POV-Ray : Newsgroups : povray.general : POV-Ray Installation thread Server Time
2 Jun 2024 02:33:03 EDT (-0400)
  POV-Ray Installation thread (Message 21 to 30 of 61)
Subject: Re: POV-Ray Installation thread
Date: 13 May 2021 15:50:00
Message: <web.609d82d32344a9a179819d986cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> // This a povr branch only example!
> #declare Nrml00 = normal {
>      average
>      normal_map {
>          [0 bevy type 1 bump_size 0.5] // unbiased wrinkles alt
the line above (28) gives me trouble.
>          [1 bevy type 4 bump_size 0.5] // Lean already wrinkled at +y
==== [Parsing...] ==========================================================
File '/home/jr/POVr/share/povray-3.8/include/shapes.inc' line 324:
Parse Warning:
Bounding object ignored due Remove_Bounds=on/+UR default or setting.
Parse Warning:
Parse Warning:
File 'bevr.pov' line 28:
Parse Error:
No normal pattern type specified. For example, bumps.
Fatal error in parser: Cannot parse input.
Render failed
regards, jr.
Date: 13 May 2021 15:59:26
Message: <609d851e$1@news.povray.org>
On 5/13/21 3:49 PM, jr wrote:
> hi,
>>       average
>>       normal_map {
> Parse Error:
> Render failed
The bevy keyword (as normal pattern collection, pattern) is new. I've
not yet released code that supports it. I should've added a note. And I
should tweak that error message as 'type' has become misleading.
Bill P.
Date: 14 May 2021 05:40:00
Message: <web.609e45162344a9a179819d986cde94f1@news.povray.org>
hi,
> not yet released code that supports it. ...
ah, ok.  can you clue me/us in wrt planned update/release?  (roughly)
regards, jr.
Date: 14 May 2021 06:30:22
Message: <609e513e$1@news.povray.org>
On 5/14/21 5:38 AM, jr wrote:
> hi,
I'm working on some commits today, so I might be able to put something
out fairly soon.
I know the internals of the bevy collection itself is a work in
progress, but probably I can throw a construction tarp over what is not
done. I'm not done with all the include self testing either, but quite
lot fixed... We'll see.
Bill P.
Date: 14 May 2021 10:20:44
Message: <609e873c$1@news.povray.org>
> hi,
>>       average
>>       normal_map {
In an average, the control values determine the weight of that part. So,
that [0 bevy type 1 bump_size 0.5] mean zero weight, zero contribution.
This mean that it could be removed without affecting the final result.
That zero weight may be the cause of your problem.
Try changing it to :
// effectively the same as the above code
#declare Nrm100 = normal{bevy type 4 bump_size 0.5}
or
// Equal weight
	average
	normal_map{
		[1 bevy type 1 bump_size 0.5]
or
//very little contribution for type 1
	average
	normal_map{
		[0.0001 bevy type 1 bump_size 0.5]
Date: 14 May 2021 16:00:00
Message: <web.609ed6bb2344a9a11f9dae3025979125@news.povray.org>
Just went through povr installation with jr.
Got the biscuit render, so looked good.
Went into qtpovray38 distribution directory to test a .pov file.
bald@Alienware ~/povray38/scenes/objects $ povr blob.pov
/home/povray/povray-3.8.0-x.povr_b0bcf6c0/bin/povr: 5:
/home/povray/povray-3.8.0-x.povr_b0bcf6c0/bin/povr: Cannot fork
bald@Alienware ~/povray38/scenes/objects $ povr chess.pov
Any ideas?
Date: 14 May 2021 17:09:10
Message: <609ee6f6$1@news.povray.org>
On 5/14/21 10:20 AM, Alain Martel wrote:
>> hi,
With povr the zero weight is part of the trick to pass the results of
this map entries normal perturbation to bevy type 4 so what you get is a
chain of perturbations ending in one result and not some average on
perturbation results.
That said, your suggestion should still work, but will result in a
normal both averaged and chained... Not something I've actually tried.
I'd guess it would come in as a mix of the lower two images.
All of the bevy stuff is still sitting only on my machine. I haven't
released it.
Bill P.
Date: 14 May 2021 17:27:48
Message: <609eeb54$1@news.povray.org>
> Any ideas?
Just guesses.
The 'cannot fork' stuff usually happens when a unix/linux system has run
out of resources to start another process. Lack of memory/swap space,
/tmp, /var - maybe. There are sometimes limits on the number of
processes in place, but this in my experience is not all that common.
For starters you could try running the 'df' command and look at disk
usage. The command 'free -m' can be useful too.
Somewhere you posted about your machine... Let me try and find that and
I'll post back here if I see anything obvious.
Note! I expect quite a few existing scenes will NOT render correctly
with the povr branch without modification.
Let me try quickly to run a v3.8 blob scene here with my povr wrapper
script. It runs OK for me, but my povr is a little different.
I don't see a chess.pov, but chess2.pov doesn't run because it tries to
include color.inc and that file is not in povr's core set of includes.
In any case I'm not getting 'cannot fork' errors...
Bill P.
Date: 14 May 2021 17:59:39
Message: <609ef2cb$1@news.povray.org>
>> Any ideas?
> Just guesses.
Machine stats you posted look good.
Had a few other thoughts meanwhile.
