POV-Ray : Newsgroups : povray.general : POV-Ray Origins Server Time
13 Aug 2026 10:39:08 EDT (-0400)
  POV-Ray Origins (Message 24 to 33 of 33)
Subject: Re: POV-Ray Origins
Date: 29 Mar 2026 09:51:35
Message: <69c92e67$1@news.povray.org>
David Buck writes:
> DKBTrace was originally developed on an Amiga computer in C.
I'm the author of the Atari 2D Graph Describer and 3D Modeller,
called Eureka 2.12, written in C language. It'll be 40 next year.
Eureka 2.12 is a software package originally developed for Atari ST
till Falcon computers. It is announced as a "2D Graph Describer and 3D
Modeller", meaning it allows users to create and manipulate 2D graphs
and 3D models. The software is notable for 2D curves analysis and 3D
modelling capabilities, enabling users to generate graphs from
mathematical functions (including fractal images like Julia and
Mandelbrot sets) and then map these graphs onto 3D surfaces. Users
can also create 3D animations and transfer images or animations from
other tools like the Persistence Of Vision Raytracer (POV-Ray).
a classic Atari application, often used in educational and creative
contexts. The software can be run on modern systems using Atari
Virtual Machine like ARAnyM (Atari Running on Any Machine).
I always was impressed with POV-Ray, Mathematica from their beginning!
Many thanks for your inspiration =)
Best regards,
Author of Eureka 2.12 (2D Graph Describer, 3D Modeller)
<https://eureka.atari.org/>
Date: 29 Mar 2026 12:10:00
Message: <web.69c94d8251ecd288ddc052af59126100@news.povray.org>
yesbird wrote:
> On 29/03/2026 13:49, GioSeregni wrote:
> > eh eh the output is never a problem
> > but I don't see the input for pov...
> > aand DXF very useful
> I have a DXF converter as a separate C program:
> https://github.com/syanenko/dxf2pov
> but found it unuseful in Studio, as it's outdated and rarely used now.
> As for POV input, I don't see the use case for it.
> Who wants to write a scene on SDL and then transfer it somewhere (where
> and why ?).
> > Instead the calls to the working and writing routines are entrusted to a second
> > executable written in QB64PE, which is great and compiles in C++.
> Is this a QBasic and is it still alive ?
> It was the first language I learned, so many years ago ...
> > It's the only way to publish, today any executable file, if it doesn't have the
> > blackmail price for certification, it gives false positives.
> Wish you good luck with publishing, hope it will be demanded.
> YB
I don't need that someone uses it
If anyone finds it useful, fine. Otherwise, it's the same for me.
The DXF format is the most robust for transferring from CAD, which I prefer to
modeling because it's more precise.
Date: 31 Mar 2026 06:05:00
Message: <web.69cb9c1751ecd28848bf72fa6cde94f1@news.povray.org>
hi,
> Hi everyone.  David (Kirk) Buck here.  I'm the original author of
> DKBTrace and POV-Ray.
(belated) "hello".
> David Buck <dav### [at] simberoncom> wrote:
> > I thought it would be interesting to add octree subdivision to the
> > raytracer.
> I do believe that we have Binary Space Partitioning (BSP) for most things.
> https://www.povray.org/documentation/3.7.0/r3_2.html
> 3.2.8.6 BSP Bounding
> > I always thought that it would dramatically speed up the rendering by
> > eliminating the vast majority of the ray/object intersection calculations.
> > I would like to see the POV-Ray rendering code extracted as a shared
> > library with an API interface.  That way, I can write other software to
> > do any modeling I want without having to output a scene file and run the
> > renderer separately.  I think that would open the door to a lot of new
> > innovation.
> It would, and Chris Cason has discussed going in this direction as well.
> We need developers.
> > Thanks, those were fun questions.
> > David
I had hoped that (at least) this particular part of the dialogue would continue.
regards, jr.
Date: 2 Apr 2026 04:25:00
Message: <web.69ce276551ecd28816086ed06830a892@news.povray.org>
> On 2026-03-27 11:51 a.m., Bald Eagle wrote:
> > Were there things that you've always wanted to implement, but never did?
