POV-Ray : Newsgroups : povray.general : L-Systems in Povray Server Time
18 Mar 2026 18:19:20 EDT (-0400)
  L-Systems in Povray (Message 41 to 50 of 64)
Subject: Re: L-Systems in Povray
Date: 11 Jul 2023 01:05:00
Message: <web.64ace273453cebfc17bac71e8ffb8ce3@news.povray.org>
> "jr" <cre### [at] gmailcom> wrote:
> > in Lvertices(), the for loop needs to read '#for (i,1,strlen(Lstr))'.  then the
> > problem becomes that you have no 'BuildRules' key for 'X', yet.  hth.
> So, I added:
> #declare BuildRules["X"] = asc("X");
The #switch needs an #else and do nothing there, for all symbols that do not
have a build rule, such as 'X' in this case
Regarding muses, besides shaving, although she prefers photography, point your
attention to the 'muse with the glass eye'. She likes ray tracing too.
ingo
Date: 11 Jul 2023 06:55:00
Message: <web.64ad3482453cebfcb49d80446cde94f1@news.povray.org>
hi,
> I have NO idea what I'm doing, but that gets me a completed render and no
> crashing.
_neat_.  (and thanks, that'll give me .. encouragement to play a little more
regards, jr.
Date: 11 Jul 2023 13:20:00
Message: <web.64ad8ef9453cebfc1f9dae3025979125@news.povray.org>
> hi,
> > crashing.
> regards, jr.
Other changes:
#declare BuildRules["X"] = asc("X"); // 88
#debug concat( "X = ", str(asc("X"), 0, 0), "\n")
#macro MoveRight (T_Pos)
 <T_Pos.x + 1, T_Pos.y, T_Pos.z>
 //#local T_Pos = <T_Pos.x + 1, T_Pos.y, T_Pos.z>;
 //#declare VXY_Arr[Curr_Items] = T_Pos;
 //#declare AZZ_Arr[Curr_Items] = AngleZZ;
 //#declare Curr_Items = Curr_Items + 1;
    #case (88)
    #local T_Pos = MoveRight (T_Pos);
    #break
    #else
    #break
   #end // end switch
#declare Axiom = "FFFFX";
#declare Rules = dictionary {
  ["X"] : "F[-X|][+F|]",
 // ["Y"] : "FX-Y"
#declare Iterations = 50;
Doesn't get me much, except a few line segments.  Once I have more time to
decipher the Big Picture, then it will be easier to make things work.
Download 'lsys7.pov.txt' (5 KB)
Date: 12 Jul 2023 10:10:00
Message: <web.64aeb317453cebfcdec7f1e73b2af915@news.povray.org>
> > hi,
> > > crashing.
> > regards, jr.
> Other changes:
> #end
>     #case (88)
>     #break
>     #else
>     #break
>    #end // end switch
>  // ["Y"] : "FX-Y"
first of all thanks to all of you for your engagement to solve this 'mystery'.
Just one remark: please do not use 'Iterations = 50;'. If the coding works
properly Povray will produce an amount of data to choke a horse with.
As far as using "X" or "Y" without declaring it is concerned: I used Ingo's
original code - means vector and angle are not separated - with
#declare Axiom = "X";
#declare Rules = dictionary{
  ["X"] : "XFYFX+F+YFXFY-F-XFYFX",
  ["Y"] : "YFXFY-F-XFYFX+F+YFXFY"
and it works like a charm (see attachment).
Furthermore I used Ingo's original and added Push and Pop stacks and...
Povray again complained about (vertices).
Could it be that Povray hates LIFO arrays <grin>.
Can't wait until Ingo's 'muse with the glass eye' is kissing me - I AM cleanly
shaven.
Time to investigate further.
Regards
Droj
Download 'lsys3.pov.txt' (3 KB)
Date: 12 Jul 2023 13:00:00
Message: <web.64aedbb5453cebfc763e4a273b2af915@news.povray.org>
> > > hi,
> > > > crashing.
> > > regards, jr.
> > Other changes:
> > #end
> >     #case (88)
> >     #break
> >     #else
> >     #break
> >    #end // end switch
> >  // ["Y"] : "FX-Y"
> Hi,
> shaven.
> Regards
> Droj
Just in case you are curious how lsys3.pov looks like.
Download 'lsys3.png' (149 KB)
Preview of image 'lsys3.png'
Date: 12 Jul 2023 13:05:00
Message: <web.64aedcd4453cebfc17bac71e8ffb8ce3@news.povray.org>
worked a bit on you lsys7. Simplified a few minor things. Changed a bit in
LVertices and added debugging.
