POV-Ray : Newsgroups : povray.general : light_group question Server Time
15 Aug 2025 20:16:33 EDT (-0400)
  light_group question (Message 1 to 5 of 5)
Subject: light_group question
Date: 21 Apr 2002 00:29:20
Message: <3cc24020$1@news.povray.org>
I'm trying to use light_group to light a plane and then general scene lights
to light a sphere and have it cast a shadow on the plane, but I am getting
two shadows on the plane--one from the general light and one from the
light_group light that isn't supposed to be illuminating the sphere. Why is
this occuring? Is there a way to get it to do what I want it to?
See image and code in p.b.i
Thanks,
jkb
Subject: Re: light_group question
Date: 21 Apr 2002 01:18:06
Message: <3cc24b8e$1@news.povray.org>
"jkb" <joh### [at] hotmailcom> wrote in message
news:3cc24020$1@news.povray.org...
lights
is
You're global_lights .7 is seen as global_lights 1 since it is apparently
rounded up. That keyword operates according to on off, 1 0, yes no, true
false. Change that and you'll get one shadow.
bob h
Date: 21 Apr 2002 16:56:05
Message: <3cc32765@news.povray.org>
> false.
Hmm, apparantly I have misunderstood the use of global_lights. In further
misunderstanding, though, even with global_lights on, the light causing the
second shadow shouldn't interact with the ball, right? I thought it should
only interact with the plane, and adding global lights allows for
interaction of other lights in the scene to also interact with the plane. As
it is, light_group doesn't do a whole lot if lights in the light group
interact with other objects as well. A long way of saying that turning off
global_lights causes the shadows cast onto the plane to be darker than I
want them to be. I'll have to experiment some more and figure out a way
around that.
jkb
Date: 21 Apr 2002 17:56:39
Message: <3cc33597@news.povray.org>
In article <3cc32765@news.povray.org> , "jkb" <joh### [at] hotmailcom>
Did you check the documentation and sample files?
> In further
Wrong, it should.  A light_group exists to allow additional lights to light
objects inside it.  Only light is considered, nothing is said about objects.
However, I agree that what you are suggesting is an interesting feature
request (that is, i.e. a "global_objects on/off" switch).  While it is too
late for POV-Ray 3.5 I will try to keep it in mind for a future version.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 21 Apr 2002 20:00:35
Message: <3cc352a3$1@news.povray.org>
I did, and on rereading them global_lights is clearly on/off. I don't know
where I got the idea it was variable 0-1.
I would like to see it included. Thanks for the consideration. BTW, great
job with 3.5. I'm new to pov-ray, but it the output I've seen from 3.5 looks
even better than earlier versions.
