On 04/10/2025 23:29, Maetes wrote:
> Yes, "something" like that.
> But instead the code-block many sliders and checkboxes and select-boxes.
> And only one or two object (box and sphere) to show the texture.
> And a download-button to get the texture.
Don't you mixing a texture and material ?
http://www.povray.org/documentation/view/3.60/324/
http://www.povray.org/documentation/view/3.6.1/331/
In any case implementation will not be difficult - I guess, you can try
it yourself. You will only need to install node.js and master
javascript, also PHP alittle.
> This treejs looks indeed very promising, maybe I'll give it a try for my own
> website.
Yes, it's really cool. Almost standard-de-facto for WegGL/WebGPU works
now.
> Your all2mesh-tool:
Now it's "POV-Ray studio" :).
> If you could extract the textures also, I would bring the Mars-Rover or
> Ingenuity to life.
Maybe later, after finishing two active projects.
YB
> Ingenuity to life.
Use search, Luke !
https://products.aspose.app/3d/extractor/glb
And see attachment ... :).
YB
Download 'ingenuity mars helicopter.zip' (1973 KB)
Just for kicks, I searched Thingiverse for Povray . . .
Rick's Chainmaker for POVRay
https://www.thingiverse.com/thing:726783
Zeycus' Abstract Chess Set
Chess set I designed in 2001, originally in PovRay.
Recently used Openscad to create the STL file.
https://www.thingiverse.com/thing:952393
Superellipsoid
https://www.thingiverse.com/thing:12419
Supershape
https://www.thingiverse.com/thing:12770
Cylindrical container holder rendered in POV-Ray
https://www.thingiverse.com/thing:1932960
- BE
Chainmaker is rather interesting ...
Btw, Bill, I need your advice. I am working on online viewer of math
objects (screenshot attached):
https://mathview.yesbird.online/
and now it has export only to OBJ.
Is it worth adding a POV exporter to it, taking in account that POV-Ray
already has a powerful library for generating math surfaces ?
Remembering quote by Steve Jobs: "Deciding what not to do is as
important as deciding what to do" ? :)
YB
Download 'mathview.png' (476 KB)
Preview of image 'mathview.png'
Well,
All I can say is that although we have things like parametric, isosurface, and
polynomial - what we don't have is a visual modeler for such things.
There does exist MathMod - which can be quite cryptic, and Desmos - which can
help visualize equations. But neither have any sort of export feature.
I'm a fan of the mathematical objects - it's probably one of my favorite things
to play with and render - but after over a dozen years of experience, I'd say
that there are usually only a few select shapes that have real, broad utility.
sphere, cylinder, torus, Dupin cyclide, etc.
Now, on the other end of the spectrum, when you need a specialized shape, and it
has to have very exacting dimensions and attributes, then parametrics and
implicit isosurfaces are probably the only things that will fit the bill -
especially when combined with surface displacement.
And those things can be VERY difficult to visualize.
I really like what you're doing, and there are things that I would want, and
would be great to experiment with. But I don't know what sort of workload is
necessary to make them happen, or what other projects you have to wrap up.
So, ultimately, I'd say that you're going to have to decide for yourself.
We can discuss this more, but I'll leave you with all of that to think about.
- BW
On 28/09/2025 00:27, yesbird wrote:
> Finally, after two sleepless nights I finished a web application that
> converts obj, fbx, glb, gltf, stl formats to mesh2:
> https://povlab.yesbird.online/all2pov
> I tested it only on a limited number of files, so some issues
> (especially related to displaying a model) are possible, testing now in
> progress. Please send any kind of feedback: bug reports, suggestions,
> requests to implement, etc.
Well done on the initiative, but like others here, I can't convert OBJ
files. My OBJ files are fine. With my silly Perl script, conversion to
POV works fine.
I think you still have some work to do to refine all this;
ps: yes, my Firefox 143.0.4-64 is compatible with WebGL 1 & 2.
kurtz le pirate
compagnie de la banquise
> POV works fine.
Thanks for feedback, could you please provide a little bit more
details - why can't you convert them ? And who else can't ?
Please send me your OBJ and content of _console_ tab (F12).
The project is in beta state, so debug information is highly
appreciated.
YB
Sure, the reason of OBJ loading issues was lack of 'mtl' file,
OBJ materials is not supported yes, will implement it later.
I made a fix to just ignore them.
PS: Frog is nice ! (attached)
YB
Download 'frog_web.png' (173 KB)
Download 'frog_pov.png' (36 KB)
Preview of image 'frog_web.png'
Preview of image 'frog_pov.png'
On 30/09/2025 12:07, Mr wrote:
> I think you should look at GIS packages (QGis/OpenSceneGraph...), ...Sorry for
off-topic, but I read that you are working with Blender
(POV@Ble). I have idea about effective conversion from Blender to
POV-Ray: If only Blender can work with glTF or GLB file's .extras
property that can store arbitrary JSON content, then we can use it
to store material name and then convert it to POV with my converter.
It's possible not to use a web-based GUI version, but to create a
command line utility running under node.js.
We can use for the start this impressive materials collection - the
royal gift from Mike Miller:
https://drive.google.com/file/d/1PncYI4G2ssqIXjK1rMej-PgAZ9Gnatz1/view?usp=sharing
What is your opinion ?
YB
Download 'mat.png' (258 KB)
Preview of image 'mat.png'
Just following up on this,
I think that for your parametric equations, it would be trivial to have an
export option for these, since they are extremely simply to output as quads of
two triangles.
Isosurfaces would be a lot more difficult I think - there has been a long
history of trying to implement meshification of these objects.
Now, perhaps if there are libraries at your disposal for things like convex
hull, it might be easy enough to provide at least that, so that there was some
data for users to experiment with and think about various approaches to more
completely represent such surfaces prior to render phase.
- BW