We're at "Parse Error: Expected 'RValue to declare', End of File found instead"
now.
ingo
/*Pov-Ray    : 3.8
Scene File : lsys.pov
Author     : Ingo Janssen
Date       : 2023-06-04
#version 3.8;
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#declare T_Pos = <0, 0, 0>;
#declare A_F = 14; // Angle increment
#declare Max_Items = 200;
#declare Curr_Items = 0;
#declare VXY_Arr = array[Max_Items]; // Pos stack for xy-plane
#declare AZZ_Arr = array[Max_Items]; // Angle stack for xy-plane
//build rules
#declare BuildRules = dictionary;
#macro F(T_Pos, AngleZZ)
 #local T_Pos = <0, 0, 0>;
    <T_Pos.x + cos(AngleZZ), T_Pos.y + sin(AngleZZ), T_Pos.z> // <x, y, 0>
#declare BuildRules["F"] = 70; //chr(70) = F
#macro YawR(AngleZZ)
 #local AngleZZ = 0;
  AngleZZ + (tau/A_F)
#declare BuildRules["+"] = 43;
#macro YawL(AngleZZ)
 #local AngleZZ = 0;
  AngleZZ - (tau/A_F)
#declare BuildRules["-"] = 45;
#macro Turn(AngleZZ)
 #local AngleZZ = 0;
   AngleZZ - (tau/2)
#declare BuildRules["|"] = 124;
// the following macros are needed for branching
#macro Push(T_Pos, AngleZZ)
#declare BuildRules["["] = 91;
#macro Pop(T_Pos, AngleZZ)
  #declare Curr_Items = Curr_Items - 1;
  #declare T_Pos = VXY_Arr[Curr_Items];
  #declare AngleZZ = AZZ_Arr[Curr_Items];
#declare BuildRules["]"] = 93;
// I left Ingo's brilliant rewrite macro untouched
#macro Ltransform(Axiom, Rules, Iterations)
  #local Result = Axiom;
  #for (i, 1, Iterations)
      #local NewResult = "";
      #local N = strlen(Result);
      #local j = 1;
      #while (j <= N)
        #local CurrentSymbol = substr(Result, j, 1);
        #ifdef(Rules[CurrentSymbol])
          #local NewResult = concat(NewResult, Rules[CurrentSymbol]);
        #else
          #local NewResult = concat(NewResult, CurrentSymbol);
        #local j = j + 1;
      #local Result = NewResult;
      #debug concat(Result, "\n")
  Result
#macro Lvertices(Lstr)
  #local T_Pos = <0, 0, 0>; // <x, y, z>
  #local AngleZZ = 0;
  //#local Curr_Item = 0;
  #declare Return = array; //{<T_Pos.x, T_Pos.y, T_Pos.z>};
 #declare Return[0] = <T_Pos.x, T_Pos.y, T_Pos.z>;
  #for (i, 0, strlen(Lstr)-1)
    #local CurrentSymbol = substr(Lstr, i, 1);
    #ifdef (BuildRules[CurrentSymbol])
      #switch (BuildRules[CurrentSymbol])
        #case(70)
          #debug "70 F \n"
          #local T_Pos = F(T_Pos, AngleZZ);
        #break
        #case(43)
          #debug "43 + \n"
          #local AngleZZ = YawR(AngleZZ);
        #break
        #case(45)
          #debug "45 - \n"
          #local AngleZZ = YawL(AngleZZ);
        #break
        #case(124)
          #debug "124 | \n"
          #local AngleZZ = Turn(AngleZZ);
        #break
        #case(91)
          #debug "91 [ \n"
          #local Curr_Item = Push(T_Pos, AngleZZ);
        #break
        #case(93)
          #debug "93 ] \n"
          #local Curr_Item = Pop(T_Pos, AngleZZ);
        #break
      #local InArr = Return[dimension_size(Return,1)-1];
      #if (T_Pos.x != InArr.x | T_Pos.y != InArr.y | T_Pos.z != InArr.z)
        #declare Return[dimension_size(Return,1)] = <T_Pos.x, T_Pos.y, T_Pos.z>;
  #declare Vertices = Return;
  Vertices
  ["X"] : "F[-FX][+FX]",
  ["Y"] : "FX-Y"
#declare Iterations = 1;
#declare Lstr = Ltransform(Axiom, Rules, Iterations);
#declare Vertices = Lvertices(Lstr);
#ifdef (Vertices)
 #debug "OK \n"
#else
 #debug "Undefined! \n"
/*#for(i, 0, dimension_size(Vertices,1)-2) // <== here Povray complains
  cylinder{
    Vertices[i],Vertices[i+1],0.1
    texture{pigment{rgb 1}}
    translate <-25, -5, 0>
    rotate <0, 0, 0>
#end*/
camera{
  location <0,0,-30>
  look_at <0,0,0>
  angle 120
light_source{
  <3000,3000,-3000>
  color rgb 1
Date: 12 Jul 2023 13:15:00
Message: <web.64aedf3b453cebfc17bac71e8ffb8ce3@news.povray.org>
>   #local AngleZZ = 0;
>   #for (i, 0, strlen(Lstr)-1) !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
>         #case(70)
>           #debug "70 F \n"
>         #break
>         #case(43)
>           #debug "43 + \n"
>         #break
>         #case(45)
>           #debug "45 - \n"
>         #break
>         #case(124)
>           #debug "124 | \n"
>         #break
>         #case(91)
>           #debug "91 [ \n"
>         #break
>         #case(93)
>           #debug "93 ] \n"
>         #break
>       #end
>       #end
>     #end
>   #end
>   Vertices
> #end
  try: #for (i, 0, strlen(Lstr)) in the macro. The it runs and renders a small
white stick? But with Iterations = 2 it fails.
