![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello,
I have a problem with Pov3.5beta9 and noone seems to have mentioned it yet..
Sorry, I can't follow all threads in all groups, but a search didn't give a
result either.
Why does the following code produce some abrupt changes in the Y direction?
The result is these shadowed lines and dots. I tried different scales and
patterns, and different resolutions of the function. You're welcome to
experiment with this yourself, to see that the problem is not something
dull, like too few triangles or a bad scale.. I don't know what it is,
actually.
camera { location <12,18,-12>*.9 look_at 0 }
light_source { <-38,60,-30>, 1 shadowless }
#declare Pigm=function { pattern { bumps scale .014 } }
height_field { function 500,500 { y-Pigm(x,y,z) }
pigment { rgb 1 }
translate -.5 scale <40,.3,40> rotate 90*y
Hugo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Problem with patterns in height_fields
Date: 4 Jan 2002 17:09:36
Message: <3c362820@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
direction?
> actually.
That's because your function gives you negative values.
Heightfields doen't work with negative values.
Change your function to function{Pigm(x,y,z)} and it'll work.
If you want to invert your heightfield just use function{-Pigm(x,y,z)}
#local T=text{ttf"timrom.ttf""Simon Adameit".01,0}#local Y=1;#while(Y>-1)
#local X=0;#while(X<7)#local O=trace(T<X,Y><X,Y>+z);cylinder{<X-3,Y,5>*.01
<X-3,Y,5>*.01+5e-3,5e-5pigment{rgb 25*O}}#debug chr(83-(O.x=0)*51)#local
X=X+.05;#end#debug"\n"#local Y=Y-.05;#end
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you!
I'll look into this.. :o)
Hugo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 5 Jan 2002 04:51:41
Message: <3C36CCA6.A1FFDFFF@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> actually.
The function in heightfields is not the same as in an isosurface. It is
evaluated in the xy-plane and the function value determines the height of
the heightfield. Try:
height_field { function 500,500 { Pigm(x,y,0) }
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>result either.
POV-Ray v3.5 beta bug reports and discussions should be posted to
povray.beta-test, as noted at http://www.povray.org/ on the beta 9 download
page.
The group povray.general would be the correct place to post when it
concerns the current release version of POV-Ray, which is v3.1g.
Thanks for your participation.
(followups to p.beta-test)
Alan
ako### [at] povray org
a k o n g <at> p o v r a y <dot> o r g
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