- What was your entire command line with flags & ini ?
- If just say the blob scene you can probably point to a normal povray
v3.7/v3.8 install and see if you get the same problem.
- You could run the povray command directly. One executable would be in
the unix directory below where you issued make:
<theMakeDir>/unix/povray blob.pov
- You could copy the blob.pov scene to where you ran the biscuit scene
and try and run it there.
- You could try (a) to cut the resources required by using the '+wt1'
and '-d' flags. I guess in that vein you could just run 'povr --help'
while in the 'problem' directory.
- You could try and start another process than some form of POV-Ray -
say gimp - from within the povr script when you are seeing the error.
- While in the directory with blob.pov, if you run 'ls -l blob.pov' does
it show the read bits set on the left. Something with 'r's like:
'-rw-rw-r--'
... Yeah, guessing. It's been many years since I've seen that error.
Bill P.
Date: 14 May 2021 18:35:00
Message: <web.609efa342344a9a11f9dae3025979125@news.povray.org>
Er, for what?
bald@Alienware ~/povray38/scenes/objects $ povray bezier.pov
povray: cannot open the user configuration file
/home/bald/.povray/3.8/povray.conf: No such file or directory
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.10064268.unofficial
 (g++ -std=gnu++11 5.4.0 @ x86_64-pc-linux-gnu)
This is an unofficial version compiled by:
 BaldEagle <cre### [at] netscapenet>
 The POV-Ray Team is not responsible for supporting this version.
<snip....>
Parser Time
  Parse Time:       0 hours  0 minutes  0 seconds (0.087 seconds)
              using 1 thread(s) with 0.012 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  0 seconds (0.000 seconds)
              using 1 thread(s) with 0.000 CPU-seconds total
Cannot create render state output file.
Render failed
The biscuit scene automatically rendered as part of the install process.
> '-rw-rw-r--'
bald@Alienware ~/povray38/scenes/objects $ ls -a -l
total 288
drwxr-xr-x  4 root root   4096 Jun 21  2020 .
drwxr-xr-x 20 root root   4096 Jun 21  2020 ..
-rw-r--r--  1 root root   1463 Jun 21  2020 bezier.pov
-rw-r--r--  1 root root    955 Jun 21  2020 blob1a.pov
-rw-r--r--  1 root root   1246 Jun 21  2020 blob1b.pov
-rw-r--r--  1 root root   1077 Jun 21  2020 blob1c.pov
-rw-r--r--  1 root root   1023 Jun 21  2020 blob.pov
-rw-r--r--  1 root root   1105 Jun 21  2020 chesmsh.pov
-rw-r--r--  1 root root 115136 Jun 21  2020 chess.inc
drwxr-xr-x  2 root root   4096 Jun 21  2020 csg
-rw-r--r--  1 root root   1522 Jun 21  2020 fractal1.pov
-rw-r--r--  1 root root   2349 Jun 21  2020 fractal2.pov
-rw-r--r--  1 root root   1405 Jun 21  2020 fractal3.pov
-rw-r--r--  1 root root   1277 Jun 21  2020 fractal4.pov
-rw-r--r--  1 root root   5082 Jun 21  2020 isosurfaces.pov
-rw-r--r--  1 root root   1499 Jun 21  2020 lathe1a.pov
-rw-r--r--  1 root root   1518 Jun 21  2020 lathe1b.pov
-rw-r--r--  1 root root   1555 Jun 21  2020 lathe1c.pov
-rw-r--r--  1 root root   3198 Jun 21  2020 lathe2.pov
-rw-r--r--  1 root root   5357 Jun 21  2020 mesh2.pov
-rw-r--r--  1 root root   1257 Jun 21  2020 polygon.pov
-rw-r--r--  1 root root   4104 Jun 21  2020 primitiv.pov
-rw-r--r--  1 root root   5344 Jun 21  2020 prism1.pov
-rw-r--r--  1 root root   5388 Jun 21  2020 prism2.pov
-rw-r--r--  1 root root   1354 Jun 21  2020 prism3a.pov
-rw-r--r--  1 root root   1810 Jun 21  2020 prism3b.pov
-rw-r--r--  1 root root   1597 Jun 21  2020 prism3c.pov
-rw-r--r--  1 root root    571 Jun 21  2020 prism3.inc
drwxr-xr-x  2 root root   4096 Jun 21  2020 quartic
-rw-r--r--  1 root root   3561 Jun 21  2020 sor1.pov
-rw-r--r--  1 root root   2617 Jun 21  2020 superel1.pov
-rw-r--r--  1 root root   2629 Jun 21  2020 superel2.pov
-rw-r--r--  1 root root   4247 Jun 21  2020 superel3.pov
-rw-r--r--  1 root root   4963 Jun 21  2020 torus1.pov
-rw-r--r--  1 root root   1759 Jun 21  2020 torus2.pov
-rw-r--r--  1 root root   1342 Jun 21  2020 ttf1.pov
-rw-r--r--  1 root root   1821 Jun 21  2020 wtorus.pov
I have qtpovray running on this machine, and it works just fine - rendering a
scene file.  But not THOSE scene files.   Couldn't make the state file.
Just did chown -R bald:bald povray38 on that whole parent directory, and
qtpovray renders those, but povr now gives me --- no output whatsoever.
no new image file in that directory after silent command
