POV-Ray : Newsgroups : povray.general : IES Files Server Time
20 Nov 2024 12:43:09 EST (-0500)
  IES Files (Message 1 to 7 of 7)
Subject: IES Files
Date: 21 Sep 2001 06:09:26
Message: <3BAB1186.3AD52F38@psy.kuleuven.ac.be>
Hello everybody,
Do you know whether is possible (or how hard it would be) to read
photometric information of a "real" light (IES file) and create the
corresponding POV light?
Thanks in advance.
pedro
Subject: Re: IES Files
Date: 21 Sep 2001 07:38:49
Message: <3BAB2703.1EFD7F22@engineer.com>
What does an IES file look like? The intensity can be coded to the
alpha channel of a spherical image map which is mapped to a sphere
around a light source.
_____________
Kari Kivisalo
Date: 21 Sep 2001 07:48:17
Message: <3BAB2904.2BDC7773@ignorancia.org>
  Hmmm... I had a look at that topic in the past, and while I see how to
use color and distance information, I've no idea on how to relate light
intensity to POV-Ray light_sources... and of course I don't understand
your point about using alpha channel for that. Please, enlighten us!
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 21 Sep 2001 07:53:32
Message: <Xns91238D5239EDCseed7@povray.org>
http://www.ledalite.com/resources/software/index.html
"IES File Viewer" parses ies files and comes with a description of ies
files
"IES Photometry File" has ~400 ies files.
Ingo
Date: 21 Sep 2001 08:26:49
Message: <3BAB3242.11D7FB3C@engineer.com>
You are free to choose any units and then interpret the results
based on this decision. Just remember that pov outputs only
integer values (0-1) so you will have to choose a scene dependant
scale factor to prevent overflows.
Or you can use the transmit channel of a pigment if the data
is red in and interpolated within pov script. I don't know
any other way to control the radiation distribution of a light
source. There was a patch for light sources which did essentially
the same thing.
_____________
Kari Kivisalo
Date: 24 Sep 2001 06:58:20
Message: <3BAF11B7.4D86F0FA@psy.kuleuven.ac.be>
Thanks for the answers, but I have to admit I'm not quite following:
what if I know the luminance of a particular bulb (real) and I
want to model it in POV. Is there a way to traduce, say, candelas per
sqr meter, in POV units?
Txs again!
> the same thing.
> _____________
> Kari Kivisalo
Date: 24 Sep 2001 07:08:24
Message: <3BAF1411.97BC2E3F@scifi-fantasy.com>
> following: what if I know the luminance of a particular bulb
> (real) and I want to model it in POV. Is there a way to traduce,
> say, candelas per sqr meter, in POV units?
To elaborate Pedro's question, if 1 POV unit = 1 meter, how do you
('cuz I jest KNOW yer gonna say that it matters what your POV
units stand for)
Tim Cook
Version: 3.12
