POV-Ray : Newsgroups : povray.documentation.inbuilt : Some mistake in reference 3.4.4.1.2 spotlight section Server Time
25 Mar 2026 21:37:51 EDT (-0400)
  Some mistake in reference 3.4.4.1.2 spotlight section (Message 1 to 7 of 7)
Subject: Some mistake in reference 3.4.4.1.2 spotlight section
Date: 19 Nov 2013 04:55:00
Message: <web.528b347ce5b41d77f9d479350@news.povray.org>
I found some probable mistake in POV-Ray reference document at spotlight
section:
1. The sentence which is just two column before the light intensity multiplier
diagram states that
"The values for the radius, and tightness parameters are half the opening angles
 of the corresponding cones, both angles have to be smaller than 90 degrees."
which tightness should be replaced by falloff. Another flaw is that it say both
angles have to be smaller than 90 degrees but I saw POV-Ray 3.7 can give an
angle more than 90 degrees in that term.
2. The description for the forth diagram in this section "To give the tightness
value full control over the spotlight's appearance use radius 0 falloff 90. As
you can see from the figure below." should be correct. ^^^^^^^^^^^^^^^^^^^
I think that is radius 90 falloff 90 for the diagram.
Subject: Re: Some mistake in reference 3.4.4.1.2 spotlight section
Date: 19 Nov 2013 07:52:50
Message: <528b5f22@news.povray.org>
> section:
> diagram states that
yes I think this is just a typo ... i'll change it
true enough angles greater than 90 degrees /are/ excepted ... i'm
wondering if /have/ in the above sentence ought to be /should/
i played around with this (quickly) and it doesn't seem to make a
difference if it's 0 or 90
anyone else have a moment to add a bit of clarity before i decide whats
needs to be changed?
Date: 19 Nov 2013 07:58:42
Message: <528b6082$1@news.povray.org>
see p.b.images
Date: 19 Nov 2013 09:02:22
Message: <528b6f6e@news.povray.org>
Am 19.11.2013 13:52, schrieb James Holsenback:
>> tightness
>> falloff 90. As
It does as soon as tightness comes into play.
There /is/ something fishy about that diagram and the paragraph before
it. The diagram says something about "negative radius", and indeed
doesn't match a radius of 0.
I think in the long run the section should be overhauled, and give
sample renders instead of (or at least in addition to) diagrams.
Date: 19 Nov 2013 09:18:47
Message: <528b7347$1@news.povray.org>
>>> tightness
>>> falloff 90. As
ah ... yes i know. i guess i should have said for a given tightness both
radius values look practically the same
yeah ... there /does/ appear to be more than one rough spot, so yeah i
agree. on my todo list (sigh)
Date: 19 Nov 2013 09:45:33
Message: <528b798d@news.povray.org>
Am 19.11.2013 15:18, schrieb James Holsenback:
>>>> tightness
>>>> falloff 90. As
For a tightness of 0 it makes quite the difference, so there's reason to
believe that the same goes for other small values.
Date: 20 Nov 2013 07:10:01
Message: <web.528ca572d765f2a0f9d479350@news.povray.org>
Ha.
Really? If this is the case, "should" is better than "have" in my opinion.
yes, the situation for a tightness of 0 it is not fit, so I raise this question.
