"Josh" <nomail@nomail> wrote:
> 1) I would love to use the example from Inigo Quilez about rounding. Say I have
> a simple function for a box used in an isosurface. How would I implement his
> idea in povray to make the corners round? I tried changing the threshold of the
> isosurface, but that doesn't do it. A simple example would be super helpful.
http://www.iquilezles.org/www/articles/distfunctions2d/distfunctions2d.htm
float sdBox( in vec2 p, in vec2 b )
vec2 d = abs(p)-b;
return length(max(d,0.0)) + min(max(d.x,d.y),0.0);
It may take some fiddling to get the vectors that ShaderToy allows you to use in
its functions into a POV-Ray function.
#declare PX = VecP.x;
And then you can use PX in the function.
> 2) I also like how you can create df3 files and use them as a function from the
> warp example. Is there any 3d modelers that can export df3? Are there other
> programs/ways to create simple df3 files of simple shapes?
There should be a function to make a df3 from POV-Ray.
http://wiki.povray.org/content/Reference:Arrays.inc
Arrays.incReference
This file contains macros for manipulating arrays.
ARRAYS_WriteDF3(Array, FileName, BitDepth): Write an array to a df3 file.
Parameters:
Array = The array that contains the data.
FileName = The name of the file to be written.
BitDepth = The size of the binary word.
Note: See the #write directive for more information.
I would have gotten to this sooner, and maybe wrote out some more detailed help,
but I spent all day writing and developing Arduino code in cpp proper.
I still have one or two things to do that I don't quite understand. ;)
But this should get you going if you play with it a bit.
https://www.desmos.com/calculator
hi,
if you're using some Linux, there's the 'df3 tools':
<http://news.povray.org/web.5b43d8aa43fdfea9635cc5ad0%40news.povray.org>
regards, jr.
Subject: Re: Mapping Textures on irregular shapes
Date: 28 Apr 2020 03:11:03
Message: <5ea7d707@news.povray.org>
Op 26/04/2020 om 23:45 schreef Josh:
You may be interesting in:
https://www.oyonale.com/modeles.php?lang=en&page=36
> Thomas
Yes, that is beautiful and probably can be modified to do what I am looking for.
Thanks!
"jr" <cre### [at] gmail com> wrote:
> hi,
> regards, jr.
Thanks! Definitely worth playing with.
I'm not sure if proper etiquette here would be to start a new post, but since
it's still on the same basic subject, I'll just continue...
How do I align a pigment with a normal? Say I have an isosurface that I want to
apply an agate normal to, but also an agate pigment_map that matches perfectly,
so that I can color just the 'valleys' of the normal map? Does that make sense?
It almost looks like it matches, but when I render one time with just the
pigment_map and one time with just the normal, I don't think they are the same
pattern.
Josh
isosurface
texture
pigment
agate
pigment_map
[0.00 rgb <0,1,.7>]
[0.02 rgb <0,.3,.1>]
[0.15 rgb <0,0,0>]
scale 0.2
normal
agate .5
scale .2
Op 29/04/2020 om 08:47 schreef Josh:
>> Thomas
> Thanks!
You certainly can! I did some exploration along that line back in 2013.
In the newsgroups, look for my name and 'df3'. There are different
discussions.
> pattern.
Looks like you're doing it right.
Might just be the the way the light strikes it, or the way the eyes are more
sensitive to the finer changes in colors of the pigment map vs the effect of the
normal.
Notice I did pigment and normal and THEN scaled (easier to keep track of, and
ensures they're exactly the same)
Maybe play around with the bump_size.
http://www.povray.org/documentation/view/3.6.1/339/
The PATTERN_TYPE may optionally be followed by a float value that controls the
apparent depth of the bumps. Typical values range from 0.0 to 1.0 but any value
may be used. Negative values invert the pattern. The default value if none is
specified is 0.5.
#version 3.8;
global_settings {
assumed_gamma 1.0
#declare Aspect = image_width/image_height;
#declare Zoom = 120;
orthographic
right x*image_width/Zoom
up y*image_height/Zoom
location <0, 0, -10>
look_at <0, 0, 0>
light_source {<0, 0.2, -20> color White } //shadowless}
sky_sphere {pigment {rgb 1}}
#declare B = 0.4;
box {<-1, -1, -0.1>, <0, 1, 0>
agate
pigment_map {
[0.00 rgb <0,1,.7>]
[0.15 rgb <0,0,0>]
} // end pigment map
} // end pigment
normal {
agate B
} // end pigment
} // end texture
box {<0, -1, -0.1>, <1, 1, 0>
/* pigment {
agate
pigment_map {
[0.00 rgb <0,1,.7>]
[0.15 rgb <0,0,0>]
} */ //end pigment
normal {
agate B
} // end pigment
} // end texture
> > pattern.
> normal.
I see now that you are right. They look a bit mis-aligned but it has more to do
with the pigment map changing more quickly than the normal...
Thanks!
Josh
I've found a way to create and use a df3 file as an isosurface. Works well. I'm
trying now to add noise to it and it makes the shape disappear. Any ideas? The
shape shows up fine without the +f_noise3d(x,y,z)*2 statement... Does anyone
know what is happening?
#include "functions.inc"
#declare Fnct00 = function {
pattern { density_file df3 "aster1.df3" interpolate 0
#declare Fnct01 = function (x,y,z) {
0.025-Fnct00(x,y,z)
#declare BaryteGreen = srgb <0.6157,0.7686,0.3725>;
#declare Iso00 = isosurface {
function { Fnct01(x,y,z) + f_noise3d(x,y,z)*2}
contained_by { box { -5,5 } }
threshold 0
accuracy 0.0005
max_gradient 6
all_intersections
pigment { color BaryteGreen }
finish { ambient <0.03,0.02,0.0> diffuse 0.8,0.4 phong 0.7 }
Josh
> 0.025-Fnct00(x,y,z)
> threshold 0
> accuracy 0.0005
> max_gradient 6
> all_intersections
> texture {
> Josh
Just to clarify, I've tried adding f_noise3d, subtracting it, nothing seems to
allow me to perturb the surface of my df3 shape like I can if my function is
just a simple sphere...
Josh