> raytracer.  The main raytrace loop goes:
>     For each ray
>        For each object in the scene
>           If the ray intersects the object
>              Collect the intersection point
>        End
>     End
>     Find the closest intersection point and calculate the lighting
> With an octree, you divide the space into large cubes and subdivide
> those cubes that contain something.  The algorithm, then, becomes
>     For each ray
>        Traverse empty cubes until you find a non-empty one
>           Calculate intersections with the small number of objects in
> that cube.
Does that mean the BSP and BVH are currently not doing this? that would be a
major bottleneck! (or did you mean you wish you had implemented it yourself?)
https://www.povray.org/documentation/3.7.0/r3_2.html#r3_2_8_6
THANKS for all of this of course ! :-) (we all hope that when you retire you get
back to more poving!)
Date: 2 Apr 2026 12:57:45
Message: <69cea009$1@news.povray.org>
Really cool to see you around again, David - it's always interesting to
see what folks are doing with the software you originally created.  I
started playing with POV-Ray in the late 80s/early 90s, and while I spend
less time playing with it today, it is also fun to see the community that
has grown out of that software and how it has changed over the years.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 2 Apr 2026 16:57:27
Message: <69ced837$1@news.povray.org>
>>      For each ray
>>         End
>>      End
>>      For each ray
>> that cube.
I like the elegance of an octree solution.  I can't say whether it's
better or worse than BSP or BVH.  With octrees, however, the ray can be
traced using a simple variation of a line drawing algorithm.  It might
even be possible to do it with integer arithmetic until you hit an
object.  I simply find it an elegant algorithm and was curious if it
would speed up POV-Ray.  It has the same problem as BSP's where you need
to build up the model before you can do the raytracing itself.  I just
find it interesting.
Post retirement, I think it's unlikely I'll get back into the POV-Ray
code itself, but I may create software that can create models that
POV-Ray can render.
David Buck
Date: 2 Apr 2026 22:00:00
Message: <web.69cf1edb51ecd2889558a085e358f448@news.povray.org>
I've been using POV-Ray for a few months now, and I have to say it's a
masterpiece of software. And, interestingly enough, my birthday is March 26, so
I'll consider this the best birthday present anyone has ever given me.
Thanks!
Date: 14 Apr 2026 17:50:00
Message: <web.69deb5f851ecd2889f3d5c2c199194f2@news.povray.org>
Have been using POV-Ray for the past 30 years.
Date: 15 Apr 2026 08:40:00
Message: <web.69df866951ecd28876d02faa25979125@news.povray.org>
You're the bullet physics playground guy!
Hello - nice to see you here.  :)
- BE
Date: 23 Jul 2026 10:35:00
Message: <web.6a62265f51ecd28852a1fdbadabc9342@news.povray.org>
> It's now been about 40 years since I wrote DKBTrace.  It seems like
> forever ago, but I can still remember the thrill of generating (very
> slowly) 3D images of scenes I modeled with a text file using software I
> wrote myself.
> I check this forum periodically, but mostly I just lurk to be honest and
> check out what people are doing.  I was about 24 years old when I first
> wrote DKBTrace. I'll soon be turning 64 years old and I'm aiming at
> retiring soon.
> I've always been interested in spreading the joy of programming and
> using computers in a creative way.  DKBTrace was one of many projects
> I've worked on simply for the joy of coding.  Interestingly, when I
> released DKBTrace, I thought I was done with it and was releasing it to
> allow others to have fun as well.  It seems that the fun has been
> continuing for the past 40 years.
> I'm going to commit to checking this newsgroup more frequently for a
> while and responding to posts.  If you have any questions or comments
> I'll try to respond as quickly as I can.
> David Buck
Thank you, David, for DKBTrace, POV and your support that follows. It sure
changed my 3D career path in the early 90's. It allowed me to produce art in a
new and fantastic way. I used POV early on to produce renders for Columbus
architects, which eventually lead to becoming a design architect and using 3D
extensively for presenting concepts to my clients. POV remains dear to my heart.
Congrats on turning 64 and retirement! I'll be turning 68 myself - time does
fly. I'm just get back to some new POV work and will try to post more often.
God Bless,
Mike.
