POV-Ray : Newsgroups : povray.documentation.inbuilt : Radiosity block `brilliance` setting Server Time
16 Mar 2026 17:16:29 EDT (-0400)
  Radiosity block `brilliance` setting (Message 1 to 5 of 5)
Subject: Radiosity block `brilliance` setting
Date: 16 Jun 2021 08:30:34
Message: <60c9eeea$1@news.povray.org>
Hi folks,
The following - or something along those lines - needs to be woven into
the Radiosity reference documentation on the Wiki
(http://wiki.povray.org/content/Reference:Radiosity); in addition, it
might be worth mentioning in the what's-new section:
--------------------- Syntax:
(The syntax needs to be extended to include another setting,
`brilliance`, which takes a boolean parameter, i.e. `on` or `off`.)
--------------------- Description:
By default, radiosity computations presume that the texture to render
has a `brilliance` setting of 1. In scenes that make heavy use of
radiosity, this may cause surfaces to look excessively dull.
As of POV-Ray v3.8, you can force radiosity to respect the `brilliance`
finish parameter, by specifying `brilliance on` in the radiosity block.
Note however that this comes at a cost of rendering speed, especially
when combining surfaces with various different `brilliance` settings in
close proximity.
Subject: Re: Radiosity block `brilliance` setting
Date: 16 Jun 2021 17:05:00
Message: <web.60ca6687687a814e6adeaecb3f378f2@news.povray.org>
> Hi folks,
> close proximity.
Added so it doesn't get lost, do not hesitate to advice me restyling if needed.
Date: 16 Jun 2021 20:20:50
Message: <60ca9562$1@news.povray.org>
Am 16.06.2021 um 23:00 schrieb Mr:
Looks good. However, I _think_ it doesn't need `#version 3.8` to work.
Which, now that I think of it, isn't really such a good idea, because it
means it can be used in a scene that claims to be a v3.7 scene, and then
someone gets surprised when they try to render that scene with genuine
v3.7...
I think I've just found myself some more work cut out for me...
So leave that in the documentation, because that's how it _should_ be.
Date: 17 Jun 2021 04:21:03
Message: <60cb05ef$1@news.povray.org>
On 6/16/21 5:00 PM, Mr wrote:
> clipka <ano### [at] anonymousorg> wrote:
>> Hi folks,
>> close proximity.
https://wiki.povray.org/content?limit=50&days=7&enhanced=1&title=Special:RecentChanges&urlversion=2
made one change and added support for the /new/ section. it's needed for
the document map... section numbering
Date: 17 Jun 2021 05:55:55
Message: <60cb1c2b$1@news.povray.org>
Am 17.06.2021 um 10:21 schrieb Ash Holsenback:
Thanks, much appreciated.
