As I explored, the technique (if not the only) technique for building
smoke/steam/vapor is to apply media effect to a sphere. This creates a
cloud-like fume.
However, for example, the steam of coffee is made of distinguishable steam lines
in a light fog. See
https://c4.wallpaperflare.com/wallpaper/496/851/672/cup-coffee-steam-hot-wallpaper-preview.jpg
With the above-mentioned technique, we can only create something like
https://i.ytimg.com/vi/ZDbJCsTGYoA/hqdefault.jpg
Should I look for another approach or the media effects can create realistic
steam?
> steam?
I would start by looking at patterns such as marble, with the turbulence
modifier.
Define a color map with clear and white, and see what that looks like.
Then you can define a function using the marble pigment pattern, and use that to
define the density in your media.
Subject: Re: How to create steam with lines rather than a fume?
Date: 17 Feb 2020 16:08:02
Message: <5e4b00b2$1@news.povray.org>
> cloud-like fume.
> in a light fog. See
> steam?
Instead of using a sphere as your container, you can use a cylinder and
use a cylindrical pattern in place of the spherical one.
Next, apply some uneven turbulence within a wrap{} container.
You can then apply some uneven scaling, maybe use black_hole elements.
Date: 18 Feb 2020 02:40:15
Message: <5e4b94df$1@news.povray.org>
Op 17/02/2020 om 19:11 schreef Kima:
> cloud-like fume.
> in a light fog. See
> steam?
All the other comments of course; in addition, you might be interested
by SmokeGen, a smoke generator created by Mikael Carneholme in a very
distant past. So distant, that his site is no longer available
unfortunately. However, if you want it (just yell), I can provide a zip
with all the needed files. Use them at your own discretion but please
mention the original author when you do.
> > cloud-like fume.
> > in a light fog. See
> > steam?
> Thomas
I strongly appreciate if you can share the files, Thomas.
It might be outdated but definitely can give me some clues following the tricks
employed for generating smoke.
Thank you again.
Date: 19 Feb 2020 02:31:36
Message: <5e4ce458@news.povray.org>
Op 18/02/2020 om 09:03 schreef Kima:
> Thank you again.
Here we go (see attachment)
The file to use inside PovRay is SmokeGen.inc. The Docs are very
comprehensive.
Have fun!
Download 'smokegen.7z.zip' (1715 KB)
> > Thank you again.
> comprehensive.
> Have fun!
> Thomas
WOW, it is absolutely marvellous. What a shame that it is not available online.
Anyhow, it made me wonder what hidden treatures can be found in your archive ;)
Date: 20 Feb 2020 02:36:18
Message: <5e4e36f2$1@news.povray.org>
Op 19/02/2020 om 23:43 schreef Kima:
>>> Thank you again.
>> comprehensive.
>> Have fun!
>> Thomas
Too many! ;-) In his days, "Uncle Tyler's Get Away" was the Place to be
(https://web.archive.org/web/20080514063612/http://home.pacbell.net/tylereng/index.html).
I am not as systematic as he was but over the years I collected a list
of about 240 POV-Ray users, each represented by at least one utility or
other which interested me somehow.
[looking furtively around] I know that there other collectors lurking in
the shadows...
