POV-Ray : Newsgroups : povray.binaries.programming : UV-mapping - problems on surface edges. Server Time
22 Dec 2024 04:35:46 EST (-0500)
  UV-mapping - problems on surface edges. (Message 1 to 4 of 4)
Subject: UV-mapping - problems on surface edges.
Date: 13 Jun 1999 09:39:25
Message: <3763B492.E705A36@fv.aetec.ee>
Hello.
Hopfully this is not very wrong group, as it seems to be only binary
group, which has relevance for this message ;-)
I have problem with UV-mapping: it seems to me, that it does not work
correctly on surface edges. I use Rhino for creating surfaces and then
export them to .3DS and from it with Win3DS2POV to Pov-Ray format.
Now, when I compare output from Rhino renderer and from PovRay, then it
could be seen, that on edges, where U and V have small values, texture
mapping is corrupted. I add 2 pictures to illustrate this problem. UV
values run in Rhino model from 0 (green-yellow corner) to 7 (red-blue
corner).
Is this known problem and/or is there workaround for it? I tested it
with UVPov 5.2. If it helps, then I can send test files for it (texture
map, 3DS file, PovRay files).
Download 'rho.jpg' (28 KB) Download 'uvpov.jpg' (27 KB)
Preview of image 'rho.jpg'
Preview of image 'uvpov.jpg'
Subject: Re: UV-mapping - problems on surface edges.
Date: 13 Jun 1999 23:21:29
Message: <37647484.42C3898B@Kopp.com>
Someone else had a similar problem, but I was unable to find the problem
at that point.  Hopefully I will this time.  That person was also doing
a Rhino->3ds->POV conversion, so the problem may be in one of the steps
of the conversion process.  But I won't rule out UV-Pov.  I'd rather
you not email the files (limited disk space on the server holding my
email), but if you could post here or in the scene-files group, I'll
take a closer look.
-Nathan
Vahur Krouverk wrote:
> Hello.
> corner).
>  [Image]  [Image]
Date: 14 Jun 1999 00:49:24
Message: <3764890a.1363563@news.povray.org>
just download a new version of Win3dstopov at
http://extra.newsguy.com/~tbaier/
I have found a curious bug with UV-mapping conversion.
Very small values are destroyed.
>Hello.
>corner).
-tb
Date: 14 Jun 1999 11:56:24
Message: <37652636.1D34A74F@fv.aetec.ee>
Thomas Baier wrote:
> Hi,
> -tb
Thank You! This new version corrected the problem. Other Thank You for
writing textures to different file from objects: it was not easy to edit
files with size 12M.
