POV-Ray : Newsgroups : povray.general : Passing macro as parameter Server Time
29 Apr 2025 22:37:46 EDT (-0400)
  Passing macro as parameter (Message 1 to 7 of 7)
Subject: Passing macro as parameter
Date: 13 Dec 2021 13:36:49
Message: <61b792c1$1@news.povray.org>
I am working on my own little animation framework for astronomy related
scenes.
I would like the ability to pass a macro name to another macro that will:
1) do some animation-related setup and housekeeping
2) call the macro passed as parameter
3) do some more animation-related setup and housekeeping
Unfortunately I have not found a way to pass a macro name as parameter
and be able to call it. Is this use case really beyond the capabilities
of the language, or I just have to find the right syntax?
Thank you
Subject: Re: Passing macro as parameter
Date: 13 Dec 2021 14:10:00
Message: <web.61b79a1b80f100541f9dae3025979125@news.povray.org>
http://www.povray.org/documentation/view/3.7.0/479/
Parse_String(String). This macro takes a string, writes it to a file, and then
includes that file. This has the effect of parsing that string:
"Parse_String("MyColor")" will be seen by POV-Ray as "MyColor".
Parameters:
String = The string to be parsed.
So, the idea is that you pass the macro name as a string parameter, and then
parse that string to turn it into an SDL directive.
If you provide some scene code with some comments describing what you want your
code to do, maybe someone can suggest an alternative method for accomplishing
the same goal.
Date: 13 Dec 2021 16:48:58
Message: <61b7bfca$1@news.povray.org>
Fantastic, I'll try that.
> the same goal.
I'll perform some experiments and gladly publish them.
Thanks!
Date: 14 Dec 2021 03:40:00
Message: <web.61b8575e80f10054ea8869266cde94f1@news.povray.org>
hi,
fwiw, my recent 'Foreach()' macro too uses that "trick".  given that your
project is well underway, you may not find it very useful though :-).
<https://drive.google.com/file/d/11PqhmEP2p1nEOH6jCJC653B08NfHVmOn/view?usp=sharing>
regards, jr.
Date: 14 Dec 2021 06:50:00
Message: <web.61b8846f80f100541f9dae3025979125@news.povray.org>
What, did you think you think I came up with all these great ideas on my own?
I steal them from you!   :D   :P
Date: 15 Dec 2021 00:57:31
Message: <61b983cb$1@news.povray.org>
It worked pretty good; a simplified version of what I have done is:
#macro animation_step(step_function, duration)
     #declare local_clock = (clock - animation_framework_current_stage)
/ duration;
     Parse_String(concat(step_function, "(local_clock)"))
I put in some more work today to improve my animation framework and used
Parse_String() a couple more times.
Thanks
Date: 19 Dec 2021 16:26:43
Message: <61bfa393$1@news.povray.org>
> / duration;
> #end
This is brilliant. I wish I'd thought of it years ago.
dik
