POV-Ray : Newsgroups : povray.general : "Cutting" in isosurfaces Server Time
20 Nov 2024 06:46:52 EST (-0500)
  "Cutting" in isosurfaces (Message 1 to 9 of 9)
Subject: "Cutting" in isosurfaces
Date: 3 Oct 2001 21:02:17
Message: <3BBBB518.63F04E04@iki.fi>
I am in need of source code or explanation of how to make plane "cut" or
"split" iso surfaces. I know I have seen a picture of metallic rounded
box being cut to pieces in a smooth way; like you had cut some irl clay
object with scissors.
So, if anybody can tell me how to do that, I'd appreciate it :-).
          /"\                           |    iki.
          \ /     ASCII Ribbon Campaign |    fi/
           X      Against HTML Mail     |    zds
Subject: Re: "Cutting" in isosurfaces
Date: 4 Oct 2001 04:13:53
Message: <3bbc1a41@news.povray.org>
"Jari Juslin" <zds### [at] ikifi> wrote in message news:3BBBB518.63F04E04@iki.fi...
Maybe this is what you're thinking of.
#version 3.5;
light_source {<10,10,-100>,1}
#include "functions.inc"
#declare X=3;
#declare Y=2;
#declare Z=1;
difference {
        isosurface {
                function {f_rounded_box(x,y,z,0.5,X,Y,Z)}
                contained_by {box {-<X,Y,Z>,<X,Y,Z>}}
        plane {+x,1}
        pigment {rgb 1}
        rotate -30 translate 10*z
And if you intend to use both halves you'd have to duplicate this with a
plane {-x,1}, which of course means translating the two halves apart or
they'd just be as one piece.
From what I gather about it other isosurfaces might not fair too well, at
least not without first adding max_gradient and/or accuracy settings.  But
this is basically the same as any other CSG is done.  Nothing real special
about it.
Bob H.
Date: 4 Oct 2001 04:40:40
Message: <3BBC2087.C7239381@iki.fi>
In fact, no :-). The picture I saw had the cut edge also "rounded",
blobby-like way, and that blobby-like cutting object in two was the
effect I am looking for. I didn't see source that time, so it might have
been made of pieces; I think "blobby" intersection of superellipsoidic
cube and planes could reproduce one of those parts, but I was hoping
there would be some way just to split object in two.
          /"\                           |    iki.
Date: 4 Oct 2001 05:05:31
Message: <3bbc265b@news.povray.org>
"Jari Juslin" <zds### [at] ikifi> wrote in message news:3BBC2087.C7239381@iki.fi...
Oh.  I *think* I know what you're saying now.  Inclusion of a deformation
such as what happens when unsliced bread is cut into, pressing the surface
down as the knife goes in.
That requires a inside curve, the kind a cylinder can have if cut open along
its length, which can then be used to CSG difference from something else.
There must be a way to apply a cut into a isosurface like that, I just don't
know how right now.  I'd guess a subtraction of one shape from another could
do it.
Heck, now that I think about it, you partly answered yourself there by
mentioning "blobby".  Using a blob with negative strength and thinly scaled
component you could move it through the positive strength component(s) and
get just such an effect.  That is, if I understood the idea this time.
Bob H.
Date: 4 Oct 2001 16:26:26
Message: <1f0rxzi.88e6cotlyb5gN%smellenbergh@skynet.be>
Have a look at the isosurface manual at
http://users.skynet.be/smellenbergh/iso_ind.html
The part on "combining functions" has an example of "Blobbing
difference" which does exactly what you want. If you are using Pov
3.5beta, you should adjust the syntax a little though.
e-mail:sme### [at] skynetbe
Date: 4 Oct 2001 20:19:21
Message: <3BBCFC89.A7F58749@iki.fi>
Cool, thanks :-). I _knew_ I had seems such things somewhere.
          /"\                           |    iki.
Date: 5 Oct 2001 01:14:53
Message: <PmAo0BA6DUv7EwPc@econym.demon.co.uk>
Do you mean something like this?
What I've done is blobbed together a sphere and two double planes
inversed (one flipped y for x, giving a vertical cut).
The clever bit is that I've multiplied the double plane functions by
some value, "Edge_Sharpness", so that points close to the cut are more
strongly affected by the double plane functions than by the sphere
function. Without this trick, the edges of the cut are very round
indeed.
The inversing of the double planes is done by adding Blobbyness^(Plane(x
,y,z)*Edge_Sharpness) instead of subtracting it as you would normally do
when blobbing isosurfaces together.
#declare Cut_Width = 0.1;
#declare Blobbyness = 0.001;
#declare Edge_Sharpness = 6;
#declare Sphere = function {f_sphere(x,y,z,1)} // Sphere
#declare Plane  = function {(abs(x)-Cut_Width)} // Double plane
isosurface {
  function { (1+Blobbyness) - Blobbyness^Sphere(x,y,z)
              + Blobbyness^(Plane(x,y,z)*Edge_Sharpness)
              + Blobbyness^(Plane(y,x,z)*Edge_Sharpness)
        max_gradient 3000
        contained_by{sphere{0,1.01}}
        pigment {rgb 1}
Mike Williams
Gentleman of Leisure
Date: 5 Oct 2001 08:17:21
Message: <3bbda4d1@news.povray.org>
    This seems to stop here for no reason.
Parse Error:    Expected 'operator', { found instead
Date: 5 Oct 2001 08:31:13
Message: <3bbda811$1@news.povray.org>
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3bbda4d1@news.povray.org...
Hey, I own the copywrite on that particular f***-up
Here's your hat:
cone
  1*y,  0.0,
  -1*y, 1.0
  open
  pigment{my_white_with_a_big_fat_D}
