POV-Ray : Newsgroups : povray.general : Spiral Ribbon.. Server Time
27 Jul 2025 11:52:43 EDT (-0400)
  Spiral Ribbon.. (Message 1 to 7 of 7)
Subject: Spiral Ribbon..
Date: 15 Aug 2003 17:20:01
Message: <web.3f3d4dd86201acfc6af901ee0@news.povray.org>
Is there an inc file out there, or a feature already included in Pov-Ray
that would let me easily make a Ribbon of a certain thickness and width
turned into a spiral with a certain radius and a set pitch. If you are
confused think of the DNA double helix, and the twisting ribbon. There are
2 of them in DNA, but i just need 1
Subject: Re: Spiral Ribbon..
Date: 15 Aug 2003 18:07:26
Message: <fT57KAAkjVP$EwPy@econym.demon.co.uk>
You could use a f_helix1 isosurface, like this:
isosurface {
  function { f_helix1(x,y,z,1,5,0.01,0.3,30,0,0) }
        max_gradient 1.5
        accuracy 0.00001
        contained_by {box {-<0.31,1,0.31>,<0.31,1,0.31>}}
        pigment {rgb x}
The parameters I've used in f_helix1() after the x,y,z are
1       Number of helixes (e.g. 2 for DNA double helix)
5       Period (number of turns per unit length/2Pi)
0.01    Half-thickness of ribbon
0.3     Radius of the helix
30      Ratio of ribbon width to thickness
0       Cross section shape (0=square, 1=circle, 2=diamond)
0       Cross section rotation
The x and z parameters in the size of the box container need to be at
least (Radius of helix) + (Half-thickness of ribbon) to avoid clipping.
If you want a thicker ribbon, with the same width you should decrease
the (Ratio of ribbon width to thickness), and increase the size of the
container box.
Mike Williams
Gentleman of Leisure
Date: 15 Aug 2003 23:12:50
Message: <3F3DA095.C09C0838@pacbell.net>
? http://povray.org/resources/links/3D_Programs/Shells_Spirals_and_Helixes/
Ken Tyler
Date: 16 Aug 2003 20:25:01
Message: <web.3f3ecaa75af411b36af901ee0@news.povray.org>
sorry to bother you again, but is there a way to make a spiral with a
trapezoid cross section, without rendering a lot of thin trapezoids rotated
and with a changing height?
   __
 /    \     - Trapeziod
/______\
>Ken Tyler
Date: 16 Aug 2003 21:21:42
Message: <cjameshuff-75D06F.20184216082003@netplex.aussie.org>
In article <web.3f3ecaa75af411b36af901ee0@news.povray.org>,
The best way I can think of to accomplish what you're trying is to use a
mesh. There's a parametric include by Ingo that may be able to do this,
or it would be fairly trivial to write custom code.
Ingo's page, with param.inc as well as other mesh includes and macros:
http://members.home.nl/seedseven/
http://tag.povray.org/
Date: 17 Aug 2003 00:34:08
Message: <pWZmLAAmVwP$EwY6@econym.demon.co.uk>
>   __
> /    \     - Trapeziod
>/______\
I'm not quite sure what you mean.
Is this anything like what you're after?
#include "functions.inc"
camera { location  <0, 1, -4> look_at <0, 0.2 0> angle 35}
light_source {<-100,200,-100> colour rgb 1}
isosurface {
 function {f_helix1(x,y,z,1,10*(2.2+y),0.05*(1.2-y),0.4*(1.2-y),1,0,0)}
   max_gradient 1.2
   contained_by{box {-<1,1,1>,<1,1,1>}}
   pigment {rgb .9}
   finish {phong 0.5 phong_size 10}
   no_shadow
Mike Williams
Date: 17 Aug 2003 19:40:01
Message: <web.3f4011995af411b3f970f2fd0@news.povray.org>
not really,
i am making a thread for a screw, and am currentl using many many cones
roted around the center cylinder, with a constant radius, but with changing
height. So if you look at the cross sectioni cut of the thread it will look
like a trapezoid, or truncated cone cut in half from top to bottom.
But using many cones takes a very long time to render.
