POV-Ray : Newsgroups : povray.general : Tracking down slow renders Server Time
23 Mar 2026 21:23:34 EDT (-0400)
  Tracking down slow renders (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Tracking down slow renders
Date: 8 May 2023 18:09:41
Message: <64597325$1@news.povray.org>
On 5/8/23 10:53, Chris R wrote:
> I realized later that I had already increased my AA thresholds for the latest
> run, to no effect.  However, a combination of decreasing the max_trace_level
> from 30 to 10, as well as decreasing the block size from 32 to 8 seems to have
> markedly increased the over all speed, as well as eliminating the days-long
> rendering of the few problem blocks.
What version of POV-Ray are you using?
I'll mention a couple things I didn't note others bringing up.
1) If you have any transparency - and IIRC - since v3.7 rays transit
through transparent surfaces, with an ior of 1.0, without increasing the
max_trace count. This was done to avoid part of the old problem of black
pixels on hitting max_trace_level.
What I've had happen, very occasionally since, is some smallish number
of rays skimming a 'numerically bumpy' surface. The rays end up
transiting in an out of the shape a large number of times. Alain taught
me the trick of changing the ior to something like 1.0005 so those
transitions through transparency count again toward the max_trace_level.
2) With isosurfaces, using 'all_intersections' (really a max of 10) when
you don't need them 'all' can be expensive. I usually start with
max_trace at 2. Sometimes I cheat down to 1, if the object is simple,
opaque and I don't see artefacts.
There is too the quality level. If of the radiosity, subsurface and
media features all you use is radiosity, you can drop from 9 (=10 & =11)
to 8 and check performance without radiosity. Dropping to 7 cuts out
reflection, refraction and transparency(a). Plus, you can use start/end
row start/end column settings to render only in regions running slow for
performance testing.
Bill P.
(a) - Makes me wonder if different bucketing of some of those features
relative to the quality level would be useful given we don't today use
all the values? The internal cost of the conditionals would be similar
(the same?), I think. It would make the quality setting different than
what folks are used to using. Something to think about I guess.
Date: 10 May 2023 16:01:21
Message: <645bf811$1@news.povray.org>
While taking a break from Cousin Ricky's interior id assignment crash, I
decided to look at the idea above.
What I found is that Christoph had already worked to extend / clean up
the quality settings up in post v3.7 code. I didn't run down when
exactly he did the work, but it's been in place for years - 2018 or
earlier. Meaning, what we have documented for quality levels and
behavior is not what is in v3.8 beta 2.
For quality levels our v3.8 documentation has:
0, 1       - Just show quick colors. Use full ambient lighting only.
              Quick colors are used only at 5 or below.
2, 3       - Show specified diffuse and ambient light.
4          - Render shadows, but no extended lights.
5          - Render shadows, including extended lights.
6, 7       - Compute texture patterns, compute photons
8          - Compute reflected, refracted, and transmitted rays.
9, 10, 11  - Compute media, radiosity and subsurface light transport.
Which even in v3.7 was not quite right I know as 9 was the true highest
quality level. Aside: 'extended lights' above means 'area lights'.
What is in coretypes.h for all recent v3.8 / v4.0 code is:
     explicit QualityFlags(int level) :
         ambientOnly (level <= 1),
         quickColour (level <= 5),
         shadows     (level >= 4),
         areaLights  (level >= 5),
         refractions (level >= 6),
         reflections (level >= 8),
         normals     (level >= 8),
         media       (level >= 9),
         radiosity   (level >= 9),
         photons     (level >= 9),
         subsurface  (level >= 9)
So, even today we can pull apart refractions / transparent rays from
reflected rays by run time flag or ini setting. On suspecting internal
reflections are the cause of long run times, we could set the quality
level to 7 to test the thought.
Disclaimer. The hooks are there in the code, but I've not tested each
v3.8/v4.0 quality level to be sure it works.
For my povr fork play (as an idea for v4.0) I'm thinking for a start
I'll change the bucketing to:
         reflections (level >= 7),
         media       (level >= 10),
         radiosity   (level >= 11),
         subsurface  (level >= 12)
and make the default quality level 12 instead of 9.
It seems to me in lumping so many of the most expensive features
together we lose the debugging capability we can get from the quality
level feature.
For 'quality' you do want to run media, radiosity, photons and
subsurface together. They are tangled and affect each other.
Bill P.
Date: 10 May 2023 17:27:21
Message: <645c0c39$1@news.povray.org>
>          media       (level >= 9),
> level feature.
> Bill P.
 From my experience, when using +q0 to +q3, transparent pigments do show
as transparent. Both filter and transmit.
Then, from +q4 to +q7, anything transparent shows as black, for any
pigment and any amount of filter or transmit.
Date: 11 May 2023 04:00:00
Message: <web.645ca0395485baa958c093306cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> ... [quality levels] ...
> level feature.
(just thinking aloud "gut reaction")  wondering, naively, if "adding in" each
feature/level separately would not be a better strategy then.  that is, some
ini/command-line format to eg say (the equivalent of) "+media -photons ..."
regards, jr.
Date: 11 May 2023 08:02:07
Message: <645cd93f$1@news.povray.org>
Thanks Alain. This must mean the non refracting transparency is handled
apart from refracted - we perhaps should add a 'level' for those sorts
of rays too.
Also that the 'full ambient' and 'ambient' both meant the same "full
ambient" in the original documentation.
Thanks jr. Your idea is better. It would add a somewhat large set of
flags/ini options, but offer much more flexibility during debugging.
