POV-Ray : Newsgroups : povray.general : Github repository with useful macros Server Time
21 May 2024 09:01:21 EDT (-0400)
  Github repository with useful macros (Message 31 to 40 of 41)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Github repository with useful macros
Date: 22 May 2021 20:05:00
Message: <web.60a99b83985098ff1f9dae3025979125@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> Btw.: The Official Windows POV-Ray v3.7 says that 1e16 + 1 = 1e16.
> Therefore I tested the macros I just posted with the scalar value 1e17, and they
> both think that it is a 2D vector.
That's crazy.
There are MORE joys of floating point math?  ;)
with qtpovray on Linux Mint, I get
1e15 + 1 = ScalarValue = 1000000000000001.000
1e15+1.1 = ScalarValue = 1000000000000001.125
1e16 + 1 = ScalarValue = 10000000000000000.000
1e16 +1.1 = 2D2D VECTOR = <10000000000000002.000, 0.000>
1e16 + 10 = 2D2D VECTOR = <10000000000000010.000, 0.000>
1e17 = 2D VECTOR = <100000000000000000.000, 0.000>
> So these solutions are not numerical robust.
Nope.   But for smaller numbers and general usage they're better than what we
had.
> Perhaps we need an istype() function like jr suggested.
It would be great, especially since then we could type thing in CSV files as
they're being read in, and would need foreknowledge of the file structure.
Alternatively, we could use a trap() or OnError () function that allows
sequential rejection of blocks of code that would try to operate on the wrong
type until the code encountered a test that didn't throw an error.
Date: 22 May 2021 20:35:00
Message: <web.60a9a222985098ff79819d986cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 5/22/21 12:13 PM, jr wrote:
>> ...  did I misread yr point?
> :-) Suppose, I think so. We want the #ifndef to only look at the tokens
> passed on the macro call.
the documentation is pretty .. explicit on optional macro args and "reliable"
testing requiring 'local.' (dictionary) -- highlighted box.
> The code can of course be correct, my point is
> the option checking code can be wrong - thereby allowing definitions
> into the macro by a path other than the call parameters/tokens.
I was surprised to see there's a way to "smuggle" an undeclared identifier into
a macro, but yeah, "caveat emptor", as BE might say.  :-)
regards, jr.
Date: 23 May 2021 09:04:50
Message: <60aa52f2$1@news.povray.org>
Somewhere in this thread jr had a feeling istype() wouldn't be too
difficult to implement. I didn't want to think about this having already
quite a mess in my head, but my head has.
I think something like idtypesmatch() might be relatively simple(1).
You'd set an id to a reference thing. Then compare other IDs against
that reference by internal type. The function would return 0 or 1.
Useful enough?
Once into something like istype(), we at a minimum need to make all the
types of interest accessible by name in the SDL. Internally there are
type classes - 'someKindaVector' and so on which would likely be useful
to have defined too. The implementation complexity rapidly increases, if
you want to set up or store types for later work in a parser aware way,
define types priori, ...
Bill P.
(1) - Less controlled variations could store values of types via say
typevalueof() in float capable 'storage-types' for later float to float
compares. Note. The type enums within the parser are not constant, but
change as the parser keywords change. Meaning one would always have to
run typevalueof() against reference 'things' to get the POV-Ray
version's baseline type values against which to compare other things.
Date: 23 May 2021 10:35:00
Message: <web.60aa6759985098ff1f9dae3025979125@news.povray.org>
<Mr Smithers>   Exxxxxxxcellent...  </Mr Smithers>
Welcome to my daily reality.
> Useful enough?
Yes.
And then it would be easy enough to write a macro that gets called and tests
what that thing is, to address your later concerns.
If I can do #read (OpenFile, Thing) and then find out what Thing is before I
further process it, then that's perfect.
Date: 23 May 2021 10:45:00
Message: <web.60aa6948985098ff79819d986cde94f1@news.povray.org>
hi,
back when I used to be real good at giving people headaches.  ;-)
> Useful enough?
sounds good, having a design that returns a bool is v elegant.  and should work
well, eg, when writing a macro for "public consumption" since I could provide
what (argument type) I look for and compare it to the parameter supplied.
(there's lots I'm not clear on, say, 'array [2][2][2]' would compare equal to
any size 3D array of same float/vect/whatever, and such, but like the
design/idea)
> Bill P.
had not envisaged anything as sophisticated.  thought if 'istype()' returned an
integer value corresponding to type[*] of "foo", and the documentation has a
(lengthy) table with suggestive but not used symbolic names (derived from the
underlying enum) and their numeric values.  anyway, past.  :-)
[*] coded presumably to keep the actual number of "types" down.
regards, jr.
Date: 23 May 2021 10:51:52
Message: <60aa6c08$1@news.povray.org>
Op 23-5-2021 om 16:31 schreef Bald Eagle:
Been there...
Date: 26 May 2021 18:11:52
Message: <60aec7a8$1@news.povray.org>
Am 21.05.2021 um 23:31 schrieb Tor Olav Kristensen:
> I take it that you would like to be able write things like cos(v0) and then the
> cos function will be applied to all of the components of the vector. If so I
> second that. But only if that if is done with a built in functionality. I don't
> like the macro's we currently have in the include files for such things.
Yeah, no. I don't think that's going to happen. Not as a generic syntax.
Not within the lifespan of this parser, anyway.
Date: 26 May 2021 18:53:27
Message: <60aed167$1@news.povray.org>
Am 22.05.2021 um 13:33 schrieb jr:
> thinking that what your + CR's (ingenious) posts demonstrate is just how much an
> 'istype()' like function is needed in SDL.  (I've a feeling it would not be too
> difficult to implement, a developer's perspective would be good)
"Pfffffffaaaaaaaaaaaaahahahahaha! BWAAAAHAHAHAHAHAHA!"
(*manic laughter*)
-- Anonymous developer.
Keeping track of the type of things IN THE PARSER ITSELF is painful
enough... add to that the trouble of coming up with a nice elegant
syntax, questions such as whether this should work only on variables, or
also literals or even complex expressions...
... oh, and then add to the mix that the parser doesn't go, "ah, let me
evaluate and see what the result of this expression is", but rather "ah,
I expect this particular type here; let me see how the following makes
any sense under that presumption"...
... ah, and let's not forget arrays. Arrays and array elements are fun.
Hooray for how the parser handles arrays, and their elements. Yaaaaaay...
Yeah. Multiple cans of worms.
Date: 26 May 2021 20:50:00
Message: <web.60aeeba5985098ff1f9dae3025979125@news.povray.org>
He's BA-aaaaaaaaaaaaaaaaaaaaack!!!
OK, although I thought at first it might be a girl, I must admit that my next
guess was that it was the parser.  I sat here, sipping my gin & tonic, slowly
shaking my head in sadness...  "That poor boy.  It had to be the parser.   He
shouldn't have gone and fiddled with it like that.  It's too dangerous.
Everyone knows that.  Others have tried - and failed.  That damned parser ... it
finally broke him...."
"I mean that, for nearly 20 years developers have been searching through this
vast parser.  It's not something to be taken lightly.  No one knows its secrets.
 It's like nothing he's ever gone after before..."
Date: 26 May 2021 21:02:38
Message: <60aeefae$1@news.povray.org>
Am 27.05.2021 um 02:45 schrieb Bald Eagle:
Dang, how am I supposed to cry myself to sleep after reading THAT ;)
