make roughness smaller to make the highlight tighter.
> > DEF DEMIRED   Material {ambientIntensity 0.4 diffuseColor 0.6 0.1 0.1
> > specularColor 0.6 0.1 0.1 shininess 0.8 transparency 0.3}
> #declare DEMIRED = material{
>  pigment{rgbt<1, 0.8, 0.8, 0.6>}//transparent pigment.
>  finish{diffuse 0.5 ambient 0 specular 0.8 fresnel roughness 0.1
>   reflection{ 1 fresnel}
>  interior{ior 1.5// required for fresnel to work
>  dispersion 1.02// blue refract more than red by that amount
>  fade_color rgb<0.6, 0.1, 0.1>//Actual colour
>  fade_distance 0.1//Define how the thickness affect the colour
>  fade_power 1001 //a standard value
> That's a transparent material. Made it have a colour that depends on the
> thickness. Adjust fade_distance as needed. fade_distance depends on the
> scale of your scene.
> Need an IOR for the fresnel reflection to work. Will show refraction.
> Fresnel highlight and reflection are minimal when the surface is viewed
> perpendicularly and maximum at grazing angles.
> Need an environment to show in the transparency and the effect of
> refraction.
> > Thanks in advanced!
> > G.
Thanks!
but sorry, "material" is exactly my trouble. I used it in the far 2002, but now,
it is
not anymore working for me
So, if I use your suggestion for declare
I get:
Parse Error: No matching } in 'material', pigment found instead
Render failed
Date: 26 Apr 2025 09:15:00
Message: <web.680cdbd9ce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> I get:
> Render failed
POV-Ray is looking for a 'texture{}' to wrap the pigment and finish, see:
<https://wiki.povray.org/content/Reference:Material>.  hth.
regards, jr.
Date: 26 Apr 2025 10:10:00
Message: <web.680ce921ce24a8bb7e2ea33059126100@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > I get:
> > Render failed
> regards, jr.
Yes, this is exactly the page by me indicated previously, if you see the whole
topic.
This page is very confusing to me.
I would like to find a way to update the old definitions as faithfully as
possible.
This "material" way is a suggestion I had, but I already knew it didn't work.
Thanks!
Date: 26 Apr 2025 10:25:00
Message: <web.680ceb9fce24a8bb1f9dae3025979125@news.povray.org>
> topic.
> possible.
> Thanks!
What happened is that texture used to have interior as part of it.
Then interiors became it's own thing - separate from texture.
So to apply both to an object, you need to put them in a material {} statement.
material {} does accept a pigment {} statement directly.
So just do
material {
     texture {pigment {}}
and that will work.
- BW
Message: <web.680cec47ce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> > POV-Ray is looking for a 'texture{}' to wrap the pigment and finish,...
> topic.
> possible.
> Thanks!
the code below runs for me using a beta.2.  hth.
regards, jr.
-----<snip>-----
#version 3.8;
global_settings {assumed_gamma 1}
#declare mat_ = material {
      color rgb <.81, .71, .23>
    finish {
      diffuse .5
      ambient 0
      specular 1
      roughness .01
      reflection {.6 metallic}
      metallic
  /* put an interior here */
box {
 0,1
 material {mat_}
light_source {<-1,1,-1>*1e3 color rgb 1 parallel}
  location <0,0,-5>
  right x * (4/3)
  up y
  look_at <0,0,0>
Date: 26 Apr 2025 13:25:00
Message: <web.680d160bce24a8bb7e2ea33059126100@news.povray.org>
> hi,
> > topic.
> > possible.
> > Thanks!
> regards, jr.
> -----<snip>-----
> #version 3.8;
>   texture {
>     pigment {
>     finish {
>       diffuse .5
>       ambient 0
>       specular 1
>       roughness .01
>       metallic
> box {
>  0,1
>  material {mat_}
> camera {
>   location <0,0,-5>
>   right x * (4/3)
>   up y
>   look_at <0,0,0>
Many thanks!
I thought texture encapsulation was more complicated, now it works!
Date: 26 Apr 2025 14:00:00
Message: <web.680d1eb3ce24a8bb7e2ea33059126100@news.povray.org>
GREAT!
I restored the old declare!
Left = a car silver from my old render 2002 vers.2.??
Center = BAD !!! my attempt to restore the old code into vers 3.7
right = very well for me ! with your help
Many thanks to all!
PS. I don't have a great ability to render realistically. I dedicate myself to
geometry, code and projects, usually, but this for my needs is more than
satisfying!
Download 'clipboard01.png' (469 KB)
Preview of image 'clipboard01.png'
Date: 27 Apr 2025 02:30:00
Message: <web.680dce21ce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> Many thanks!
excellent.
> to geometry, code and projects, usually, but this for my needs is more than
> satisfying!
nice models, a forecourt (like a car dealer) or a parking lot, just .. an
overview, would be v cool though (I suspect you've "a collection" :-)).
regards, jr.
Date: 27 Apr 2025 18:50:00
Message: <web.680eb3c1ce24a8bb7e2ea33059126100@news.povray.org>
> hi,
> > Many thanks!
> excellent.
> > satisfying!
> regards, jr.
Thanks!
Not many vehicles, this is an overview of my stable. I have many objects made
over many years but also for interior architecture, let's say I have the
essentials. Vehicles and people are the only ones that are born from the web,
even if I work a lot on them to lighten, correct and above all optimize because
they are always very heavy. And I have to use many of them in my projects ...
NB. for the trees instead I use my algorithms ..
Download 'car.png' (836 KB)
Preview of image 'car.png'
Date: 28 Apr 2025 12:20:00
Message: <web.680faa15ce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> > ... an overview, would be v cool though ...
> Thanks!
hey, thank you very much.  (I like the newer VW shape much better than the old
60s "hippie express" :-))
sounds nice :-).  agree that stuff taken from the web needs to be "cleaned up"
carefully.
and again, thanks for "whipping up" that scene.
regards, jr.