It's more doable with Christoph's post v3.7, quality code mechanisms
cleanup. The individual controls are now booleans prior to the tracing
conditionals - which means I should be able to override the quality
level set booleans if I get the order of the flag / ini evaluations
right. Or probably safer, but uglier to code, some method which
remembers all the individual feature control settings and uses those at
some later time during set up to override the quality determined boolean
settings.
Bill P.
Date: 29 Jun 2023 09:35:00
Message: <web.649d87a05485baa964326bc25cc1b6e@news.povray.org>
> Bill P.
I got access to a nice, big Linux box with 64 cores and tried rendering the
scene again, using the smaller block sizes and reduced max_trace_level.  It
chugged along pretty steadily for about 48 hours, and then with 128 pixels left
(out of a 1920x1080 image), its been stuck for an additional 72 hours with no
sign of progress.
The camera in the scene is at a very low angle above a wooden table with a bumpy
surface.  The table top is encased in a varnish object that is transparent and
has its own bumpy quality as well.  The two blocks that are stuck appear to be
on this surface and may be where some of the lights in the room are causing
specular highlights.
I'm using v3.8, and I have gotten into the habit of always using material{}
instead of texture{} for my objects so I don't forget to assign an ior when
using fresnel at the finish level and for reflection.  I'll have to look more
closely at the code to make sure I didn't miss any and leave them with the
default 1.0 ior, but I know for sure the varnish has an ior assigned from a
table of ior values.
I may end up shifting the camera location slightly and see if that eliminates
the problem spots, but I'd be interest in trying to figure out whether I'm just
hitting some threshold edge condition where an algorithm is just never
terminating.  Could I be hitting a loop where the threshold condition cannot be
met due to floating point precision problems?
-- Chris R.
Date: 29 Jun 2023 12:04:51
Message: <649daba3$1@news.povray.org>
Leaving the ior at 1.0 is very probably not your problem.
An ior 1 next to «air» effectively kill any fresnel reflection and
should do the same for highlights based on the fresnel model.
If your varnish have an ior of 1, then, it don't contribute to anything
having «fresnel» in it's definition.
Date: 29 Jun 2023 13:20:00
Message: <web.649dbc815485baa91f9dae3025979125@news.povray.org>
> sign of progress.
I know that I've run into that sort of thing with heightfields with a reflective
finish.  That was some sort of "known" bug, that I have no idea ever got
investigated or fixed.
Perhaps you can try to reduce the reflectivity of the surface - Only the very
upper/outermost surface should need a reflective value.
You can also try to render _just_ those blocks with the appropriate command line
switches, so you don't have to wait 48 before testing that region of the render.
- BW
Date: 29 Jun 2023 19:38:58
Message: <649e1612$1@news.povray.org>
(64 cores... What a dream! :-) )
Yes, always possible there is some unknown problem causing the run
extreme render times.
Given you have the problem isolated to two blocks, why not try what Bald
Eagle suggested. There are the (start row / end row) and (start column /
end column) controls. These I used often while running down various
solver issues (image artefacts) in 2017 / 2018 (a).
So. You could start by making a pretty good guess at the image rows
covering those to hung blocks. Then try row by row renders using:
povray ... +sr600 +er600 ...
povray ... +sr601 +er601 ...
When you find a row which hangs you can then start to use the column
options:
povray ... +sr602 +er602 +sc500 +ec1500 ...
povray ... +sr602 +er602 +sc700 +ec900 ...
You might need to 'kill' the hung processes (or cntl-c cancel if that
works) while you isolate to pixels. You can use the 'kill' command for
this or 'kill' via linux process monitoring commands like top/htop.
Should be you can leave all other options the same and slowly isolate
the problem pixels. If like my old hanging transparent blobs, it might
end up being just a pixel position or two (b).
If you can get to a scene of reasonable size and complexity also cut
down to a small number of problem pixels, I'll take a look at it on my
little two core i3 while doing some extra performance/debugging stuff.
Note though. Real life has me tied up until late July or more likely
early August so I won't be able to look at anything immediately.
Aside: I think all linux distribution offerings come with 'top' or
'htop' commands. It might be interesting to kick off one of these
commands in a terminal while povray is struggling to look at whether cpu
bound (povray processes at near 100%) or perhaps consuming large amounts
of memory - and so perhaps the 'hung' threads are paging even on your
huge machine (b). Large memory use would hint at runaway recursion
internal to the code (runaway transparency being one way this might
happen).
Bill P.
(a) Somewhere, I have a script framework which isolates to particular
pixels automatically based on various triggers - but that framework had
nothing which isolated on 'long render times...'
(b) Or there is a very remote chance the block is hung on exit. We have
seen 'render block' hangs with the Simple Direct media Layer (SDL1.2)
preview code - which the official v3.8 code still uses - though there
has long been a newer and less buggy 2.0 package. Using something like
top or htop, you might see the povray process(es) using very little cpu
or memory resource in this sort of case.
Date: 30 Jun 2023 08:35:00
Message: <web.649ecbcc5485baa98a3c0aee5cc1b6e@news.povray.org>
> options:
> happen).
> Bill P.
Thanks for all of the debugging hints.
Top is reporting that 2 cores are running at 100%, so one per 64-pixel block.
Memory has held constant, and this machine has 80GB so I don't think it's paging
very often.  Not much else is running on the machine at this point.
I'm going to leave it running over the 4-day holiday weekend and if nothing has
changed I'll kill it and try to isolate it.  Or if I'm feeling ambitious I'll
see if I can attach gdb to the running process and at least look at the stack
trace.
-- Chris R.