ingo
Date: 12 Jul 2023 14:15:00
Message: <web.64aeeca8453cebfc17bac71e8ffb8ce3@news.povray.org>
Try this.
Your pop and push macros didn't return anything.
image looks strange.
ingo
/*Pov-Ray    : 3.8
Date       : 2023-06-04
#version 3.8;
//#declare Curr_Items = 0;
//build rules
 #local AngleZZ = 0;
  AngleZZ + (tau/A_F)
 #local AngleZZ = 0;
  AngleZZ - (tau/A_F)
 #local AngleZZ = 0;
   AngleZZ - (tau/2)
#macro Push(Curr_Item, T_Pos, AngleZZ)
  #debug "push macro runs\n"
  #declare VXY_Arr[Curr_Item] = T_Pos;
  #declare AZZ_Arr[Curr_Item] = AngleZZ;
  #local Curr_Item = Curr_Item + 1;
  Curr_Item
#macro Pop(Curr_Item, T_Pos, AngleZZ)
  #debug "pop macro runs\n"
  #local Curr_Item = Curr_Item - 1;
  #declare T_Pos = VXY_Arr[Curr_Item];
  #declare AngleZZ = AZZ_Arr[Curr_Item];
  Curr_Item
      #local j = 1;
      #while (j <= N)
        #else
        #local j = j + 1;
  Result
  #local AngleZZ = 0;
        #case(70)
          #debug "70 F \n"
        #break
        #case(43)
          #debug "43 + \n"
        #break
        #case(45)
          #debug "45 - \n"
        #break
        #case(124)
          #debug "124 | \n"
        #break
        #case(91)
          #debug "91 [ \n"
          #local Curr_Item = Push(Curr_Item, T_Pos, AngleZZ);
        #break
        #case(93)
          #debug "93 ] \n"
          #local Curr_Item = Pop(Curr_Item, T_Pos, AngleZZ);
        #break
  Vertices
  ["Y"] : "FX-Y"
#declare Iterations = 6;
#ifdef (Vertices)
 #debug "OK \n"
#else
  cylinder{
    rotate <0, 0, 0>
camera{
  location <0,0,-30>
  look_at <0,0,0>
  angle 120
light_source{
  <3000,3000,-3000>
  color rgb 1
Date: 12 Jul 2023 16:10:00
Message: <web.64af07a7453cebfc763e4a273b2af915@news.povray.org>
> Try this.
> ingo
Gee, I didn't want to open a new rabbit hole for you.
I tried your code and yes: the image DOES look strange.
It seems like the whole thing stops after 1 iteration not knowing where to go
next or what to do next.
But at least Povray does not complain anymore.
I suppose you cannot borrow me your 'muse with the glass eye' for a moment or
two just to find out what's wrong with my push and pop macros.
I promise I'm shaven and like to photograph.
See how this thing we are talking about should look like.
Thanks for your patience
Droj
Download 'ls_plants01.png' (363 KB)
Preview of image 'ls_plants01.png'
Date: 13 Jul 2023 00:50:00
Message: <web.64af815b453cebfc17bac71e8ffb8ce3@news.povray.org>
Next thing to do is to debug the stack content and the vertices content.
Where it probably goes wrong:
The first point is added to the array and from then on only the "end points"
(last endpoint is next start point). But when branching you need a new start
point. That gets confusing. It is probably better to write [startpoint,
endpoint] to the array. The loop it with a stride of 2.
ingo
