POV-Ray : Newsgroups : povray.general : POV-Lab: plans and discussions Server Time
3 May 2024 06:20:47 EDT (-0400)
  POV-Lab: plans and discussions (Message 35 to 44 of 44)
Subject: Re: POV-Lab: plans and discussions
Date: 12 Feb 2023 13:15:00
Message: <web.63e92bd31a3112301f9dae3025979125@news.povray.org>
..pov file:
Download 'remapcolormap.pov.txt' (15 KB)
Date: 12 Feb 2023 13:50:00
Message: <web.63e9348c1a3112301f9dae3025979125@news.povray.org>
and then to shift the color values around in a non-linear mapping, just paste:
//  Modify color map index
  //#local NewIndex =  pow (NewIndex, 2);  // squared
  //#local NewIndex =  pow (NewIndex, 0.5);  // sqrt
  #local NewIndex =  sin (NewIndex * pi/2);
right below
#local NewIndex =  ReMap (Min, Max, 0, 1, OldIndex);
in macro FixColorMapArray.
Enjoy!
Download 'remapcolormap.png' (50 KB)
Preview of image 'remapcolormap.png'
Date: 12 Feb 2023 14:00:00
Message: <web.63e936081a311230501ba4b089db30a9@news.povray.org>
> Op 12-2-2023 om 15:36 schreef Bald Eagle:
> > With regard to the color_map, I'll say that this is just another example of
> > making the hard-coded data in your scene difficult to nearly impossible to
> > manipulate.   You might consider storing all of that data in an array, and then
> > building the color map from that.   Then you can mathematically manipulate the
> > index values any way you want.   It's also very useful in case you want to embed
> > "lines" into a map - in order to make grids, or bracket a region of something,
> > or fix an uneven-looking map that doesn't get interpolated the way that you want
> > visually.
> This is interesting. Can you give an example on how to tackle that? I am
> not sure if I understand correctly.
Too see an example of how to do something along those lines, you can
have a look in the Color_Maps.inc file, which can be found here:
https://github.com/t-o-k/POV-Ray-color-maps
Tor Olav
http://subcube.com
Date: 13 Feb 2023 00:00:00
Message: <web.63e9c2a01a3112303691b85710800fb2@news.povray.org>
> jr:
> re the camera stuff BE mentioned, made me think that assuming you/povlab knows
> when a user also has POV-Ray installed, you could also perhaps make use of the
> real-time render feature.
Unbelevable, but it works - not real, but almost-real time. This light-weight
scene turns with about 2 FPS on my outdated Intel Core i5 750 2.66 GHz.
Good for preview, thanks, jr, you saved time for me, I'm almost started using
Matlabs's animation techniques.
What I like most about POV is that impressive things can be done very easy.
> BL:
>You have a "right" directive twice in your camera block.
>You may want to read about the camera and the way it works since there are some
>commands that will alter previous camera commands, so there is --- I'll call it
>a preferred order of operations.
Now I am going 'Into the Lens', to explore all camera features.
YB
Download 'vector_animation.png' (98 KB)
Preview of image 'vector_animation.png'
Date: 13 Feb 2023 00:05:00
Message: <web.63e9c4961a3112303691b85710800fb2@news.povray.org>
Scene, btw:
Download 'animation.zip' (100 KB)
Date: 13 Feb 2023 02:31:11
Message: <63e9e73f@news.povray.org>
Op 12/02/2023 om 19:55 schreef Tor Olav Kristensen:
>>> visually.
Bill and Tor, many thanks for your explanations! I had not been aware of
this until now. Going to have a good look and play happily in the
POV-garden for a while. :-)
Date: 13 Feb 2023 05:50:00
Message: <web.63ea15131a3112303691b85710800fb2@news.povray.org>
Thanks to your comments, now we have 10 ready-to-use colormaps here:
https://github.com/syanenko/colormaps
Download 'example.png' (51 KB)
Preview of image 'example.png'
Date: 13 Feb 2023 06:30:00
Message: <web.63ea1e621a3112301f9dae3025979125@news.povray.org>
Sure thing.
I also do this sort of thing for sphere sweeps and prisms - all the data gets
put into an array, and then I can make a spline for the sphere sweep, or use a
loop and grab the xz data for the prism.
I can always move "forward" from an array, since the data is always fully
accessible for anything I want to use it for.  I can't go "backward" if that
data is hard-coded into some other single-purpose container.
Date: 13 Feb 2023 11:33:49
Message: <63ea666d$1@news.povray.org>
Op 13-2-2023 om 12:26 schreef Bald Eagle:
> Sure thing.
And as I am stupid, I forgot that - thanks to you - this technique was
used in Granites_21! ;-/
I am getting old....
Date: 14 Feb 2023 03:35:00
Message: <web.63eb47661a31123088a828ca6cde94f1@news.povray.org>
hi,
"yesbird" <nomail@nomail> wrote:
> Unbelevable, but it works ...
:-)  (agree re preview, ideal)
regards, jr.
